Kubota L35 No Forward, Reverse or Steering
/ Kubota L35 No Forward, Reverse or Steering #1
parksplace5454
Pinedale (a very small community), Arizona - Home
Kubota L35
My Kubota L35 will not go forward, or into reverse and there is no steering. Hydraulic oil level is full. Bucket and Backhoe work fine. I do notice that when I check the hydraulic oil level after running the tractor, it appears to be "foamy" (don't know if that is normal). Any thoughts on the problem would be greatly appreciated. At this point I cannot even get it onto the trailer to take it to the Kubota dealer.
/ Kubota L35 No Forward, Reverse or Steering #2
Foamy or milky like water in it , tractor kept outside
/ Kubota L35 No Forward, Reverse or Steering #4
Multiple pumps! Water in oil or cheap oil!!
/ Kubota L35 No Forward, Reverse or Steering #5
Must of fixed it, no reply back
Thanks all for the responses.
Little busy here... sorry I didn't respond sooner. Kept outside... yes. Water in oil no... just drained and refilled with new premium oil from Tractor Supply. No sign of water in drained oil.
/ Kubota L35 No Forward, Reverse or Steering #8
I'm not sure if this will help, but, years ago I had an L35 that stopped moving and it ended up being a clip or a pin (very long time ago) that failed in the transmission... I belive it was a known problem and if I remember correctly my machine was well out of warrantee and the dealer split the repair with me. Hope it's something simple for you...
Thanks very much... at this point I don't have a clue so this is definitely something to keep in mind.
/ Kubota L35 No Forward, Reverse or Steering #10
How many hours?
How long have you owned/operated it?
When did it last work OK?
It would be helpful to others to note where you are located (update your user info).
How many hours?
Good suggestions... I have updated my profile except for the hours.. will complete that tomorrow. I have owned the L35 for 10 years now. Bought it used with 700 hours on it. She has been parked for a year where she last stopped. The problem did not come on all of a sudden; got gradually worse over time. Weather seems to have something to do with it. She tended to work ok in warm weather after warming up. As the problem progressed, she will not move at all in the cold winter. Was too busy to tend to her this past summer so don't know if the warm weather phenomenon still applies. I live at 6500 feet and so it gets really cold in the winter. Best i can tell there is one pump for the transmission and steering.. those are the two functions that do not work. Loader and Backhoe work fine. Just drained and replaced the hydraulic oil with premium oil from Tractor Supply.
Thanks,
Ed
/ Kubota L35 No Forward, Reverse or Steering #12
Sounds like it could be the screen in the trans or hyd filter. Also check flow from pump and pressure.
/ Kubota L35 No Forward, Reverse or Steering #13
I tend to agree with Leejohn. Cold fluid is harder to flow and a restriction will only make this worse. A filter change is probably the lowest-hanging-fruit to go after.
/ Kubota L35 No Forward, Reverse or Steering #14
I believe the gst on the l35 gets its control hydrulics from the power steering pump, if I remeber correctly the ps pump has a common suction line with one of the implements pumps. I would start doing pressure test on the ps circuit. Sounds like either a bad pump or maybe a problem with the flow divider.
/ Kubota L35 No Forward, Reverse or Steering #16
Usually some where between the power steering pump section, steering and transmission valves their is a regulator valve for the GST pressure, but since steering is not working go upstream from there but foam would indicate a suction leak.
David
PROBLEM SOLVED! I wish to extend my sincere thanks to Tags, DieselBound, Leejohn, TMGT & David_Kb7uns for very helpful inputs. Problem turned out to be air getting into the suction line (hence the many micro air bubbles in the hydrology oil). The culprit was 3 small lengths of old hose in the suction line. When I replaced those with new hose & new hose clamps, everything turned up roses. Kubota L35 Suction Line.jpg
Thanks again and Happy New Year!
Ed
/ Kubota L35 No Forward, Reverse or Steering #18
Thank you for letting us know the "winning" fix!
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2013 FORD F250 (A60460)
2013 FORD F250...
2011 KENWORTH T370 (INOPERABLE) (A58214)
2011 KENWORTH T370...
2020 DRAGON ESP...
2024 MACK GRANITE GR46F DUMP TRUCK (A59823)
2024 MACK GRANITE...
2013 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2013 Godwin...
