Aftermarket source for Tie rod Boot MX5100 ?
   / Aftermarket source for Tie rod Boot MX5100 ? #11
Well LD1, I replaced one of mine today ,and screwed up the boot on the tie rod it's self trying to get broke loose.
I'm not buying a new tie rod end until I have to. About 82.00 for that bad boy
I don't pop that joint apart.
Just unthread it where you adjust toe and slip new boot over. No need to pop that 90 degrees joint out of the spindle, and no risk of damaging
   / Aftermarket source for Tie rod Boot MX5100 ? #13
Good to know for next time. I didn't know the end would turn
   / Aftermarket source for Tie rod Boot MX5100 ? #14
..... Would be nice to find something like a $5 napa boot that will work. Or better yet....a tougher urethane boot from some source......
Actually Napa Auto Parts does have a "universal" tie-rod boot kit that comes with two different size thick rubber boots which you can easily cut shorter if needed.
So does Rock Auto:
More Information for DORMAN 13567
$2.85
:wink:
So does Rock Auto:
$2.85
:wink:
No provision for snaprings. These boots seal on each end with a snapring.
   / Aftermarket source for Tie rod Boot MX5100 ? #16
Just a thought for ya - On ATV's we use stainless steel zip ties to seal boots fairly frequently. If you pull them tight with pliers they latch down rather well.
   / Aftermarket source for Tie rod Boot MX5100 ? #17
Hey, if you want one with snap ring grooves which accepts a Kubota snaprings at both ends, you may want to stick with OEM boots.
Don't have to be exact Oem snap rings. But does have to have snaprings.
Automotive style...90degree joints.....the boot is contained on both ends but no need for rings.
This is an inline joint.
Lots have linked nice urethane joints exactly like I want.....just can't find any 17mm x 43mm
2016 Volvo Semi (A59814)
2016 Volvo Semi...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2001 Chevrolet Suburban SUV (A59231)
2001 Chevrolet...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
UNUSED FUTURE FT-RP72 - 72" HYD ROCK CRUSHER (A52706)
UNUSED FUTURE...
