Chain oil
/ Chain oil #1
dodge man
Super Star Member
West central Illinois
JD 2025R
Can you use motor oil for bar and chain oil? I have got some leftover oil sae 30 and 10w-30 that is new oil but has been sitting around a few years. Ok or a bad idea?
/ Chain oil #2
Bad idea. Bar oil is thicker and has additive in it to help it cling to chain. Put your left over oil in a oil can instead
/ Chain oil #3
Are we talking about a couple of liters or some pails ?
A few thankful is allright although regular bar oil is preferable because it sticks to the bar better
/ Chain oil #4
I don't think it'll hurt anything, especially if you mix it 50/50 with some bar oil. Personally, I don't like the smell of motor oil, so I wouldn't use, but I wouldn't worry about it causing any problems. Now used motor oil on the other hand is something I wouldn't even consider. I've met people that use it exclusively, but it really makes a mess of saws!
/ Chain oil #5
I have used it in the past, it doesn't work that well. Like they said, bar oil has some snot like properties that make it work well. I use the Wal mart kind. It doesn't work as well as good kind, but it works better than motor oil.
/ Chain oil #6
I usually use the $8 a gallon bar oil at tractor supply that goes on sale for $6 a gallon. I've used hydraulic oil in a pinch. Bar oil is obviously better, but I don't think occasionally running a tank full of whatever new oil you have laying around is going to hurt anything.
/ Chain oil
I have about three quarts of oil laying around I want to get rid of. I have a conainer that is about a pint in size that a dump out of a gallon jug and use to fill the saw. I blended maybe 20% motor oil with bar oil and thought maybe it was a huge mistake. I did some reading on the internet and got some conflicting data. It doesn’t sound like a big deal. Thanks for the responses, I often trust this web site for answers more than other random web sites.
/ Chain oil #9
Bar oil has "tackifiers" that help it do the intended job, just like oils you'd use on various machinery where you want the oil to stick to a surface. Motor oil doesn't. I know a guy who used uses motor oil in his saws on occasion, because he's cheap and can't bear to not use/reuse/hoard materials, and even he says it's not nearly as good.
/ Chain oil #10
Mix it in with bar oil IMHO. Summer weight is 30wt and winter weight is 10wt. Yes it can be used up. JMO
/ Chain oil #11
What you did is probably the best way to use the engine oil as bar oil. At 20% you may notice it but not alot.
/ Chain oil #12
I can speak as a man who used BAR OIL by the fifty gallon drums and ran chainsaws for a living year in and year out. As a professional faller and bucker I would pour a gallon to a gallon and half of saw gas through a chain saw in a six hour period. Using used motor oil is a rotten idea even though some one else will say they use it. BAR OIL is made to minimize wear on the bar and chain at the same time. Have I cut the BAR OIL with gasoline, diesel, kerosene, in the bitter cold? answer is yes. Have I used regular motor oil of every configuration and hydraulic oil in a pinch? yes. Used motor oil, the risks of screwing up your oiler assembly and or filter make for me, the use of used motor oil a foolish option. Loving your saw as your work partner means you feed it right.
/ Chain oil #13
Well said^^^^. I use the orange jug Stihl bar oil, I think at $12/gallon. Not worth fussing over at a few gallons a year at my rate. I will not use the green Stihl bio oil again, too thin, the oil runs out before the gas if you are not careful and it seems to smell up the saw. I started using it since I live on the salt water but I do not cut much here anymore, most cutting is in my timber land. So I went back to the orange tacky stuff jug.
/ Chain oil #15
He is not using USED motor oil he is mixing NEW motor oil in. :2cents:
I agree on the used motor oil deal though. Nasty to work on saws running it. Then I smile as I price them for labor and parts to replace their oil pumps. ;)
/ Chain oil #16
New motor oil has additives in it.
Using use/new motor oil for fuel will put the additives in the air"
/ Chain oil #18
Ok, i think i get it. If putting those additives in the soil is bad, then burning it will put it in the air. That might be bad for you and other people or just maybe it would be good for you, in the aerosol form as it will be able to better penetrate deeper into the lungs, someone needs to do a study. I know sitting behind a vehicle that burns oil is unpleasant.
/ Chain oil #19
Motor oils are just that, for motors,---NOT chainsaw oil.---Depending on what you think of your saw, and the wrong oil damage cost later on, --I would never use it in any of my 29 running saws!
Use the oil in your squirt can to oil stuff with. thanks; sonny 580
/ Chain oil #20
Back in about 2010 or 2012 Baileys had a "by the case" sale of their bar oil. It was inexpensive ($6?) and good. I bought 8 gallons. I've still a few left.
BUT the name of the product is "Motion Lotion" and I faced some questions when wifey saw the bill and the name.
2020 GMC AT4 CREW CAB TRUCK (A64280)
2020 GMC AT4 CREW...
Club Car Electric Golf Cart (A66285)
Club Car Electric...
Landhonor FW-13-15000G, Skidsteer Mount Winch  (A62679)
Landhonor...
1062 (A63291)
1062 (A63291)
2015 PETERBILT 579 TRI/A DUMP TRUCK (A59914)
2015 PETERBILT 579...
2019 Volvo VNR64T T/A Sleeper Cab Truck Tractor (A61573)
2019 Volvo VNR64T...
