How to keep #pt from floating up?
/ How to keep #pt from floating up? #1
Willy Wonka
Member
Douglas, MA
New Holland/2120
I have a draw bar on the lower portion of my 3 point but nothing is attached the top 3pt. Long story short... When I towing a trailer around and it doesn't have enough weight on the tongue the trailer will pop up. this makes backing up almost impossible. Is there way to tow something around with the 3 point and not have this issue?
Thanks in advance!
/ How to keep #pt from floating up? #2
Use the draw bar instead of the three point or chain the three point down
to the draw bar in the center(rear) of the tractor;just don't forget it's chained
down.
So basically the only option is to have a fixed stabilizer that will not allow me to move it up and down?
/ How to keep #pt from floating up? #5
...........or chain the three point down
down.
Us a Clevis or such on the drawbar to make it say to attach chain to it if needed. Works great and is fast and easy.
/ How to keep #pt from floating up? #6
Yes since most 3 PH do not have down pressure capability the arms will float up if a load it trying to lift the arms.
/ How to keep #pt from floating up? #7
Willy Wonka - basically what you are saying in post #4 is correct. The lower arms on your three point hitch system, with the drawbar attached to the lower arms, can not be forced down hydraulically - they are designed to lift hydraulically. If your trailer is loaded to the rear of the trailer - tongue light - then the tongue will lift the drawbar.
The solution - as per nybirdman - use your standard drawbar or chain your crossarm drawbar down OR load your trailer towards the front so it will be "tongue heavy" and hold your cross arm drawbar down.
Personally I do not like the idea of chaining your cross arm drawbar down - - too easy to forget and cause damage by lifting with your 3-point lower arms before you un-chain.
/ How to keep #pt from floating up? #8
I just use the tractor draw bar with trailer ball 1221171506-00.jpg1221171507-00.jpg
/ How to keep #pt from floating up? #9
Before backing up if you lower the 3ph it reduces the chance of it raising I bring loads of logs down the mt. on my trailer and that's what I do so it won't raise.
Thank you all for the help!!!
/ How to keep #pt from floating up? #12
/ How to keep #pt from floating up? #13
I don't see how that would stop the three point from raising if the load was rear heavy.
Well as long as you added more weight than there was negative tongue weight it would keep it down. I am assuming his trailers are loaded in a manner where if unhitched the tongue doesn't pop up in the air. They are likely near balanced or have very little tongue weight. The added weight on the 3pt to trailer ball mount would counter act this and keep it down. Now go set a pallet of concrete on the tail end of the trailer and no it won't help but a trailer shouldn't be loaded that way to begin with.
Most trailers have more length in front of the axle than behind. This gives whatever weight you add on the front a mechanical advantage (leverage) to overcome any weight on the back.
Think of a ballast box with a hitch on it. The trailer would not lift it up unless there was some serious negative tongue weight.
/ How to keep #pt from floating up? #14
Doesn't answer the OP's question or issue directly, but:
Since I always want weight on my 3ph for good balance against the FEL and not have to install and take off implements all the time - especially just to move a trailer - I add 2" receiver tubes to my 3ph implements, specifically my BB. My BB is pretty much my default 3ph implement; it's fairly compact and weighs over 1100 lbs.
Once I figure out how to add a 2" receiver tube to my 8' EA ED grader blade, I'll really be in business.
/ How to keep #pt from floating up? #15
/ How to keep #pt from floating up? #16
There used to be a kit for the N series Ford tractors which didn't have drawbars. It was a chain to keep the three point drawbar down (I don't recall what it hooked onto) and ALSO a chain that prevented you from lifting the three point control. If you chain the three point down, somehow preventing yourself from lifting it accidentally seems pretty important.
/ How to keep #pt from floating up? #17
Here's a view from a set-up similar to what we have for our 8N (before we bought the swinging drawbar kit)
The bars that go from the inside of the lift arm up to the 3pt top link are what keeps the lift arms from rising.
The black piece in the bottom corner is used to keep the draw bar from rotating - needed if you're using a ball type hitch.
/ How to keep #pt from floating up? #18
How much towing around do you really do? Perhaps just a clamp on receiver on the loader bucket (if you have a loader and bucket)?
I towed around a bit using a 3pt setup on my B7800. Didn't like it. But didn't have much towing to do and I pretty much refrained from towing until I got my NX5510, and now I'm convinced that towing via drawbar is the only way to tow: I've been towing in excess of 11k lbs, something that I'd never consider with a 3pt setup.
/ How to keep #pt from floating up? #19
I use my 3pt to tow with all the time, being able to back up to a trailer (see it easily) lift up the 3pt and I've got the trailer hooked without getting off the seat. Granted I'll only move around with the trailer like that short distances if I'm relocating something that's in the way etc. For safety if I'm towing a trailer down the road I go with the drawbar. Much more solid a tow point, no chance of it raising of course, it's where the tractor is designed to pull from.
Both methods have their place, depending on the situation one is more convenient then the other.
E.
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
20in Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A61572)
20in Single...
2001 Ford E-450 Super Duty 14ft. Box Truck (A61573)
2001 Ford E-450...
2017 Jeep Patriot 4x4 SUV (A61574)
2017 Jeep Patriot...
2012 Allmand Bros. Maxi-Lite SHO-HD Light Tower 20KW (A63689)
2012 Allmand Bros...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
