kioti dk40se stuck clutch
/ kioti dk40se stuck clutch #21
My dilemma is how do I start the tractor in gear without pulling the tractor?
Sounds like you do not want to disable (jumper) the neutral safety switch. That is how I do it. No
way I would drag around the tractor to start it. Another way (which I have not done) is to raise
the rear wheels off the ground an inch with a good hyd jack and FEL up, then short the start terminal
to the battery connection on the starter. Key to ON position and in 2WD, of course.
A helper then lowers the jack (low range).
/ kioti dk40se stuck clutch #22
While it was apart I discovered a hole 1/2" or 5/8" had been drilled in the side of the bell housing at approx. nine o'clock. The hole was located so you could get a chisel or screwdriver in to release the clutch plate. I used the hole to release a stuck clutch more than one once after that.
How cool is that!
The last clutch I did was on a Kubota with dual dry clutch. It had a window to see into the bell housing,
but it was blocked off by the loader subframe.
/ kioti dk40se stuck clutch #23
Can you change between forward and reverse without the clutch? On my old GST transmission tractor you could.
/ kioti dk40se stuck clutch #24
No, the DK's are synchronized mechanical shuttle and require the clutch to forward/reverse
I put vinegar in the bell housing today around six hours. I rotated the a fly wheel three times so the vinegar would reach all surfaces of the clutch. I then started the tractor and let it run at a high rpm for around 30 min. I then jammed it in gear. It broke loose immediately. I drove it around for awhile. All is well now. Thank for all of the input. I will have to pay close attention to The throw out bearing.
/ kioti dk40se stuck clutch #27
Congrats on your success!
/ kioti dk40se stuck clutch #28
Good show! After you rinse/neutralize the bell housing I think you should park with the clutch pedal locked down until you are sure all is really dry in there.
/ kioti dk40se stuck clutch #29
Why not just lock that clutch down if you do not plan to use it the next day?
/ kioti dk40se stuck clutch #31
I'm glad this worked out for you. :drink:
/ kioti dk40se stuck clutch #32
My old 9N would stick the clutch plate to the flywheel. The first time it happened I split the tractor to fix the problem. While it was apart I discovered a hole 1/2" or 5/8" had been drilled in the side of the bell housing at approx. nine o'clock. The hole was located so you could get a chisel or screwdriver in to release the clutch plate. I used the hole to release a stuck clutch more than one once after that.
That's the way I have done it, works like a charm!
/ kioti dk40se stuck clutch #33
Awesome! Glad you got it free.
I ran the tractor for a while on Sunday. The throwout bearing does squeak a little bit. I will have to keep a close eye on it. I may still have to break that tractor in half. Thanks again for all y’all’s help Robby
2013 F150 (A62613)
2013 F150 (A62613)
2015 RAM 1500 4 X 4 CREW CAB PICK UP TRUCK (A59914)
2015 RAM 1500 4 X...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
72in. Skid Steer Bucket (A65640)
72in. Skid Steer...
Michelin Mach X BIB 710/70R42 Tires (A65640)
Michelin Mach X...
