Used Crane Advice
/ Used Crane Advice #1
0o0
Austin, TX
JD 5520
I've been looking into buying a used mobile crane for on-farm construction tasks such as setting steel roof rafters.
Browsing auctions for government equipment I saw many Terex LRT-110, a mil-spec crane, with very low hours (under 50) regularly sell for around $15,000 in operating condition aside from a dead battery. I don't know how old they are, but assume most were made in the 1990s.
Mobile Cranes For Sale | GovPlanet
How do these military cranes compare to other used cranes? Is there expensive maintenance I should expect to do immediately?
Would something else like a carry deck crane or telehandler make more sense? I want to spend under $20,000.
/ Used Crane Advice #2
Be careful with crane, I have seen many accidents from improper operation
/ Used Crane Advice #3
I'd look more into a "truck crane" for versatility
over the "neck breaker" you have pictured. (Not that I am certain that the crane operation is from the cab only on that Govt. unit). That term came from this type of crane with limited visibility to the front & sides only.
imgres.jpg I have seen some nice truck crane's in that same cost "neighborhood" and I could see where having a good sized bed for self loading along with controls on each side of the truck (usually) would be much easier to operate in a 360* work area.:thumbsup:
/ Used Crane Advice #4
I have loved cranes since I was around three years old. There used to be a pipe manufacturer near us with all manner of tracked cranes in their yard. I would go nuts.
But for most, including me, it would have very limited use. A telehandler would be much more useful (I owned a 12 ton one). It can fill in for a crane.
The day we got the Dynalift.
Always liked those REAL sized wheels! lol
/ Used Crane Advice #5
I was the equipment officer/manager for several Navy expeditionary Reserve units. Those low hour units are virtually brand new. The military replaces CESE (civil engineer support equipment) based on calendar age not on hours. Some reserve units do not use stuff very much; but, they over maintain for training of maintenance crews, batteries run down, and rubber goods deteriorate. Beware electrical systems are 24 volt and the batteries are very expensive. In your case you could get by with smaller batteries though.
Because of requirements for durability and reliability over wide conditions; military CESE is way over engineered compared to civilian market equipment. We used to re-certify our cranes every year even though not used just for the training value. That unit you were looking at probably cost DOD $100K +/-. We had a tactical wrecker built onto a 5 Ton cargo truck that cost $350K where a civilian counterpart would be $100K. If you get one be sure and get the O & M Manuals. Engine internal parts are fairly standard but most other parts are unique to the military. Most parts are available in the surplus market place. Major work is done in specialized depot maintenance/repair shops not by field units. In Vietnam I Corps area the Marine Corps actually had depot shops the Seabees built; right across the road from the camp I was in. Military parts were fairly easy to get over their but we had a civilian fire truck that needed a drive shaft for the main pump; previous battalion had on order 6 months, we were there 10 months, still on dead line.
That unit will outlast you 2-1 if maintained. Also they are diesel hogs with engines way bigger than a civilian counterpart. Not built to Green standards.
Ron
/ Used Crane Advice #6
I have been told the mil units have short booms compared to similar commercial lift units. Military uses them for material handling (containers) more than construction. Look carefully at your use and their reach charts.
/ Used Crane Advice
Ron
Thank you for sharing your expertise. I don't expect to be building anything taller than 25ft and only a few dozen hours a year use most likely (higher fuel usage not a significant issue) so this will be perfect.
My thinking is the 2 piece boom means less to go wrong and easier to repair. The idea of military reliability and very low hours is appealing.
They sound like great machines for the price.
I will probably buy one of these in the next year or two unless I find a better deal on a good condition telehandler or truck crane.
/ Used Crane Advice #8
In my era the basic crane was a 25 ton lattice Boom crane. Real work horses, not unusual to overload them at times as nothing else was available. The military has since gone to squirt boom cranes (as we called them) due to versatility and compactness. You will find rotating ones in the surplus market now as well as what your were looking at. They range down to 5-10 to capacity, probably closer to your need. We call them Cherry Pickers. The Navy Seabees have now gone to a lot of commercial grade stuff since working alongside some many civilian contractors in combat zones and the cost for special tactical equipment. Before I retired and before HUMVEES, we had even started getting civilian pickups and other small vehicles. They had electrical systems upgraded to 24 volt to make compatible with existing stuff.
