Ag vs industrial tires
/ Ag vs industrial tires #1
coolbrze
Gold Member
VA
Kubota MX5800
Looking at purchasing a new Kubota (possibly L3901 or L4701) & not sure if I want ag or industrial tires. Tractor will be used mostly in the mountains on pretty steep grades but will also be used on flat ground (fields). Will be running a rotary mower (bush hog), York rake, & front end loader. Any recommendations?
/ Ag vs industrial tires #2
R4's will typically have a higher ply rating and stiffer sidewall. If you are not going to do any tillage they would be the way to go. I just purchased a set of 12 ply R4's for my Ford 4610 SU. I mainly brush hog with it and needed the heavier tire for thorns and flat prevention plus they are tubeless. Plug and go.
/ Ag vs industrial tires #3
R4s wear great and get good traction 99% of the time.... Problem is hillsides (not real steep grades) in moist (not sloppy wet) conditions.... My problems with R4s occurred backing up the slope to bush hog close to a tree line... you might think (I did) that if it lost traction, it would slide straight down.... the weight of the bush hog swings the back around, so I’m starting to slide sideways down the slope... Front loader drops to ground... it stops.... long story short... my R4s are 10 years old and I’ll get Ag tires when replaced... I’m sure there’s some operator error involved in my experience... but there are a lot of tractors on Ag tires in the Hollow... Good luck with your decision...!
/ Ag vs industrial tires #4
R1 for what you described.
/ Ag vs industrial tires #5
There are so many posts on this site and YouTube videos comparing the two. I went with R4s in the L6060 I just ordered because I have R1s on my NHWM55 now and they tear up the yard around the house and tear up my gravel driveway. Maybe the R4s will do the same, but the R4s appeared to be more common on compact tractors so I felt I’d had a higher resale on it. Also if I need to do work at someone else’s property I figured the R4s will do less damage on their property.
I plan to run my rotary cutter, 7’ box blade, rear blade, backhoe, grapple, and later a rake to clean up my hilly property. I hope I don’t regret the R4s and I am sure there will be a couple places they may not be as good as far as traction. However, like with the R1s I will learn and compensate. My final thought is that if R4s were so terrible then they likely would not sell them or strongly steer you away from them at the dealership.
Hopefully I made a wise choice. Tractor hopefully gets delivered end of next week so once I run it around a bit I’ll have more advice.
/ Ag vs industrial tires #6
No question what-so-ever, I would go with R1's. When your butt is up against the wall - the R1's are going to grip and pull you thru. I will agree - if you will be doing a lot of whatever on your lawn - the R1's will scuff it up.
I run R1's - 16.9 x 28 & filled with Rimguard. Each rear tire weighs right at 1000#.
/ Ag vs industrial tires #7
R1's for field and hill work.
R4's are a compromise. Less traction. But benefits are less lawn damage, and stiffer/thicker tire with higher load ratings and do better in the woods because increased puncture resistance. None of those benefits help you for what little you describe of your needs
/ Ag vs industrial tires #8
For traction on steep slopes, I'd take R1s every time.
/ Ag vs industrial tires #9
I was considering a skid steer or a CUT. I nixed the skid steer because it would tear up my lawn and gravel driveway to much. I went with a CUT and R4s because I thought it would be easier on the lawn than a friends R1 was, and I was correct.
I have a big fairly nice lawn and cannot tell I am maneuvering on it with R4s unless I do a lot of work in one spot. I had to deal in a foot of mud hailing dirt for fill and it did alright. Maybe R1s would have been better but for the limited time I used them in mud they worked out alright. I suppose it all depends if it is a field tractor or an all around tractor with a bunch of yard work involved.
/ Ag vs industrial tires #10
R4 tires are optimized for doing heavy loader work, operating around construction sites (or other scenarios where durability and puncture resistance is important). They are a good general purpose tires for many uses.
R1 tires are optimized for row-crop farming where forward traction and a narrow tire are important factors. They have fewer plys and are less stiff than R4 tires.
You haven't mentioned anything that suggests R1's are needed, so maybe look into R4 tires. It really comes down to aligning the purpose/benefit of the tire with your typical uses.
/ Ag vs industrial tires #11
I would vote for R1's also;problem is once you make a choice you are stuck(they use different rims).We use our tractors in the dirt and snow so R1's are a must.I have done a lot of brush-hogging and FEL work and no real problems.
/ Ag vs industrial tires #12
Hmmmm.... thanks for pointing that out birdman... Rims needed to convert...
/ Ag vs industrial tires #13
I already made the mistake of R4s. They dont hold on a hill, no traction in mud.
/ Ag vs industrial tires #14
If your property has lots of big sharp rocks, I'd go with the R4's. Lose a little traction from the R1's, but gain a lot stronger sidewall and tread structure... R1's have a fairly weak sidewall and tread structure compared to the R4's....
/ Ag vs industrial tires #15
I would go with R1 for the traction on the hills and mountains. For those who think R4 are more puncture resistant (the only flat I have had is on R4, my R1's never had a flat), you can get the best of both worlds by ordering R2 deep tread rice and cane tires. They have larger treads and more plies than standard R1 tires.
/ Ag vs industrial tires #16
I live in hilly terrain and have had both.After a nice little butt pucker sideways ride down a slight hill went back with ags verses the industrials.No issues after that.
/ Ag vs industrial tires #17
I agree with you on puncture resistance. Of course maybe it varies by tire brand. I have R1s on my current tractor and if the tires were susceptible to puncture I would know by now. We recently had a modular set and a barn built and I have done a lot of debris cleanup. No issues with the tires, other than lifting close to max weight on the loader will cause the fronts to bulge out despite proper inflation.
I have a lot of tree cleanup to accomplish now so I went with R4s on the machine I just ordered. Hoping I don’t regret it when mowing but once I get the place cleaned up in 5+ years I could just pay to replace them I suppose. Time will tell :)
/ Ag vs industrial tires #18
Standard OEM stuff, the R4's tend to be heavier.
BUT.....you "can" get R1's with just as many plys
/ Ag vs industrial tires #19
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A63688)
2023 New Holland...
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
2009 Ford Escape Hybrid SUV (A61574)
2009 Ford Escape...
KUBOTA BT2912A - 15" PIN ON BUCKET (A64280)
KUBOTA BT2912A -...
Redball 6 Row Hooded Sprayer (A64119)
Redball 6 Row...
Deutz D 2011 L03 Engine, 3-Cylinder Diesel (A63689)
Deutz D 2011 L03...
