Buying Advice Kubota BX2751 Front Quick Mount compatible with BX80 series?
/ Kubota BX2751 Front Quick Mount compatible with BX80 series? #1
KennyR
Member
Big Rock, IL
Kubota 2380
I'm a longtime member, but haven't posted for a few years. I've searched without success, but have a question impacting my upgrade options.
I have a BX2360 with a number of Kubota attachments, and am considering upgrading to a new BX23S. Will my BX2751 front quick hitch (used with a BX2750D snowblower and BX front blade) will fit on the BX23S or any of the BX80 series tractors. My local dealer does not have a BX80 on the floor to check/measure.
Thanks for any help!
/ Kubota BX2751 Front Quick Mount compatible with BX80 series? #2
Kenny not positive but in the same boat, DONT THINK SO....
I have that hitch with 2 pins, new frame is missing that.
/ Kubota BX2751 Front Quick Mount compatible with BX80 series? #3
Also this is the new plow...
SlimShadie, Thanks for your help and pictures. I think you're correct, from the pictures it looks like there's a very different hookup for the front quick connect. Plus, the hose couplings are different between the BX60 and BX80 series. I may look at the one BX80 at my dealer and do some measurements to see if there could be any fairly easy fabrication options
It looks like the plow itself is near identical, so wonder if Kubota or aftermarket will sell the parts to convert and attach the older BX2750-D snow blower to the new BX 80 series. Wasn't thinking of selling/trading my current blower (with hydraulic chute rotation) and plow just to rebuy a different connection system. May need to contact Messicks to see if they know anything about conversion, etc.
/ Kubota BX2751 Front Quick Mount compatible with BX80 series? #6
No. The old implements will not fit on the new BX80 Series. What they said was that the new design would not allow the old front hitch, so they made it better since the old implements would not fit anyway. They also mentioned that they could not produce an adapter plate because it caused the implement to be pushed too far forward. I think the snow equipment is basically the same, but the sweeper has changed to a 24" disc (we don't use a lot of snow blowers down here, but we do have a few brooms).
Thanks for the added information. I wonder why Kubota didn't consider that a number of owners with older BX models may not really want to spend another $5K+ to replace all of their front mount implements. Deal killer for me. I guess my BX2360 will be good enough for a number of years to come!.
/ Kubota BX2751 Front Quick Mount compatible with BX80 series? #8
Hi There everyone. I just thought I would post my first message on here. I just traded a BX 2370 for a BX2380 and used the old front hitch and blade setup. There was no modification required the lower frame is the same. The reason I went with the old style is the new setup moves the implements to far forward, and also strength of it was questionable. The only problem you run into with the old hitch is that you can't fully open the hood while its on. Since it only takes 1 minute to remove the hitch it is not that big a deal. Hope that helps.
Trops, thanks for the update...you're the fish person who has upgraded to the BX80 and was able to mount the front attachment hitch. That is very good news to those of us who have the front hitch and blade/snowblower attachments. Thanks again.
/ Kubota BX2751 Front Quick Mount compatible with BX80 series? #10
Trops the frame doesnt look like it has the same holes for the pins on the Bx2751? Can you verify? Pics?
I had same question, here are a few pics of BX 2380 I took yesterday from my dealer. Looks like the bottom of front frame is the same, even has the "hook" for the BX60 mid mower front bar. It does look like the front frame may stick out about 1/2 inch more (I don;t have my BX 60 to check)? If so, would just need to have hole redrilled.
/ Kubota BX2751 Front Quick Mount compatible with BX80 series? #12
Hi Guys. Before I traded the 2370 I had it at the dealer for some service work as well as getting them to appraise it for the trade. While there we took the blade and quick hitch off my 2370 and mounted it right on to a new 2380 that was in stock. Everything lines right up we didn't need to do anything to make it work, no drilling at all. As I stated before the only issue you run into with this setup on the 2380 is that you can't fully open the hood with the hitch on. You can get it open enough to check oil and clean rad screen. One other thing that came up was the hydraulic fittings are different so they changes the hose ends from the old hitch and blade angle hoses. When I picked up the tractor they had the mower on and the blade mounted, so you can have them both on at the same time. I have the blade off right now as I don't it on right now. I can put back on quickly take a pic if you need.
