Loader Bucket Breakout Force
/ Loader Bucket Breakout Force #21
I am not familiar with your loader, but can you swap end to end the factory cylinders? therefore the rating would be the same but the curl back would be the stronger circuit and the curl down would be the weaker, instead of the way it is now? you could test by switching the hoses at the quick connect but then the controls would be backwards. if you like it then switch the cylinders around. dont leave the controls backwards, that could be dangerous to other drivers.
Just a thought.
MrC.
Not gonna work.
dont matter which direction the cylinder is oriented, retract is still gonna be curl
First check the pressure, 10% is the golden rule, it will make a huge difference. seriously
I wouldnt say golden rule.....but 10% is still probably within the safety design of everything.
A ~2600psi rating from factor......+ a 260psi increase......still only 2860psi and still well under 3000psi component limitations.
And 10% boost in pressure is a good bit more than 10% increase in actual usable capacity.
/ Loader Bucket Breakout Force #22
Just a thought.
MrC.
As LD1 said it’s not going to work. The only way to do that is with a lever. Look at a real loader for example. Most of them curl the bucket up with the extension stroke of the cylinder.
The other holes will not work, your cyls well hit the boom. No matter what you do you can't lift the hole pile. I was told that along time ago and also was told when the bucket is full get out of there, time is money.
The cylinders I was thinking of using have a tapered mounting flange on the butt end. They will fit but the clearance will be close. It's a moot point anyway since boosting the hydraulic pressure a bit seems to be a better way to go.
I'm not trying to move the whole pile at once, just fill the bucket with one pass. Yes, time is money and it takes time to make a second attempt to fill it. Some "finesse" is required to fill a FEL bucket from a compacted pile. You can't just bury the bucket and expect to lift it with these compact tractors. I've been doing it for over 30 years using many different machines.
TSO suggested I buy a bigger tractor if I want a stronger loader. That's what I did when I traded my old L3430 and LA723 for the MX5800 with LA1065 last year. At almost twice the HP and close to a 50% increase in rated FEL strength with the same bucket size, you'd think there would be a big improvement. Not so. There was a slight increase in breakout performance but no where near what I expected.
In any case, thanks everyone for your comments and suggestions.
/ Loader Bucket Breakout Force #24
Much closer to a 20% increase in loader capacity.
The M and the Grand L you had are pretty close in physical and frame size. The MX just packs alot more HP. There isnt anywhere near 50% difference in loaders.
And another thing......dont know if your L was equipped with a SSQA or not. But the SSQA not only adds weight (reduces capacity) but it also shifts the load further forward. Neither of which work in your favor.
I have had no issues digging in compacted piles with my MX. But technique is key. You cant just bury the bucket in and break out like I can on my Ford 5500 with massive 4" diameter lift and curl cylinders.....and only a 12" wider bucket.
Yes, I can bury the bucket on the MX and not be able to move it....because it has the traction to bury into the pile. But technique of lifting and curling while advancing all at the same time and it becomes second nature. I can come out with a full bucket everytime
If You look at the Kubota Specs, the breakout force for the LA723 is 2605#. For the LA1065, it's 3981# or a 52.8% increase.
Both tractors were equipped with SSQA.
I agree about technique as I said. I also can fill a bucket with one pass in certain types of material. I deal mostly with rocky rooted hardpan and red shale where it isn't so easy. Just a modest increase in breakout will make a big difference for me. Thanks to what I've learned from the posters here, I should be able to get some improvement through hydraulic pressure adjustment.
/ Loader Bucket Breakout Force #28
Im not seeing the 3981 number.
Im seeing 3102 vs 2605.......a 19% increase
and 2275 vs 1870 for lift to full height at pin.......a 21.6% increase
and lift to full height at 500mm forward.....1691 vs 1400.......a 20.7% increase....
AND.....kubotas loader model numbers indicate their lift capacity. Make the last number a ZERO and thats your lift capacity in KG. (last number is revision)
BUT......sometime about 3 or 4 years ago....kubota changed WHERE they measure that at for model # purposes. It used to be at bucket center.....
So the 723 loader is 720kg......3rd revision.........and 720 kg = 1584# at bucket center.....(about midway between the 1400lbs at 500mm and the 1870 at the pins).
Dont know if they still do....but kubota manuals used to list ALL 3 numbers for lift. Bucket edge (500mm), bucket center, AND pins. They also usually include a graph (curve) because a loader is MUCH stronger at ground level. Usually the "breakout" force is what the loader can lift at ground level with the lift cylinders. MUCH MUCH higher than at max height.
Now your LA1065 loader.....is newer. remember I mentioned they changed where they measure for model purposes. On your model.....1060kg refers to lift at pins in KG. or 2332# (pretty close to the actual spec of 2275...probably some rounding up involved) And its the 5th revision.
The previous loader on the MX (same loader different stickers) was an LA854. 850kg....4th revision.
So you are comparing a 720kg loader to a 850kg loader.
Gotta understand marketing......and just how loaders are rated. Because it can all get very confusing.
Just trust me when I tell you....that your MX loader is no where near 50% stronger than the LA723. The 20% stronger that I said......thats reality.
