Will this valve work for Rear remotes
/ Will this valve work for Rear remotes #1
davisgary2
Salisbury, nh
Kubota L3560HSTC
I have a Kubota L 3560HSTC. Rear remotes are in my future how soon not sure. I found this valve which looks like it would add 4 remotes.
Hydraulic Monoblock Solenoid Control Valve, 4 Spool, 13 GPM, 12V DC
I have the rear hydraulics for the backhoe which has to be looped back in when the backhoe is not connected. Could I run that line through this valve and end up with four rear remotes. Remotes would be used for TNT. possibly angle on scraper blade etc.
Any thoughts would be appreciated.
/ Will this valve work for Rear remotes #2
That should work as long as your tractor has a flow of less than 13gpm.
Note that per the description, the 4th valve is setup as a motor spool valve.
As such when the valve is "off" the two ports are connected together. It should not be used for a cylinder that you want to have stay put.
It is designed be used for a motor so that when you shut it off, it can slowly spin down (rather than slamming to a stop).
Aaron Z
/ Will this valve work for Rear remotes #3
NO.
Two reasons.....
First.....A and B ports are open to tank when in neutral. (typical open center valve). What you want is technically called a tandem center valve.....where A and B are isolated when in neutral.
Opening a and B to tank when in neutral wont hold a cylinder in position when not on the lever. So you could use the valve to raise the wheels of a transport implement.....but as soon as you let off the valve.....the gravity would lower the implement back down. Same thing with a Top N tilt. No load holding at all.
Second reason.....No power beyond option. Which is typically of solenoid type valves. They normally use a high pressure rated tank port to feed downstream. Usually with remotes the 3PH is still fed AFT the remotes. Usually Via power beyond with a manual valve. Given the tank port on that valve is only rated for 725psi.....that would be a no go for feeding the 3PH.
And third (I know I only said 2 reasons).....I wouldnt want a solenoid valve for remotes. Because there is NO feathering. The valve is either on or off. So making minor adjustments to a top N tilt, or hydraulic rippers on a box blade, or whatever.......forget it
/ Will this valve work for Rear remotes #4
The way I read the spec. I took it the D port work ports are open to tank? Power Beyond (conversion plug required.} But Where would you put that many switches on a joy stick to give you control over each one? I would just put in a 4 spool valve and set up the way you want it.
/ Will this valve work for Rear remotes #5
Probably wouldn't use a joy stick to mount the switches for remotes, would you? Just asking.
/ Will this valve work for Rear remotes #6
If asking me I would not.
/ Will this valve work for Rear remotes #7
As I read the description, valves A, B & C are normal, its only valve D that is a motor spool valve.
Also, per the description, it is power beyond capable with an adapter.
Aaron Z
/ Will this valve work for Rear remotes #8
I overlooked the power beyond. So disregard that part of my previous post.
But the fact still remains that its a true open center and not a tandem center. At least thats how I read it.
I'd call and get more clarification from the MFG or seller.
Because in once sentence it says spood D is motor spool used for non-load holding situations like motors or horizontal cylinders.
But the next sentence leads me to believe that ALL spools are that way.
Id want clarification before shelling out $500+
IF spools 1-3 are indeed tandem center.....then yes the valve will work.
But personally.....I would want a manual valve for control (feathering ability)
/ Will this valve work for Rear remotes #9
2 Volt DC Solenoids
Probably should read "12 volt"?
Thanks for all the replies. I will send them an e-mail and try to get more information.
As far as switches my thought would be to have a little switch panel where the factory remotes would go not on the joystick.
The remotes would work similar to my third function remote. I agree with LD1 that it would be harder to feather, but my third function seems to work OK for my snowplow and for about $3000. less than factory remotes might be doable.
I will send then a message now and see what their response is.
Thanks again for the input.
7002SFL (A61572)
7002SFL (A61572)
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
2008 Peterbilt 379 Semitruck (A64047)
2008 Peterbilt 379...
2019 VOLVO VNL TANDEM AXLE SLEEPER (A59911)
2019 VOLVO VNL...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
