high octane fuel concern
/ high octane fuel concern #21
That 100LL is wonderful stuff. Never goes stale from age . Never deteriates plastic, rubber or metal.
X2 on that. I’ve been using it for years in all my 2-stroke and small engines. No nasty odor left behind either when it evaporates. When I’m cutting wood with the chainsaw it smells just like I’m at the historic races at Watkins Glen.
/ high octane fuel concern #22
I use premium no ethanol fuel in my quads, motorcycles, and all small engines. I have for years with no problem. I just hate ethanol.
I run 100LL in my airplane.
/ high octane fuel concern #23
The problem is ......
NO ETHANOL automotive fuel (premium or otherwise) is BANNED in some states!
THAT is when 100LL becomes the BEST option for no ethanol!
/ high octane fuel concern #24
Heh heh... technically true. Folks just assume that higher octane means better, cleaner, faster... I mean... it costs more so it HAS to be better, right? ;-)
Back in the late 80's I bought a new JD 175 Hydro that was miserable to start right from new. I contacted the dealer and their recommendation was to make sure I was running "Hi Test Gas". Ahhh... right. It turns out the choke rod was misadjusted and the engine was only getting half choke.
Around here all grades of gasoline have the same Ethanol content. I run non-Ethanol in all my small engines but unfortunately the only grade available is 91-octane so that's what I use. It costs around $0.50 more per gallon than Ethanol-laced Premium.
Not necessarily true. Detonation, while usually unwanted, has little to do with ease of deflagration (ordinary burning). A liquid can be difficult to light on fire, but easily detonate, and vice-versa. It is noted that many high-octane fuels contain less energy per mass, but the difference is trivial.
/ high octane fuel concern #25
I was told by a small engine mechanic that if I store gasoline I should use premium and a fuel stabilizer. He explained the reason for premium is that the octane rating degrades over time and if it gets to low, the engine won't run on it. I store gas for 1 year +/-.
/ high octane fuel concern #26
Just wondering if high octane fuel (91 and 94 octane) will damage the 2 and 4 cycle motors. We live in a cold climate and was suggested to run high octane fuel in the winter so the motors will start easier.
The octane issue is misleading and not the reason for the advice to use high octane in small engines.
The addition of ethanol to gasoline is very hard on older small engine carb and fuel system parts. Automobile fuel systems had to be redeigned with materials that would not breaak down when in the presence of ethanol.
Sometimes, high octane fuel has less or no ethanol.
The addition of ethanol is often legally binding on producers and the pumps will say "may contain up to 10% ethanol."
Aircraft engines, like small engines, are high performance designs particularly 2 stroke outboard motors.
Here is the advice in the aviation community:
Never burn fuel that contains ethanol in your airplane. Learn how to test for ethanol in fuel, what to do when you can't find ethanol free gasoline, and the damage ethanol can cause to your aircraft.
Testers to allow you to see the % of ethanol are cheap and there are many do it yourself videos on youtube.
Ethanol test kit for percentage of ethanol in gasoline | eBay
There are gasoline additives specifically designed to stop ethanol damage in small engines.
Dave M7040
/ high octane fuel concern #27
I can't get gasoline without ethanol in it where I live. I've been using either Torco 100UL or VP Fuels T4 in my chainsaws, trimmer, and lawn tractor for years. Both fuels are 100 octane. While the canned fuels are expensive, it's a lot cheaper to run expensive fuel than have engine problems from ethanol. After rebuilding more than one carburetor from ethanol gas gumming up, my time associated with cleaning fuel systems and frustration with power equipment not working properly make the additional cost worth the money.
/ high octane fuel concern #28
Swines
The small engine repair shops in my cold Canadian area recommended this additive to prevent ethanol problems.
Star brite Star Tron Enzyme Fuel Treatment - Concentrated Gas Formula
Star brite Star Tron Enzyme Fuel Treatment - Concentrated Gas Formula | FortNine Canada
My advice to friends and family is to use this additive at the start of a piece of equipment's operating season and then as the season ends to switched to the "canned" fuel so the engine has this on board when idle and when starting the season.
If you get one of the methanol testers I suggested in a previous post, you will find as I did that sometimes the high octane fuel which has been ethanol free suddenly has ethanol in it.
Dave M7040
/ high octane fuel concern #29
Swines
I started trying out ethanol fuel additives in 1999. I've tried about every additive for ethanol fuel, including the Star Tron additive, and for my use, none of them work to my satisfaction. In 2007, I finally decided to make my life simpler and changed to the Torco / VP fuels. They work and I don't have to fiddle around with running the equipment out of fuel, refueling with a canned fuel, running the equipment to circulate the new fuel, etc. etc. I have eight different pieces of equipment and I prefer to make my life easier by simply using high grade fuel all of the time.
