Bolt on bucket hooks for my MT125
   / Bolt on bucket hooks for my MT125 #11
Looks great. I think I will paint mine also.
I get asked frequently about the best way to paint our hooks, even cover in the FAQ section on the website. Here is how I usually reply:
What other hardware on your tractor is painted?
   / Bolt on bucket hooks for my MT125 #12
Thanks Doofy, I appreciate that very much. Those are not mine however-just a copy made offshore.
That is sad to see, but I think anyone who compares the products carefully will notice a difference and hopefully go for the US product. Ken's hooks are a work of art with precisely cut plates and amazing welds. Can't say that about the Titan knock offs.
   / Bolt on bucket hooks for my MT125 #13
Agreed! Quality of offshore products is often lacking. Amazon is bad about duping folks in to buying foreign junk and I have already cancelled my Prime membership partly due to this fact.
I just ordered a 6-pin wiring harness to install a stereo in my 3135 and just noticed it will be here in 6 weeks and is shipping from Hong Kong. Phooey! It shipped the same day so I couldn't even cancel.
   / Bolt on bucket hooks for my MT125 #14
After slinging my generator with ratchet straps today and then watching this video I'm sold that this is a much better way. I really liked your video. Not to poke my finger at you, but a suggestion - WD40 is awesome for aluminum, but a poor cutting oil for steel. Grab a can of this if you shop at Harbor Freight 12 Oz. Thread Cutting Lubricant It is sticky and great for places you'd use a hand drill since it won't just run like an oil. There are also much better cutting oils, but for a good general purpose cutting oil I really like this and use it for steel and stainless on the lathe & mill often. Anyway, you will see that you drill steel faster and your drills stay sharp much longer with this (or other cutting oil for steel) vs WD40.
kennyd - order placed. But got the blemished since I'm a cheap ******* :)
   / Bolt on bucket hooks for my MT125 #15
"rider7767" your video covered the painting like a pro too. A quick wipe down with some BrakeClean and we're good to go. Rattle can it and it matched LS's paint job almost perfectly. Thanks again rider for following through and all the details as usual. :thumbsup:
   / Bolt on bucket hooks for my MT125 #16
Thanks for the business, we genuinely appreciate it :thumbsup:
   / Bolt on bucket hooks for my MT125 #17
Got my hooks today. If those are 'blemished' I think you are much more particular than I am - they look just fine to me :)
I got 3 hooks to go at each end and one in middle. Would it be beneficial to run a piece of 3/16" x 3" x 50" steel under the top part of bucket where these will attach? Added strength or just waste of time & material? Not welding the steel backer strip to bucket, just drilling and the 6 bolts for the hooks wold pass thru holding that strip there. The bucket seems stout enough that I don't think I could damage it trying to lift anything - I think I'd run out of lifting force before running out of bucket strength, but figured no harm in asking. <$20 of cold rolled steel so not a big deal if it would do any good.
   / Bolt on bucket hooks for my MT125 #18
I just bolted my 2 on the outer edges on the ends. I have lifted things w/chains and also straps w/o any problems, but not real heavy stuff (big, bulky, and awkward though). I agree that you would probably max out the lift capacity before you would bend the bucket. I mounted mine very close to the side end of the bucket wher the top is welded to the side. I would suspect that the center would be the weakest.
   / Bolt on bucket hooks for my MT125 #19
I was reading this thread, and it just struck me funny! You said, Sad to see. You are beating this guy up for using hooks bought from another country all the while listing 2 tractors and a UTV made with majority foreign parts. I am new hear, so I may not understand how things work. Not looking for a fight. It just struck me funny. I like his videos.
   / Bolt on bucket hooks for my MT125 #20
How is that Korean made tractor working out for you?
2007 JCB 3CX BACKHOE (A60429)
2007 JCB 3CX...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2019 Ligchine Spiderscreed Concrete Screed (A59228)
2019 Ligchine...
DEUTZ MARATHON...
VOLVO SD75B SMOOTH DRUM ROLLER (A60429)
VOLVO SD75B SMOOTH...
Freightliner Columbia (A56438)
Freightliner...
