2013 John Deere 5065E electrical problem
/ 2013 John Deere 5065E electrical problem #1
tlmurray930
Jacksonville, tx
john deere 5065E
I started my 5065e a few days ago and it ran for about 30 seconds, then died. Would not make a sound when I tried to restart NOR did it have any lights. Everything is dead including starter and all lights and gauges. I removed battery and had it tested by 3 different shops and they all said battery good just needed charging which I did. Put back on tractor still no starter, no lights or gauges. Re-cleaned battery terminals, checked all fuses, checked fuseable link, still nothing, starter will not turn over, no lights or gauges. Tractor only has 350 hours. Any thoughts or ideas will be appreciated.
/ 2013 John Deere 5065E electrical problem #2
Are you getting power to starter? Start checking wires from battery. Start small and don’t over think it. Just inspect everything good. Check all fuses good. Like with a multimeter ohm them out.
/ 2013 John Deere 5065E electrical problem #3
Did you check ground to frame?
I visually inspected fuses, they were all good. I used a check light on fuseable link and it did light up.
Have not checked ground to frame yet, but I will tomorrow
/ 2013 John Deere 5065E electrical problem #6
power at starter solenoid ? on battery cable
Please explain checking fuses with multimeter
It is so strange that NO lights will work if power goes through fuseable link.
/ 2013 John Deere 5065E electrical problem #11
DITTO on checking ground to frame plus other 3 battery cable connections. PS: battery cable can look good but be corroded inside of insulation.
HEY Tx Jim: Please remind me what and where the other 3 connections that you mentioned are. Thanks
/ 2013 John Deere 5065E electrical problem #13
ground at battery, ground at frame, pos at battery, pos at starter, ground on wire harness all the wires from the dash usually connect at one spot, pto off, seat switch good
Ground at battery and frame good. Pos at battery good. Pos at starter, ??? . Ground on wire harness, can't locate. Further help will be appreciated Tx Jim and Peter 315
/ 2013 John Deere 5065E electrical problem #16
Follow pos to starter and see if you have voltage. The ground from harness are usually a few white wire all bolted to either the block or the frame. I can find the exact spot tomorrow.
/ 2013 John Deere 5065E electrical problem #17
Did you get power to the dash lights or head lights? check the fuse box for power
/ 2013 John Deere 5065E electrical problem #18
View photo & note green arrows. Red arrow is a fusible link.
/ 2013 John Deere 5065E electrical problem #19
I’ve replaced that fuse many times. Easily looked over
/ 2013 John Deere 5065E electrical problem #20
250 Gallon Diesel Fuel Tank w/ Pump (A64047)
250 Gallon Diesel...
2025 PJ CC162 T/A 16FT EQUIPMENT TRAILER (A59912)
2025 PJ CC162 T/A...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
2019 JOHN DEERE 333G SKID STEER (A64279)
2019 JOHN DEERE...
Asphalt Melter (A61572)
Asphalt Melter...
2023 MANITECH MTECH-2.0T TELESCOPIC WHEEL LOADER (A64279)
2023 MANITECH...