After starting this thread and getting the answer I was hoping for, I ended up trading my BX2360 with the front hitch, snowblower, and blade for a new BX2380 with QA front blade. My dealer gave me a very nice trade in for everything, along with a nice discount from MSRP on the new set-up. My reason for going with the new BX2380 was the drive-over mower, easier removal and install of the loader, and QA attach front end...ease of implement removal and install is increasingly important since I'm not getting any younger!
I realized I only used the snowblower maybe 4-5 times in the past 7 years (when the snow was over 8-10 inches and nowhere to push it) so really didn't use or need one. I liked the more compact front blade mount on the BX2360, but think that having the new blade mount on the QA loader arms will let me mound the snow higher as it gets deeper later in the season. Thanks again to all who helped with my decision!
/ Kubota BX2751 Front Quick Mount compatible with BX80 series? #14
Hi I am new this site but been coming here a few years for good information about tractor. I recently traded my kubota bx2350 in on a new model kubota bx23s. I was following this tread because I still have BX2751 quick hitch for the BX2750 snow blower. I was told that it will still fit new tractor when I bought the tractor. I was informed today that it would not fit the hydro. If anyone knows if bx2751 hitch fits bx80 and what are the part number for the hydro connectors?
As Trops said in Post #12, despite what Kubota indicates, he actually tested and found out that the 2751 hitch will in fact mount on the front of the BX2380 without any major modifications, other than impacting the hood fully raising. You would just need the dealer to change out the hydraulic hose coupling on the hitch (which controls the raise/lower function) to match the new quick-detach fitting used on the BX80 series. Your dealer's parts department should have the parts diagram for the BX fittings, and should be able to change the fitting fairly easily and inexpensively. Let us know if you make the change, and post a picture!
/ Kubota BX2751 Front Quick Mount compatible with BX80 series? #16
Well took me few months to get everything in from kubota for the bx 2751 quick hitch conversion. It does fit on the new bx 23s. I did take some picture to verify it.
Glad it worked out for you! While I bought a new quick connect B2672 plow for my BX2380, its is not as nearly easy to use as the old plow that used the quick hitch. It's a lot of weight on the end of the loader arms that causes bouncing even with a lot of back counterweight, and it is trickier to set the plow blade at a consistent angle and curl when working with the 3 function value. I'm sorry I traded in the old plow and quick hitch, and may consider locating a new BX2371 and converting back to the old system.
/ Kubota BX2751 Front Quick Mount compatible with BX80 series? #18
Kenny, give it some time. I posted a while back on the problems I've had with the FEL mounted blade. Now, I can whip around with the blade clearing my drive and almost dropping the blade to the perfect level each time. Before, I put the blade in float and would lose all steering because of the weight. I was considering a new 80-series with the QA front blade because of it, but think I'm fine now. If I do keep my BX2670, I'll add a third function and hydraulics for angling the FEL blade. On my fourth year without EVER using the 50" rear blower, I'm selling it and getting a rear blade to compliment the front blade.
Thanks, I'm not doing anything this year, and I'll see how well I get used to the blade operation. I finished installing the 3rd function valve last week to add the hydraulics for the blade angling...was about a 5 hour job. It's trickier when you have the 3rd function, as it is very easy to apply a bit of side pressure to the stick when moving the blade if you don't keep your thumb on the 3rd function button...moves too fast in one too many directions! I'm still learning how to fine tune using the joystick positioned on the side of the BX2380...I knew the feel and touch on the front-mounted joystick of my old 2360.
And PM me if you're selling your rear blower. I had the front mounted one as well but traded it in when I got the 2380, like you I hadn't used it in a couple of years (but was nice to have it as a back up for the 15 inch snow we would get every 3-4 years).
/ Kubota BX2751 Front Quick Mount compatible with BX80 series? #20
You guys with the front QA and blade... does the blade come with the hydraulic angle, or is this additional? Build and price won't add hydraulic angling except to the FEL mounted blade. I'm interested in angling for the front HD blade that used the frame-mounted QA for the BX 80 series.
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
2016 Peterbilt 337 S/A Flammable Liquid Transport Truck (A60352)
2016 Peterbilt 337...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2014 INTERNATIONAL PROSTAR 6X4 T/A  SLEEPER TRUCK TRACTOR (A59908)
2014 INTERNATIONAL...
Case skid steer wheels and tires (A61307)
Case skid steer...
20FT X 12FT LIVESTOCK SHELTER (A58214)
20FT X 12FT...
