RTV-XG850
/ RTV-XG850 #2
That looks great, if I were in the market for a UTV this would definitely be on the list to check out. Limited slip front diff and locking rear, but it says "foot operated locking differential". Blah. Is that how they implemented the diff lock on the older RTV's?
/ RTV-XG850 #4
.... "foot operated locking differential".....
That's a deal breaker for me, unless it can be pushed to lock and left that way w/o having to keep pressing your foot.
/ RTV-XG850 #5
How can you expect to have a rear differential lock and then expect to operate in any way but a straight line, have yet to see a mechanical differential lock that was not spring loaded.
Have seen electrically activated rear differentials and have a front one on my quad with pumps driven by the spinning wheel that will lock up but once the wheel gains traction it unlocks the clutch pack as the fluid is no longer being pumped into the clutch pack.
Think you will be waiting a very long time for a differential that stays locked all the time as once it is locked steering in a direction other then straight is difficult.
David
/ RTV-XG850
Someone posted on the OTT forum that his dealer told him it is a Subaru motor? If that's the case I would be happy with that. All my Subaru/Fuji/Robin motors have been trouble free for me.
And the Fuji in my older Polaris was the only one that starts in the minus 40 degree weather we have had. The new fuel injected Polaris made one....not a chance.
/ RTV-XG850 #7
....Think you will be waiting a very long time for a differential that stays locked all the time as once it is locked steering in a direction other then straight is difficult.
David
Huh? In every quad I've owned along with my current Honda Rancher the rear axle is always locked with no ability to unlock. My Polaris Ranger's rear axle is locked unless you toggle the switch to "open". My previous Mule could be mechanically locked.
I just checked Subaru/Robbins website and saw this which is kinda sad; Small Engines | Pumps | Generators | Subaru Industrial Power
"Effective October 2nd, 2017, Subaru Corporation has withdrawn from the small engine power product business and has ceased the production and sale of multi-purpose engines, generators and pumps.
Industrial Power Products of America, Inc. will be responsible for supplying replacement parts to our distribution network as well as handling warranty claims."
/ RTV-XG850 #8
Yes, most sport quads have a solid rear axle. No unlocking those unless its broken.
My previous ATV and current UTV have locked rear axles. You need to get the models with turf mode to have the ability to unlock the rears.
/ RTV-XG850
DK35vince is correct. All modern atv's and side by sides have locked rear axles unless you get one with "turf mode" as he said.
/ RTV-XG850 #10
My Kubota UTV has a lever on the dash to lock/unlock the read dif...
If you leave the lever in the lock position, the real axle stays locked.
SR
/ RTV-XG850 #11
On my RTV-X1120D, the diff lock is a heel operated pedal, but there is an additional hand-control knob that you pull up to lock the pedal down without keeping your heel on it.
/ RTV-XG850 #12
Utility quads from what I have seen are open differentials on the rear because of their size and weight, My Outlander has the Visco Lock on the front with open non locking on the back.
For some reason the US bound Polaris RZR 800S that we have has a solid rear axle which makes road driving horrible but the Europe bound ones had the turf saver switch that turns the rear axle into 1 wheel drive. The front axles are a dual roller Hilliard design making each side independent.
David
/ RTV-XG850 #14
This is very interesting because Kubota is using the same CVT rubber belted transmission as I have in my RTV-400 with only 16hp from a one cylinder EFI Subaru engine. Yeah, did not like hearing there will be no more Subaru Robins. I wonder if it's all the competition from Chinese motors. My RTV has the lever on the dash, unlocked normally, locked if you move the lever. I've used it once in five years...though I do engage it once in a while just to move the machinery around. Two levers, one for 4wd, one for locked diff.
The CVT grinds gears (which is strange because it doesn't really have gears...) if you try to shift too quickly. I hope they made that better in this newer model. Really need to count 1001, 1002 then change gears.
Am guessing this model is for wide open spaces, where owners have big farms or ranches and need to boogie for long distances.
Pure overkill for my puttering around.
Kubota makes a number of small gas engines; would be interesting to know if they build this one, a lot larger than the others.
/ RTV-XG850 #15
That would be ok then if it's like that, just as long as it can be left locked when needed w/o holding a peddle down.
2020 BROWN AND HUBERT 10' SPOOL TRAILER (A63276)
2020 BROWN AND...
2009 Chevrolet Tahoe SUV (A64557)
2009 Chevrolet...
20 GALLON SPRAYER, 12V (A64278)
20 GALLON SPRAYER...
Swict 66in Bucket Skid Steer Attachment (A64553)
Swict 66in Bucket...
2022 SANY SY50U EXCAVATOR (A63276)
2022 SANY SY50U...
Welcome to the Ranch (A64557)
Welcome to the...
