Yes, there is a pretty large bolt hanging out of the drain hole. I could not see up there, but there was something on the bolt as well.....something larger than a washer.
I just loaded her up on the trailer and took it to the dealer. I showed them the picture and they were plenty suprised as well.
No problem, just a connecting rod bolt. Keep the rpm's under 1200 and you'll be fine.![]()
They ended up having to split the tractor to get that bolt out. It was one of a few bolts that holds the rear two cases together and it did not seem to cause any other problems in there.
I got the tractor home and it is operating fine.....like it did before.