Ron
/ Used Crane Advice #9
I watch a lot of Government auctions and regularly see the same ending bid results on cranes. You can get a lot of bang for your buck but as my buddy always says, "A sale is not good deal if you don't need it." I think it sounds like the crane is way more machine than you need AND it's single purposed. A telehandler is a very versatile machine and could serve regular daily tasks and serve as a crane when needed. The 20K budget is tight but some dedicated auction watching can make it possible.
/ Used Crane Advice #10
Sell your tractor and buy a compact telehandler: http://www.tractorbynet.com/forums/...pact-telehandler-post3243370.html#post3243370
These are 40' steel trusses:
/ Used Crane Advice #11
I worked for a crane manufacturer for 10 years. In that time frame we built cranes for the Air Force and Marines. Memory wise unit was built structurally same as other units. Now could be different specs for engine or tires or such. Remember the Marine unit had mount for M16 in the cab. Things I can remember different was special paints used due to the use of one in water and it also had all electrical connects sealed with silicone sealant. But basically same machine as regular unit was except tweaked for their needs. If battery box is like the ones we had we used 12 volt batteries wires in series to get the 24 volts. Then all our units cranked on 24 volts.
Using crane with boom rotating and you sitting below it is not as good as one that rotates wit the boom but you will or should have clear view of about 180 degrees. I would have no issue buying a unit like that. Just do the normal checking the machine. Regardless of what type of machine you buy tipping is a major concern. Study proper operation. Move load low as possible to help prevent roll over, much like front end loader use.
/ Used Crane Advice #12
The unit in your pic looks super!!!!--- it would serve you well for your type use!
Cranes are a piece of cake to run!!---Just be careful and you will do fine!
I did own a BE truck crane for many years and they are very handy when you need them. thanks; sonny580
/ Used Crane Advice #13
Don't do it. You'd be much better off with a telehandler. The crane is single use. The telehandler is the way to go.
First, read this thread from 2001. It's a long read, but makes tons of sense. Worth spending some time reading.
http://www.tractorbynet.com/forums/related-topics/5108-compact-tractors-designed-all-wrong.html
Implements, with few exceptions, like dirt plows and large mowers, belong out front where you can see them.
For all other tasks, the telehandler makes the most sense and bang for the buck.
Read Xfaxman's posts and reasoning...
For that matter, if we can't talk you out of buying that crane and into buying a telehandler instead, consider investing the $20,000 and using the interest to rent a telehandler when you need it. In the end, you'll still have your $20,000 (probably way more), and won't have a single purpose machine sitting behind your barn with the tires going flat and batteries dead. ;)
/ Used Crane Advice #14
Watch this comparison video. Granted, the crane in the video is larger than the one you're looking at, but the principle is exactly the same. Talk yourself out of the crane... ;)
/ Used Crane Advice #15
I agree that a crane is a single purpose piece of equipment and a telehandler is much more versatile. But for a $15-$20k budget.....I'd expect a telehandler to be a good bit rougher in shape than that crane
/ Used Crane Advice #16
Agree on that. Gotta find an old lady that only drove it to church on Sundays.
/ Used Crane Advice #17
Or, since the OP is looking at a camo crane, he might also look for a camo telehandler...
Aaron Z
/ Used Crane Advice #18
Aaron Z
Lets just hope they didnt park it in the woods....might make it hard to find:laughing:
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
Purdy PT 60' Land Leveler (A64126)
Purdy PT 60' Land...
Luck Now 425 (A64126)
excavator trenching bucket- one bucket per lot (A63689)
excavator...
New/Unused landhonor 5 Gallon Vacuum Cleaner (A65583)
New/Unused...
John Deere X500 Riding Lawn Mower (A66285)
John Deere X500...
