Cold Blooded Honda
/ Cold Blooded Honda #51
Seafoam is GOOD stuff. Anytime any small motor even has a hint of roughness I run a little saefoam through it and 99% of the time that clears it all up.
/ Cold Blooded Honda #52
If running on part-choke helps, I'd do that to get the task at hand done until warmer weather hits and you can look into it further. Especially for an engine that doesn't like the cold anyway.
I have also found that with engines that have sat, that gum and varnish from old gas will sometimes redissolve a bit in newer gas, and if you can get them to run at all you can sometimes improve them by simply working them and running more fuel through them. It applies solvent (new gas) and suction (engine vacuum). Not a long term fix, but sometimes it is enough to get you through a job.
I do agree that any type of enclosure to keep engine warmed air closer to the engine will likely help, with or without moisture involved.
/ Cold Blooded Honda #53
Chevron Techron is an alternative that is usually more cost effective from what I've found
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A58214)
WHISPERWATT 220...
2021 Bobcat T66 (A60462)
2021 Bobcat T66...
