Cold weather tractor problem
/ Cold weather tractor problem #11
I gather there is a body of experience pointing to the PCV path as the culprit ... and it probably is. I hope it is that, but am also wondering , with abnormal things like oil coming out of the exhaust pipe, what about a blown head gasket ??
/ Cold weather tractor problem #12
You would have to do a compression test on all the cylinders to see if there is a head gasket issue.
/ Cold weather tractor problem #13
You might want to look at getting/making a winter front for the rad. That might help to keep the heat in and the pcv free to operate.
Jim, thanks for that diagram, and Scotty, also for your response. I talked to my local dealer today, and they kept telling me that there is no PCV valve on this tractor, but did supply me with that diagram as well. The diagram doesn稚 say 善VC so it must not have one...or, they are just using different terminology. They suggest bringing it in of course so more damage isn稚 done. Anyways, I知 at work now, but when I get home tomorrow morning, I will try to access this 礎reather and take it apart. Thanks for all the help.
JWR, I hope it is not a big problem or anything expensive also. Something I forgot to mention on my original post... After I let the tractor sit outside for a few hours, I started it back up and moved it out of the driveway so my wife could pull her car out. I left it running for maybe 45 minutes at idle, when I lost track of time playing with my kids. I was doing some reading, and came across ‘diesel slober.’ From what I understand, others have had some diesel slobber, that looks like oil, come out there exhaust when it idles for long periods of time, and not under any load. Could these be what happened in my case?
/ Cold weather tractor problem #16
Operator Manual - translation from Japanese, possibly by a writer who has mastered English as a second language. Common automotive terms with which we are familiar don't translate well far a person not familiar with our terms so there is the need to complete the translation.
If I remember correctly, Kubota came out with a kit that included insulation for some top engine components. My M135GX was back at my dealer's during winter to replace the computer because the power shifts were too rough. They had me visit their shop before trucking it back to make sure I was satisfied. Like yours it had been moved from the warmer shop outside when I got there. The mechanic and I drove it around for a bit until it lost power, and ran extremely rough. The mechanic had me start it again after he raised the hood so he could watch. At that point crankcase pressure had built up to the point the turbo seals blew. Leaking oil fouled the DPF. So in that dealer visit my tractor got a new computer, turbo, and DPF filter. They showed me kits they had in stock for smaller tractors but my M135GX didn't have a kit because I had the only failure. I had no problems after the repair but your story resembles mine so much except for the final failure. I searched this computer for the pics I took but apparently I archived them when I traded the M135GX for a M7-171.
MHarryE, It's a good thing that happened at the dealer, because it sounds like that failure might have cost a pretty penny or two. What makes me thinking, at least hoping, that these guys are right about it being just a frozen breather/vent/valve, is that is still runs just as smooth as it did the day I bought it. Even after I found that the oil fill cap blew off, and some oil leaked out around the dipstick, it started right up, idled nice and smooth, and when I revved the engine up to PTO speed (the oil fill cap was still off at this time in case a valve/vent was frozen), it had no problems, sounded great, and no oil leaked anywhere as far as I could tell. Anyways, I hope all my worry was for nothing. Either way, I'm glad I joined this forum. I've gotten a lot of great replies, from some good experienced people...thank you all.
/ Cold weather tractor problem #18
Could be, but I think it is more likely that the unusually high crankcase pressure is forcing oil into place where it wasn't designed to go. Like the valve/guides/seals for example. The crankcase is one large continuous volume that stretches from the sump to the valve cover that is supposed to be at a neutral or atmospheric pressure.
If you are really concerned about head gasket sealing - and I am not - then an easy way to do a non-invasive check is to submit an engine oil sample and ask that it be evuated for antifreeze byproducts. Blackstone Labs is a well known oil analysis site. Cost is about $30. Although I suggest you never rely on a single analysis report.
rScotty
/ Cold weather tractor problem #19
JWR, I hope it is not a big problem or anything expensive also. Something I forgot to mention on my original post... After I let the tractor sit outside for a few hours, I started it back up and moved it out of the driveway so my wife could pull her car out. I left it running for maybe 45 minutes at idle, when I lost track of time playing with my kids. I was doing some reading, and came across ç§Ÿiesel slober. From what I understand, others have had some diesel slobber, that looks like oil, come out there exhaust when it idles for long periods of time, and not under any load. Could these be what happened in my case?
Yes, Jesse, you will see an unusual amount of "diesel slobber" with the Interim Tier IV engines such as you and I both have. Don't worry about it it - especially if it happens when you are running the engine at low RPM or leaving it to idle. In those conditions the amount of diesel slobber can be surprising. And even more so in yours with the frozen PCV valve. I suspect the excessive slobber is part of why that Kubota chose to have the exhaust on those engines exit toward the ground instead of up into the air where the slobber would be flung all over the machine.
There's an technical explanation for this slobber - You can to a TBN search for EGR valve or injector timing and make up your own mind. I don't think it is normally associated with the PCV valve - although of course if the PCV valve freezes up then all bets are off. I am beginning to think that the excessive slobber comes back to the Tier IV special Interim pollution regulations and the interaction of the EGR valve and the injection timing. Basically, it is increasingly looking to me as though during the Interim Tier IV era - roughly engines built from 2007 to 2014, NOx was reduced at the expense of excessive soot formation - especially at low RPM. If that is true, the slobber and some fuel-burning inefficiency at low RPMs that we have on our Interim Tier IV engines is simply part of the trade off to enable this engine to pass the interim regs.
Jesse, you and I have been lucky so far. Sounds like our engines were not damaged by crankcase pressure - and it sounds as though some were. Have you taken the PCV valve apart yet? I'm going to take a look to see if I even have one today.
rScotty
rScotty, I did have a chance to play around with my tractor. But I didn’t even go as far as removing the breather assembly and cleaning it out. Coming off of the breather, is about a three inch section of rubber hose. My hose was frozen solid. So instead of trying to gain access, I thought I might try and thaw it out first. I pulled the tractor outside, removed the oil fill cap to relieve any pressure (I did cover with a clean rag though) and started it up. I brought it up to about 3000 RPM, and let it sit outside for about 40 min. When I came back and checked on it, I had nothing sputtering out of the exhaust, and I even held a clean white rag up to it. I had no oil around the dipstick, and the rag that I covered the oil fill with was also pretty clean with just a few spatters. I checked the rubber hose coming off of the breather, and it was nice and pliable. I put the oil fill cap back in, and drove around for a bit, finally parking it over some white snow. I continued to let it run at an elevated RPM for another 10 min or so, and there was not one speck of oil on the snow. I will include a picture of that short rubber section of hose coming off of the breather. I will learn from this experience, and definitely run my engine at a high idle, if it has to sit for a bit in cold weather, and also, not run it for a short time in extreme cold weather, shut it off, and then try to run it again at idle. Maybe I will try a work around someday for freezing temps, that I can return to normal for above freezing temps the rest of the year.
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
2024 Linx (A60462)
2024 Linx (A60462)
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
