Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #3,901
Added a hydraulic toplink to my box scraper to lift the front edge to skim over gravel driveways without tearing but smoothing for a starter base, worked great on this first snow fall of 7?
   / Pictures of your snow weapons #3,902
Hard to beat a hyd. top arm for most any 3 ph attachments. Yours is more proof of that.
   / Pictures of your snow weapons #3,903
I am wishing it will work as good when I install the snow blower too.
   / Pictures of your snow weapons #3,904
I do the same thing with my box blade. Using the rear blade as a “gauge” works really well. I love the smooth finish it gives with no tire tracks behind!
I go back and forth between using my rear blade and box blade for snows. It usually depends on what’s already on the back, and how much snow is on the ground.
   / Pictures of your snow weapons #3,905
Finally got around to getting a pipe on my blade for plowing. The hope is that I don't move so much gravel when I plow snow. I had it made at a local welding shop. They suggested putting the bolts on each end to pinch the pipe and help hold it in place. It also has two short lengths of chain welded on the pipe to chain it to the top of the blade. Just got it back today so I haven't used it. Looks like snow tonight and the next few days so I'll see how it works on the gravel.
That looks great!
   / Pictures of your snow weapons #3,906
warmed up yesterday..then dumped 4" of snow last night. i hope it hangs around until christmas. so far its been a light snow year 20171219_082125-0.jpg 20171219_082139-0.jpg
   / Pictures of your snow weapons #3,907
And the pics of your snow weapons are ?? We'd like to see them along with the nice scenery.
   / Pictures of your snow weapons #3,908
this is my 2012 JD 5093e. up front is a 9-2' Boss DXT, and the blower is a Normand inverted 92''. Hope you guys like it. MattIMG_3506.JPG
   / Pictures of your snow weapons #3,910
Weve gotten 14”of snow today, and its still falling.
I plowed for 6 hours today, will be doing again tomorrow morning.
   / Pictures of your snow weapons #3,912
Beautiful setup Matt. May I ask what the plow is worth.
the plow cost about $5000. i have it wired like it would be on a truck so if i need to i can take it off the tractor and put it on the truck. I like how this is set up because any tight driveways i use the blower, for the long ones I go much faster using the plow.
   / Pictures of your snow weapons #3,913
Nice, I think I see only two hydraulic lines going to the plow. It must have two cylinders, how is that set up? Are they single acting cylinders, on my plow, I have one cylinder, double acting, could i use the same setup on this plow?
   / Pictures of your snow weapons #3,914
this is my 2012 JD 5093e. up front is a 9-2' Boss DXT, and the blower is a Normand inverted 92''. Hope you guys like it. MattView attachment 532683
That is an incredible setup! I almost bought a Normand Inverted 80" for this season. There can't be a better tool for snow removal. Please continue to post pics as the season progresses. :thumbsup:
Is this your first season?
   / Pictures of your snow weapons #3,916
the plow is power out and spring return. if you look on boss plow web site there are better pictures. Matt
   / Pictures of your snow weapons #3,917
I previously had a kubota m7040 that i ran set up the same way.. I wanted more horsepower and the 12 speed trans so i made the switch. You will not regret having an inverted blower!!
   / Pictures of your snow weapons #3,919
Weve gotten 14俳f snow today, and its still falling.
So you should have a beautiful white Christmas! Congratulations!
   / Pictures of your snow weapons #3,920
Here's mine. Kubota F2690 and a Toro 1028
KUBOTA L3410 TRACTOR (A60430)
KUBOTA L3410...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
2000 Bobcat 763 (A60462)
2000 Bobcat 763...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
2010 CATERPILLAR 345DL EXCAVATOR (A60429)
2010 CATERPILLAR...
