JD 1070 charge light help?
/ JD 1070 charge light help? #1
Zeke56
Lee, NH
JD 1070
For the last 5 or 6 years, I've replaced 4 regulators. Alternator has been checked and confirmed good.
Fan belt tension, fine. Last year, no light would come on until 2100 rpms without lights. With lights, it would come on around 1600 rpms. This year, the charge light comes on around 1600 rpms with no lights. With lights, it's on regardless of rpms. Now, after another brand new regulator the other day, the charge light still comes on with lights and no charge light until maybe 2100 rpms without lights.
Disclaimer: I put 3 auxiliary tractor lights on this tractor many years ago. It ran with no issues for years with the exception of maybe one or two new regulators? I'm planning to switch out those lights to LEDs, but ultimately wondering what the electrical issue is here?
Would appreciate any help.
Thanks in advance.
(Scratching my head)
/ JD 1070 charge light help? #2
I don't have your answer, but I have a PDF of the Deere tech manual you're welcome to.Shooy me your email if wanted
Joe
Thanks for the offer, Joe.
I think that I have a copy of the tech manual.
Just don't know where to look to find the problem.
If I knew what was causing this, I'm pretty sure I could fix it.
Thanks again,
/ JD 1070 charge light help? #4
If you can mount an automobile alternator (a "Delcotron") with built in regulator/rectifier, you can leave of all of the external stuff. We used to stick those on anything! (I know of at least one person who put one on their airplane.)
/ JD 1070 charge light help? #5
Have you checked the battery cables and BOTH ends (especially the ground). Mine comes on once in a while. The terminal on my VR got so hot once that it melted the insulation and terminal off at the regulator.
/ JD 1070 charge light help? #6
Check grounds especially frame to engine. Check the indicator light circuit as well as the actual bulb to make sure it's the correct one, I believe the bulb is not just an indicator, it's actually part of the charging circuit correct Ω is important............Mike
/ JD 1070 charge light help? #7
The charge light is turned off by two positive voltages. One positive comes from the key switch and the other comes from the alternator. When the alternator is not charging that circuit is negative and the light turns on. As the alternator starts charging that circuit becomes positive and turns the light off.
The first thing I would do is take a multi meter and check the actual volts that you are getting at the alternator and at the battery. There might be nothing wrong with the alternator and the fault might be all in the charge light circuit.
I would get those added lights out of the circuit, and then check all your connections including grounds. The next thing I would do is look more closely at the alternator. I believe it is actually more of a dynamo since it only puts out an AC voltage. If you have the tech manual, go through the trouble shooting procedures on the alternator. I don't know its ratings, but it would be interesting to see what it does under various loads. I know you've had it tested, but I just have my doubts about it if all connections are good.
I see that the Tractordata website lists the electrical system at 20 amps with 35* also listed. Could it be a 20 amp alternator installed but using a 35 amp regulator?
Thanks for the help. I'll have to dig into the tech manual. The alternator has a clean ground (when checked last year) and a plug in harness. The tractor does have both a 20 amp alternator and regulator installed.
I plan on taking off the added lights and going back to basics (to check) before I add the LED lights. Hopefully, they'll draw a lot less? The interesting thing is that the lights I originally added, worked fine for several years.
Yes, thanks. Both ends are kept clean and covered with dielectric grease as are the terminals.
Thanks, Mike. I'll have to look for the frame to engine ground. The indicator light bulb is the original. Not sure if it's part of the charging circuit or not? I will pull the dash and take a look at the circuit.
Good info right there, pmsmechanic.
We had very cold temps here a couple weeks ago. Below 10 degrees for maybe a couple weeks. The tractor started fine the few days I needed it. But, I kept it running mostly without lights and at rpms that wouldn't turn the charge light on.
If I run it with lights (charge light on) for long periods the lights will dim (battery dying).
I have a schematic that is called "New Version - March 1999" and the above is not the case. However, if you have a diagram of the innards of the VR, then the above might prove to be true with the "Old Version." My version shows one side of the bulb tied to ground. I'll dig through my books tomorrow and see if I can find the old version schematic.
I believe this tractor is a 94 or 95 but can confirm.
TIA for the old version schematic.
/ JD 1070 charge light help? #13
I'm just gong by how it works on a Delco alternator. I don't have access to a service manual to try to figure it out.
/ JD 1070 charge light help? #14
All of the information posted so far seems to point to a weak alternator.
rScotty
/ JD 1070 charge light help? #15
rScotty
I have a 1070 bought new in 96 so it is approx. same vintage. I've been running one auxiliary light (sometimes) all those years with no issue. It does sound like a weak alternator. I would check voltage at the battery while it is idling with and without the lights on, and with and without the auxiliary lights in the circuit. I would assume voltage should be more than 12. I can do tests on mine if you need comparative numbers. I just installed a new battery this summer - it is the second one in 21 years.
/ JD 1070 charge light help? #16
Hey, that's great. Now we have one 1070 that charges right and one that doesn't. This should make it easy. All we need is to put a voltmeter across the battery and an ammeter in series with the + lead to the battery. Then we record those two readings at rest and at various RPMs, with and without lights on.
If the batteries are good, doing that test should tell us all we need to know.
Start by recording the volts and amps with the motor off and lights on at 5 minute intervals until the voltage drops below to 12.2 volts or so. Try not to go to far below 12.2 volts. That will tell us the basic state of the batteries.
I sure do like those 1050/1070 series JDs. Some of the best.
rScotty
/ JD 1070 charge light help? #17
I looked at the "Old Version" that I found in my tech manual and the charging circuit is identical. One side of the bulb is tied to ground and the other side goes to the VR.
So a double negative turns it off?
/ JD 1070 charge light help? #18
I'm no electrical expert but if I had a persistent electrical problem with one of these tractors I would not only check the battery to frame ground but I would also check the engine to frame continuity. Some of the components were painted before assembly and the ground was carried in the connection bolts. As an example I have two JD 950's and none of the rear lights worked because the rear fenders had lost their ground. Apparently the design was adequate when the machine was new but failed with age. I have added ground straps to solve the problem.
The serial number will confirm it for you.
1989: 001001
1990: 001338
1991: 100001
1992: 115001
1993: 120001
1994: 130001
1995: 140001
1996: 150001
1997: 160001
1998: 170001
Thanks, I'll check it tomorrow.
Thanks for your input, I'll get back to you if I need numbers to compare to.
I will be checking the alternator again.
Love your first battery! Hope the new one lasts as long.
See my answer to rScotty also.
2021 Kenworth T880 Tandem Dump Truck, VIN # 1NKZL40X6MJ464380 (A65563)
2021 Kenworth T880...
150 GALLON FUEL TANKS (A65643)
150 GALLON FUEL...
INOP/NON-RUNNING 2012 Ford F-450 Ambulance Truck, VIN # 1FD0X4GT2CEB23465 (A65563)
INOP/NON-RUNNING...
2014 MASTER END DUMP TRAILER (A65643)
2014 MASTER END...
1990 Wilderness 29 5R Camper Trailer (A66285)
1990 Wilderness 29...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