/ Loader Bucket Breakout Force #29
I have the MX5100 and cant complain about the loaders digging ability. I put a 1400lbs counter weight on the 3pt so that I can use the full power of the loader without lifting the rear wheels. Even with the weight I can get the rear end too light to safely move around. Cant see how you can add more power safely without the risk of overturning the machine rather easily.
/ Loader Bucket Breakout Force #30
...Cant see how you can add more power safely without the risk of overturning the machine rather easily.
There is a chance that the PSI was set too low... would like to know the "before" PSI...
/ Loader Bucket Breakout Force #31
That extra hole would allow you to make a simple bracket to use the longer cylinders.
Cut four pieces of steel, triangular shaped.
Compared to a slice of pizza, add two holes at the "crust" edge,
so the new triangular brackets can be bolted to the holes shown in the pic in post #1
Then, add a third hole at the point of the triangle, that is now pointing up
(or angled back to accommodate the length of the cylinder)
The rear of the cylinder will drop in between the new brackets.
The new hole is positioned to fit the longer cylinders.
A rectangular plate is welded between the two new triangles, at the back,
Hopefully, no welding of the existing loader frame will be necessary.
I always prefer bigger cylinders as compared to added hydraulic system pressure.
There are too many other components in the hydraulic system that will not like a higher pressure.
I do not think I heard the answer to the toothbar question??
My tractor is a crazy digging machine when the toothbar is on,,,
Without the toothbar, I could barely scratch this hard clay/rock soil,,,
My toothbar is off a CAT skidsteer,,,
/ Loader Bucket Breakout Force #32
Don't disagree at all - if it is in spec the machine seems to have plenty of power for its weight/size. I have mine within spec but if I recall it was just very slightly under the max recommended.
This is quite upsetting. I didn't expect a 50% increase in the overall strength of the MX / LA1065 (lifting capacity etc.) That's not what this post is about. My main concern is ground level breakout force.
I bought the MX primarily due to the dealers assurance the breakout force on the LA1065 was about 50% higher than the LA723. He showed me specs from the respective FEL manuals for the ground level breakout force measured at the pivot point. The LA1065 was rated at 3981# (see pics) and the LA723, 2605#. It seemed a fair comparison.
You are obviously more knowledgeable about Kubota FEL performance than either myself or the dealer. I've been a good customer at this dealership for many years and I don't deserve to be lied to. I'm going out there this week to pick up some filters and I'm going to confront them with your math.
This thread has been very educational for me and thank you for sharing your knowledge.
/ Loader Bucket Breakout Force #35
I don't particularly think he was lying to you, I mean he pointed out a number that was legitimately on the page. I think it was more like, he was telling you what you wanted to hear, and you fell right into it.
/ Loader Bucket Breakout Force #36
(I'm saying this in jest!!!) Enough about Math and just get a tooth bar... A tooth bar will do more for your break out force than Math ever will!
PS adding the standard L's went from LA463 to LA524 and now to LA525 - they all lift the same amount.
/ Loader Bucket Breakout Force #37
View attachment 536551 View attachment 536550
Yea, I dont think it was intentional.
But I believe the 2605# for the LA723 is at 500MM......so that compares to one line further down in your manual.
As I said.....many people get hung up on the confusing specs.
Capacities at Pins? vs Bucket center? vs 500mm forward.... (and on larger tractors that is at 800mm forward).
then at what lift heights? Max height? Ground level? Somewhere in between?
And like I said....you basically have the newer version of a 854 loader. Going from the 723 to the 854 isnt much of a stem.
And it apears not as much of a step as you were lead to believe. Trust me....its only 20% more loader and not 50%.
But doubt there is anything the dealer can do now.....if he even remembers. But you may be able to talk him into checking system pressure on the house.....and boosting it to max spec.
I notice you also have a L6060. Do you have the LA1055 loader on it? Basically same specs on that loader. Notice any difference?
And unfortunatally.......you have the BIGGEST tractor you can get from kubota with a loader AND HST. Next step up puts you into GST trans.
Test pressure first and foremost.
I dont have a toothbar on mine. And have no issues digging out of piles. And with my old L3400.....pre bucket teeth vs after......still never noticed an issue breaking out from a pile......but the difference in digging virgin earth was pretty big.
/ Loader Bucket Breakout Force #40
Just a thought.
MrC.
Maybe I am not understanding what your suggesting, but I think you are saying to remove the cylinders and flip the body end and chrome end, and put back on. If that is what you are saying, nothing will change. It does not matter if you flip the cylinder like that, extending is still dump, retracting is still curling the bucket. The forces have not changed at all.
To truly "flip" the function, you would need to weld brackets to the bottom of the loader arm and bucket so that extending was curl up and retracting was dumping. But then your cylinders would be underneath and in harms way.
2011 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A66736)
2011 Dodge Ram...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
Metal Eagle Weather Vane (A66738)
Metal Eagle...
THERM DYNAMICS TD 375 FLAMELESS HEATER (INOPERABLE) (A68842)
THERM DYNAMICS TD...
2008 CHEVROLET IMPALA CAR (A66091)
2008 CHEVROLET...
2019 Cadillac XTS Stretch Limousine for Sale, S and S Coachbuilders, 70IN, 7731 Miles (A63689)
2019 Cadillac XTS...
