   / Share Pics of People Hauling or Towing Something Wrong #6,691
Recent posts here remind me of about 20 years ago when I guy I know put a partially loaded oil drum in the bed of his brand new truck that had a bed liner that was slippery on the bottom. He didn't strap it down as tight as I would have and wouldn't listen to me. Anyway, in the short drive we took, all was OK until he accelerated a bit and the straps created a bit of slack. Then someone pulled in front of us and he braked suddenly and the drum accelerated forward. It puckered the back of the bed metal severely and I presume pulled the sides in a little bit.
It's hard to get that metal back in shape but he tried and it never looked right. For the few years he had that truck he never got over it. After that, every truck had a rubber bed mat in it on day one.
   / Share Pics of People Hauling or Towing Something Wrong #6,692
When those hitches rust into the receiver it's like they welded themselves together. You could try a beefy slide hammer, but I'm thinking that if you already tried hooking it to a tree and hit it with a sledge that's probably not going to do any better. At least it could develop some shock/spike load that you maybe didn't do with the tree and in the right direction compared to the sledge. Just another idea.
Rob
I tried a sledge hammer first, side to side, front and back the best I could threw the week I was soaking it with PB blaster multiple times a day, no luck.
Although I just let the sledge do the work, I didn’t try to destroy the thing.
After that failed I tugged on a tree a bit lol again not trying to break something, the thing didn’t budge a bit and I said the heck with it and put the pin back in.
I guess instead of changing ball mounts I’ll just have to get used to changing balls on this pintle set up.
   / Share Pics of People Hauling or Towing Something Wrong #6,693
Although I just let the sledge do the work, I didn稚 try to destroy the thing.
After that failed I tugged on a tree a bit lol again not trying to break something, the thing didn稚 budge a bit and I said the heck with it and put the pin back in.
I guess instead of changing ball mounts I値l just have to get used to changing balls on this pintle set up.
This is one of those really interesting problems!
Might be some better penetrating fluid to use (some folks say kerosene(?) and ATF works the best; someone recently managed to get a frozen clutch free'd up using vinegar and some force), but I think it's needing a bit more help... Perhaps jacking up (weight of vehicle) on the hitch and letting gravity work on it a bit? (obviously, one needs to account for all the safety concerns)
Not sure if you can get at the back side, but maybe an impact gun (chisel)? And use something like this:
   / Share Pics of People Hauling or Towing Something Wrong #6,694
   / Share Pics of People Hauling or Towing Something Wrong #6,695
Ah, thanks for the correction! (for sure, it couldn't smell any worse than PB Blaster :laughing:)
   / Share Pics of People Hauling or Towing Something Wrong #6,697
Fluid film worked well for me!
   / Share Pics of People Hauling or Towing Something Wrong #6,698
take the hitch off and beat it out form the back.... you may need to cut the back of the tube off to get to the inner 2" tube. we had that same inssue with a county truck bought at auction. might be cheaper to find a different hitch
   / Share Pics of People Hauling or Towing Something Wrong #6,699
+1 on Fluid Film. Best snake oil ever. I gave up on PB Blaster a long time ago when I first discovered FF.
   / Share Pics of People Hauling or Towing Something Wrong #6,700
"Slick Stuff" is a less expensive knock-off of Fluid Film.
2021 Deere 333G (A53317)
2021 Deere 333G...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A56435)
Kuhns AE10 Small...
2015 International Bucket Truck (A55973)
2015 International...
Forklift Safety Basket (A56857)
Forklift Safety...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2017 Ford Expedition (A56859)
2017 Ford...
