Snow Blade mounting a snow blade on a front end loader
   / mounting a snow blade on a front end loader #21
If anyone is looking for some good info on mounting a plow on the front end loader, feel free to ask away. I have looked everywhere and researched a ton of different options. What I have come up with is in my opinion the most useful, cost effective, and easy to find parts.
I used this to mount to the quick attach system on my tractor (LS XR4140HC): Three Point Adapters - Quick Tach Attachments - Tractor Attachments
I bought a local Diamond Trip Edge Plow for the 1980's or 1990's, solid heavy quality steel unit ( You can also use a Fisher Plow): Diamond Edge | Trip Edge Snow Plows | Meyer
A few CAT2 pins, some chain, and other some items you can put it all together. Using all these parts allows thew plow to float using the chain system like a truck would and not use the force of the loader to control the plow.
I ran hydraulic lines from my rear controls to angle the plow left to right. I used a crossover release valve to limit any damage if anything is hit with the plow.
   / mounting a snow blade on a front end loader #22
Drew,
Do you have any additional pics that show more detail on how you put this together?
   / mounting a snow blade on a front end loader #23
Drew,
Here are links to my plow mods (same tractor as yours). Originally I made it rigid frame to the QA plate. The blade has its own trip edge.
http://www.tractorbynet.com/forums/build-yourself/323978-snow-plow-build-3.html
I later modified it to make the blade float like it would if mounted on a truck. See posts 7 and 18 for pics.
http://www.tractorbynet.com/forums/snow-removal/374316-advice-needed-please-converting-curtis.html
   / mounting a snow blade on a front end loader #25
Thanks George. I will take a look at these posts when I have a few minutes. I am not capable of welding and fabricating. I am much better at following instructions...
   / mounting a snow blade on a front end loader #26
   / mounting a snow blade on a front end loader #27
I have a kioti ck 30 and am considering putting on a quick attach 8 ft blade.. dealer doesnt recommend this as he says can damadge loader arms ,,, anyone here have any prob;ems
tks
Back in the early 1980's, FEL plows were all but unheard of on compact tractors due to possible loader arm damage. Ignoring my dealers advice I built one for my little Kubota B7100 from an old 6 1/2 ' Western plow I took off a wrecked jeep. It was amazing what that little 17 HP tractor would do in the snow! After using it for 3 seasons, I noticed cracks forming in the welds on the loader arms. I re welded them and used the setup for another 2 seasons before selling the tractor to a friend. As far as I know, he's still using it.
Newer compact tractor FELs are designed for use with plows and many companies sell them. Although I can't speak for your CK 30, I used FEL plows on my Kubota L3010 and L3430 without any problems. I still use them on my L6060 and MX5800 as well. As others have mentioned, using a spring trip mulboard and crossover relief valve are a good idea. In my experience, tire chains, at least on the front, are also a great help.
   / mounting a snow blade on a front end loader #28
I didn't have to weld anything with my setup, and the plow detaches from the 3pt plat quick and easy so it can be used for other functions.
   / mounting a snow blade on a front end loader #30
I also grooved my tires. I've been plowing in 2wd
PIECE OF 4' X 76" 3/16" THICK SHEET METAL (A57192)
PIECE OF 4' X 76"...
UNUSED PABREAK RT260 - 72" HYD TILLER (A57193)
UNUSED PABREAK...
2019 Nissan NV200 Cargo Van (A55852)
2019 Nissan NV200...
2006 E-Z-Go ST350 Gas Utility Cart (A55851)
2006 E-Z-Go ST350...
2023 Club Car Carryall 700 Utility Cart (A55851)
2023 Club Car...
2012 Chevrolet Express 3500 Passenger Van (A55973)
2012 Chevrolet...
