   / Share Pics of People Hauling or Towing Something Wrong #6,711
Hitch is a drawtite that’s on the truck now but I have a curt class 5 I’m taking off my F150, works for the F350 also so I could just change the hitches.
   / Share Pics of People Hauling or Towing Something Wrong #6,712
All this reminds me that I should remove my ADAPTER for the 2.5" receiver that I have. As much as it's annoying, I don't want it rusted in there.
   / Share Pics of People Hauling or Towing Something Wrong #6,713
When you take the hitch out do you leave the adapter in the receiver?
TBS.
   / Share Pics of People Hauling or Towing Something Wrong #6,715
Yes.
1 vehicle with a class V hitch.
Many hitches @ class IV.
My class 5 is 2in, made by curt. In order to get a ball mount rated the same I had to buy one that’s solid metal lol, it’s rated at 16k though, same with the ball.
   / Share Pics of People Hauling or Towing Something Wrong #6,716
I got mine out by chaining it to a tree with my truck on a small hill. I put chocks a couple inches from the front of my wheels and then used the BFH on the bar, hitting it side to side and top/bottom. I had to move the chocks as it starting sliding out but the weight of the truck did the job eventually. It fought the whole way out. Come-along would do the same. I used a needle scaler to remove the rust from the receiver.
   / Share Pics of People Hauling or Towing Something Wrong #6,717
I want a class V that sticks out a little farther than my 2" Reese. My tailgate hits my jack.....
   / Share Pics of People Hauling or Towing Something Wrong #6,718
My sister had a 2” drop hitch in her Honda Pilot. It was rusted in I had her tie off to a tree and hit it while she put some pressure on it. AmaZing how well the **** things hold. I think I also sprayed it. It had to come out as she was pulling a uhaul Trailer and I had to flip the 2” drop to a rise so the Trailer sat level.
   / Share Pics of People Hauling or Towing Something Wrong #6,719
I’ll try keeping pressure on the truck while hitting it with hammer, I have a nice little valley (old pond) that I can use, if the truck lets loose, it won’t go anywhere.
   / Share Pics of People Hauling or Towing Something Wrong #6,720
For a rusted in hitch, I'd use an air hammer with a chisel that was ground flat, or had a pad welded to it. Dose it with penetrating fluid and apply pressure with a winch or puller and give it a few blasts. It'll take a while, just a little movement at first, and it will probably fight every mm, but it will succeed where brute force fails.
2025 TPM-16 Mini Hydraulic Excavator W/Dozer Blade (New/Unused) (A59225)
2025 TPM-16 Mini...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2015 FREIGHTLINER...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A58017)
2003 VOLVO VNL...
(1) 420/80R46 USED TIRE (A52708)
(1) 420/80R46 USED...
2016 Nissan Frontier Ext. Cab Pick-up (A56858)
2016 Nissan...
