Grading Homemade grader for GC series tractors
   / Homemade grader for GC series tractors #1
cdaigle430
Maine
MF GC2410
Saw a quick youtube video on a GC1705 titled home made niveleuse grader. Cant post link now as Im at work and they don't allow youtube access. Man this is sweet....whoever built it is a professional for sure. Anyone on here know this person? Perfect for grading roads but I wonder if there is a spring that gives way to the blade if you hit something?
   / Homemade grader for GC series tractors #2
I think this is the video the Original Poster is referring too, and I agree, it looks pretty nice.
I don't think there needs to be a spring because it seems in a few places he takes a bit too much of a bite and the tractor spins.
   / Homemade grader for GC series tractors #3
Nice, but would it have any advantage over a 3 point back blade?
I think its easier to level out when under the tractor vs behind.
   / Homemade grader for GC series tractors #5
I think as short as the wheel base is it wouldn’t be much different than a box blade. Look how long the wheel base is on a real grader. It would be a lot slower to hook up than a regular box blade.
   / Homemade grader for GC series tractors #6
It has a lot of advantages, and in fact I ripped apart my 3 point hitch grader blade and mounted it to a trailer because of the inherent problems with a 3 point hitch grader. I am not trying to be a computer-cowboy here, just trying to explain why they do not work as good as people would first think.
The biggest reason is, being attached in a cantilevered way, when the tractor goes into a dip,the grader blade digs even deeper behind, but when the tractor goes over a hummock, the grader blade rises from the ground. With a lot of skill , many passes and a lot of use of the 3 point hitch lever it can be graded out, but its not great even then,
But when the blade is slung in the middle between two points (the front and rear tires of the tractor in this example, the blade only rises and falls half as much as the front and rear tires travel. This makes for a much more flatter surface. Kind of kike how a long handplane smooths out wood much better, it rides over the low spots and hits the high spots. On a grader blade it cuts the high spots and fills the low spots.
To get the flattest road, the distance between the front tire and the rear tire needs to be as long as possible, this is why real road graders are so long.
BUT as much as I bashed 3 point hitch grader blades; in tight places, like back grading a new house, a person might not be able to get in there with a long tow behind grader blade.
   / Homemade grader for GC series tractors #7
Assuming you’re working on reasonably level ground the blade doesn’t dig in when the tractor hits a dip because it’s free to ride up. A good operator can compensate for when the tractor hits a high place. I agree that a tractor isn’t the best choice for grading but neither is the tractor grader. With the weight of that setup it won’t be good for anything except loose dirt. A box blade at least has some teeth to help break up loose dirt.
   / Homemade grader for GC series tractors #8
"To get the flattest road, the distance between the front tire and rear tire needs to be as long as possible".
That is exactly why I suggested that you might want to move your blade further back on your trailer grader.
The wheel base on the little GC 1705 with belly blade, is much too short to create any meaningful grading improvement over a simple rear blade, and the rear blade offers more versatility.
Google "Huber Maintainer" to see a tractor type grader that really works.
I would love to have a Huber!
   / Homemade grader for GC series tractors #9
+1 I would make a trailer grader.
The center grader isn't going to do much more than you can do with a grader box.
   / Homemade grader for GC series tractors #10
Yeah, like I said, it's neat but I'll just stick with a 5' back blade for my uses. I don't grade anything I plan to go more than 15mph on anyhow.
2014 VOLVO VHD DAYCAB (A58214)
2014 VOLVO VHD...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58216)
8 TOOTHED BUCKET...
2007 FREIGHTLINER COLUMBIA 120 (A58214)
2007 FREIGHTLINER...
2019 ford Explorer AWD SUV (A56859)
2019 ford Explorer...
IRanch Mini Excavator Wood Grapple (A57149)
IRanch Mini...
2013 John Deere 350G LC Hydraulic Excavator (A56857)
2013 John Deere...