However, I'm sure other people will appreciate your information on the Star Tron additive, and wouldn't mind the additional time and work involved with using the type of fuel regimen you've described.
For the "use aviation gas" people - the local fixed base operator (FBO) will not dispense av gas into a container to take it off of the airport. The reasons are more complicated than it's worth going into on this forum, but I understand the policy and why they don't want to sell gas "retail." It's their business and their policy and I'm not going to argue with them about it.
/ high octane fuel concern #30
I have been repairing small engines as a hobby for about the last 20 years. Sometimes I get an engine with the carb so full of crap, that I have to actually scrape it out of the bowl. When the customer comes back for his machine, I ask if he has been using a additive in his fuel. 99% of the time, the answer is yes.
I see no useful purpose of the additives. As far as I can tell, it does not have any beneficial effect. But I do know that they do a great job of gumming up carbs.
/ high octane fuel concern #31
Using 100LL, the whole violation of federal law thing aside, is too expensive. By the way, it's not tested the same way as auto gas, (the r+m/2 method), so it's not really 100 octane either, at $6 a gallon. Which as stated, doesn't increase performance in lower compression engines anyway.
Ideally, you find boat gas, (which is ethanol free). And half the cost.
Though I never did it, I do know several people who use auto gas in their airplanes, and they all have for many hours, over a very long time. None of them have ever had any issues.
They also don't ever have lead fouled spark plugs.
/ high octane fuel concern #32
The only decent gas station around here (Shell) sells premium gas and advertises that is has NO ethanol. This I used to buy for the Jeep AND all the small engines. Now I run the Jeep on regular gas and the small engines on the 0% ethanol Premium gas.
The last tank of fuel I put into the Jeep before I park it for the summer (while I am at work I don't use it) will be premium as I will have it parked for about 5-6 months.
/ high octane fuel concern #33
For all the gasoline the small engines use , who cares if it is another $10-$50 a season. The idea behind 100LL that while it has more octane than most applications require . 100LL is readily accessible , contains no ethanol and does not gum up or corrode fuel systems .
/ high octane fuel concern #34
Between toe mower, atv, saws, weed eater, logsplitter, pressure washer, etc.....I probably burn 100-150 gallon a year.
Alot more than $10 a year difference
/ high octane fuel concern #35
That's fine, if you use 5 gallons a year.
I am well aware of the qualities of 100LL. I've bought thousands of gallons of it.
/ high octane fuel concern #36
We use 20-25 gallons of gasoline per month primarily for John Deere Z820A Zero Turn, Polaris Ranger, 3 pressure washers and assorted 2 cycle chain saws, trimmers, blower, etc. Corvette only gets 100-200 miles per year.
Two tractors are diesel and we have 300 gallon bulk tank. I do not want to store bulk gasoline because of the ethanol contamination.
I never have gas more than a few weeks old. I started treating all gasoline with Stabil Marine 360 a little over 3 years ago. Problems with carbs, fuel lines, etc. on 2-stroke equipment are completely gone. Everything starts easy, usually one pull. The Swisher walk behind line trimmer, that was a hard start from new, now starts easily even after a few months of non use.
BTW, I buy only 87 octane, except for the Corvette.
/ high octane fuel concern #37
I am starting to take a serious look at running some of my 4 strokes on propane.
I already have a permanently installed 22 kw Generac and being able to stoke the fuel forever sure makes things easier.
The snorkel conversion kits look quite easy to install and use.
When I have a few bucks after Christmas, I am going to try the conversion on two portable generators.
Dave
/ high octane fuel concern #38
I am going to try the conversion on two portable generators. Dave
I considered that, but the kit maker said there would be a power loss.
I'm pushing my 5500 watt generator to the limit on gasoline.
/ high octane fuel concern #39
EXACTLY CORRECT !!!
I have a gas TLB, a gas 8N, two gas riding mowers, and a bunch of small gas engines.
My TLB uses the most gas of the bunch, and probably uses 25 gallons per year.
All other machines combined, likely use another 15 gallons.
40 gallons, total each year, completely avoiding ethanol gas damage & storage issues.
100LL works for me !!!
If plugs ever should get lead fouled, I can clean, or replace them.
Non ethanol automotive gas is not available within 50 miles.
/ high octane fuel concern #40
I would pay the difference just to prevent production loss and repair costs caused by ethanol fuel.
1/2" Quick Attach Blank Plate (A66408)
1/2" Quick Attach...
2026 Electric Tricycle (A64194)
2026 Electric...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A64553)
2025 Mower King...
2020 Elgin Pelican Street Sweeper (A64194)
2020 Elgin Pelican...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
2010 International 4300 2,000 Gallon Water Truck (A64194)
2010 International...
