   / Share Pics of People Hauling or Towing Something Wrong #6,711
Hitch is a drawtite that’s on the truck now but I have a curt class 5 I’m taking off my F150, works for the F350 also so I could just change the hitches.
   / Share Pics of People Hauling or Towing Something Wrong #6,712
All this reminds me that I should remove my ADAPTER for the 2.5" receiver that I have. As much as it's annoying, I don't want it rusted in there.
   / Share Pics of People Hauling or Towing Something Wrong #6,713
When you take the hitch out do you leave the adapter in the receiver?
TBS.
   / Share Pics of People Hauling or Towing Something Wrong #6,715
Yes.
1 vehicle with a class V hitch.
Many hitches @ class IV.
My class 5 is 2in, made by curt. In order to get a ball mount rated the same I had to buy one that’s solid metal lol, it’s rated at 16k though, same with the ball.
   / Share Pics of People Hauling or Towing Something Wrong #6,716
I got mine out by chaining it to a tree with my truck on a small hill. I put chocks a couple inches from the front of my wheels and then used the BFH on the bar, hitting it side to side and top/bottom. I had to move the chocks as it starting sliding out but the weight of the truck did the job eventually. It fought the whole way out. Come-along would do the same. I used a needle scaler to remove the rust from the receiver.
   / Share Pics of People Hauling or Towing Something Wrong #6,717
I want a class V that sticks out a little farther than my 2" Reese. My tailgate hits my jack.....
   / Share Pics of People Hauling or Towing Something Wrong #6,718
My sister had a 2” drop hitch in her Honda Pilot. It was rusted in I had her tie off to a tree and hit it while she put some pressure on it. AmaZing how well the **** things hold. I think I also sprayed it. It had to come out as she was pulling a uhaul Trailer and I had to flip the 2” drop to a rise so the Trailer sat level.
   / Share Pics of People Hauling or Towing Something Wrong #6,719
I’ll try keeping pressure on the truck while hitting it with hammer, I have a nice little valley (old pond) that I can use, if the truck lets loose, it won’t go anywhere.
   / Share Pics of People Hauling or Towing Something Wrong #6,720
For a rusted in hitch, I'd use an air hammer with a chisel that was ground flat, or had a pad welded to it. Dose it with penetrating fluid and apply pressure with a winch or puller and give it a few blasts. It'll take a while, just a little movement at first, and it will probably fight every mm, but it will succeed where brute force fails.
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Fleco Log Forks (A59213)
Fleco Log Forks...
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
2017 Nissan Titan (A55788)
2017 Nissan Titan...
2020 PRAT TL (A55758)
