HF manual log splitter
/ HF manual log splitter #1
buckbros
Maryland
john deere LT180, John Deere GT235, 1950 Case Vac, 2 Gravely L Models
I have a HF manual log splitter that due to my stupidity I need to replace the hyd. bottle jack. This thing has two levers, one moves the shaft at a faster speed & the other is used to do the splitting. Anyone know where I may purchase the bottle jack. HF does not have them on the shelf & if you ask the assistant they don't have a clue. I only paid about $100 for this thing and believe it or not it does work pretty good. I built a gas powered one years ago and keep that one at our cabin. I bought the HF splitter to use here where I live to split smaller stuff.
/ HF manual log splitter #2
Hi the old one can't be fixed ? I looked online no luck finding one
/ HF manual log splitter #3
Did you try ordering parts from HF as page 11 of the Manual shows all of the jack parts.
Thanks for the reply. I actually cracked the shaft that pushes against the log. I only had the ram contacting about 1/2 of it's surface on the log. It was pushing way off center of the ram. My fault completely. It still works but I don't know for how long.
I just sent an email to find out if I can order the part. We'll see what happens.
/ HF manual log splitter #6
The part is probably half the cost of a new splitter
I'm thinking that also. I may try to just get a single lever bottle jack & try to adapt it. The lever with the longer stroke
is not really that much help anyways.
Here is the reply from my email to HF. It was no surprise. I often wondered about getting repair parts from HF, now I know.
Don't know why do they even put the IPL in the owners manual.
"Thank you for contacting Harbor Freight Tools.
Unfortunately, the replacement part you豎*e requesting is not available and cannot be ordered separately from our manufacturer.
The item may be exchanged if it逞エ within the 90-day warranty by visiting the store of purchase or by contacting Customer Service department at 1-800-444-3353. We are available MondayèŽ*。aturday, 5:00am?:00pm and Sunday 6:00am?:00pm (PT).
We apologize for any inconvenience".
Michael Roberts
Product Support
/ HF manual log splitter #9
What you are describing sounds similar to the quick lift floor jacks. With no load they extend quickly until a resistance is met and then go into the slow full force lifting mode. Not sure if these can be purchased separately or the cost.
I have found quick lift bottle jacks but they do not go into the slow mode after making contact. If I could find one as you describe, that may be what I would need. I'll have to keep looking.
2001 John Deere 6210 (A60462)
2001 John Deere...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
iDrive TDS-2010H...
Kubota KX080-5 Midi Excavator w/ Hydraulic Thumb (A64047)
Kubota KX080-5...
Spray Daddy 400 Gallon 30 ft Sprayer (A64047)
Spray Daddy 400...
Case Steiger 600S Tractor (A64047)
Case Steiger 600S...
