Early Christmas present
/ Early Christmas present #1
orezok
Super Member
Mojave Desert, CA
Kubota B7800
Sometime last night, my furnace stopped working. Now heating with fireplace and portable electric heaters. :mad:
I swear I wasn’t naughty!
/ Early Christmas present #2
That's how my luck usually rolls.
/ Early Christmas present #3
Sorry to hear that. What kind of furnace do you have in the Mojave Desert? Here in East Texas, 100% of my heating is done by wood stove.
/ Early Christmas present #4
I must be on the list also but further down,6" snow and still falling so will the temps single numbers tonight below zero rest of the week. :(
The kind of furnace you need when temperatures get down to as low as 12 degrees outside! Fortunately only 39 last night.
This isn’t my first experience. About 15 years ago on Thanksgiving day, the SWIMBO goes to put the turkey in the oven. Oven won’t heat. Dead! Transfers turkey to a large combo convection microwave we had. About 20 minutes later that quits. Ended up finishing the turkey in the RV.
/ Early Christmas present #7
Very few people realize that a Desert environment is very cold at night. :)
/ Early Christmas present #8
The relay that turns on our furnace failed on a Saturday afternoon. If we hit it with a screwdriver it would latch, but wouldn稚 work once it shut off again. Dealer couldn稚 get the replacement on a weekend.
So we had a dance for the next couple days. After house would cool to 62-66ー we would manually activate it with the thermostat set to 72ー. We had a couple of auxiliary heaters so we didn稚 have to reset for 6-12 hours.
Ours was an electromechanical unit. New ones are solid state.
/ Early Christmas present #9
Q- can we come over to your place (eat your food, watch your tv and make a mess in your place and then leave)
A- sorry my heater is out- we will be over to your place in a few min though!
Frigging genius!!!!!
/ Early Christmas present #10
As they say, the first guy doesn't have a chance. In the last two weeks: Computer died, $500 and counting. Furnace quit, $800. Hot water heater quit, $400 fix, new heater soon, price to be determined. Knock on wood.
OP here. Dodged a bullet. The furnace is a horizontal model mounted in the attic. Climbed up there and wiggled all the wires on the mother board. Also checked the door switch on the blower section as once before the door came loose and cut the power to the unit. I had put a screw in the door to hold it tight after that episode. I don't know which fixed it, but I put the door back on, tightened the screw and all is well again. :cool2::dance1:
/ Early Christmas present #12
A fine example of the KISS principle. Glad everything worked out for you!!!!
/ Early Christmas present #14
Yep, very dry air can easily do that!! I've saw snow flakes in Iraq. :(
2021 Gehl RT215 Track Loader with 74in Smooth Bucket (A61307)
2021 Gehl RT215...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1986 MURRAY WEST COAST STYLE RGN (A60736)
1986 MURRAY WEST...
2020 Chevrolet Silverado 5500HD Dump Truck, VIN # 1HTKHPVK0LH288017 (A61165)
2020 Chevrolet...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
