Dec 27, 2017 / Same 80 Explorer Transmission Fluid Top Up #1 P pjpnzl New member Joined Dec 27, 2017 Messages 3 Location New zealand Tractor Same 80 Explorer Where on a Same Explorer 80 do I fill up the transmission fluid? Thank you.
Dec 27, 2017 / Same 80 Explorer Transmission Fluid Top Up #2 rdbigfarmboy Gold Member Joined Jan 7, 2005 Messages 429 Location Collinwood, TN Tractor MF, Same,Zetor Fill pug on top at rear 3 pt hitch, lift and transmission are one system
Dec 28, 2017 / Same 80 Explorer Transmission Fluid Top Up #3 Sawyer Rob Super Member Joined Dec 5, 2014 Messages 9,312 Location Upper Mid West Tractor several brands I believe you have to have the 3 point all the way down, for proper fill level check. SR
Dec 28, 2017 / Same 80 Explorer Transmission Fluid Top Up Thread Starter #4 OP P pjpnzl New member Joined Dec 27, 2017 Messages 3 Location New zealand Tractor Same 80 Explorer rdbigfarmboy said: Fill pug on top at rear 3 pt hitch, lift and transmission are one system Click to expand... Thank you. Hard place to get to on my Same. Behind all the hydraulic connections etc!
Dec 28, 2017 / Same 80 Explorer Transmission Fluid Top Up Thread Starter #5 OP P pjpnzl New member Joined Dec 27, 2017 Messages 3 Location New zealand Tractor Same 80 Explorer Sawyer Rob said: I believe you have to have the 3 point all the way down, for proper fill level check. SR Click to expand... Thank you.
Jan 15, 2018 / Same 80 Explorer Transmission Fluid Top Up #6 banjodunn Veteran Member Joined Jun 25, 2008 Messages 1,479 Location Ararat Vic Aus G'day if you talk to your local dealer they should be able to supply you with an owners manual Jon
