Timber Frame Build - Round 2
/ Timber Frame Build - Round 2
4 years ago I swore I would never do this again. This was prob my least favorite job during the last build. Hoping to get all of the t&g sanded and stained this weekend for the outside porches.
All of the equipment is lined up for Monday. Two scissor lifts, forklift, telehandler, my tractor and forks, and crane on wednesday.
2018-01-04_07-53-38
/ Timber Frame Build - Round 2 #162
T-minus 10 days and the cloud should be lifted, lol. Hard to believe our install date is almost here already. Here's a couple pics of our bar top. Getting it through a 12 ft door was challenging. Also a huge difference today with our foam installed. No problems keeping things warmed up inside now. That was a lot of surface area without insulation.
20171229_123224
20171229_123057
Is that one slab? Or is it sections end to end. That looks huge. Jon
It is one slab. 32-34" wide and 18-20ft long. Can't quite remember exact length. We will probably cut down to about 15 ft I'm guessing. I'll start framing up the bar area once the timber install is finished.
/ Timber Frame Build - Round 2 #164
How do you plan to keep it from cracking? Or is it kilned dry? Jon
It is kiln dried already. Any checks that would develop along with a few of the open knot holes will get resin filled.
/ Timber Frame Build - Round 2 #166
Looking forward to the finish top. I sure enjoy these projects threads. Jon
Got the overhead door removed this evening and temporary doors up to block the opening. Ended up using some scrap lumber, scrap insulation, and shrink wrap to make a couple of 12'x 6' doors to keep the heat in. Everything is cleared out and cleaned up ready for timbers. Should arrive around 9am tomorrow morning.
2018-01-07_08-24-45
/ Timber Frame Build - Round 2 #170
That's exciting!!!! This is gonna be an interesting week!!!
/ Timber Frame Build - Round 2 #172
Thats cool. Can't wait to see it.
The crew made some great progress today. Both lower wings are complete. Tomorrow is going to be interesting watching how they do the vaulted ceiling. Because to they have a roof overhead and no crane to lift with they designed the frame different then normal. Usually they would build the center section as a bent and raise the entire section at once. Weather was also great today. Topped out at 50 degrees. I picked up my post plates and risers today and was able to do my painting outside. We had a low of -14 just 8 days ago.
DSC_6796
DSC_6789
DSC_6780
DSC_6787
/ Timber Frame Build - Round 2 #174
Since it's all decorative and not supporting any load, why did you go with posts?
Are you talking about the interior posts that sit in the middle of the floor? If so they are supportive of the vaulted ceiling. Center portion is going well so far today. They built the entire center portion on the ground then used the forklift to set.
DSC_6807
DSC_6804
DSC_6809
/ Timber Frame Build - Round 2 #176
:thumbsup: VERY COOL!!!
/ Timber Frame Build - Round 2 #177
Looking great, love it.
Last section going up then ready to start prep for tomorrows outside install.
2018-01-09_01-32-01
/ Timber Frame Build - Round 2 #180
2018-01-09_01-32-01
What are the plans for the tops of the timbers? Some kind of covering to hide building insulation? Or will lighting effects hide it? Jon
2025 TopCat ECSSSTG200 Hydraulic Stump Grinder Skid Steer Attachment (A64553)
2025 TopCat...
7002SFL (A61572)
7002SFL (A61572)
2022 EZ-GO ELITE...
EZGO (A64557)
EZGO (A64557)
2022 EZ-GO ELITE...
ELECTRIC POWER WASHER (A64278)
ELECTRIC POWER...
