White 6150 - Starting Issue
/ White 6150 - Starting Issue #1
HOFFandGOLDMAN
Eston, Saskatchewan
535 Quadtrac
Hello,
I own a white 6105. Has been an absolute gem of a tractor, hard on fuel though. Lol. My wife went to start it last week to feed her horses as it is our main chore tractor and she said it was ticking, but wouldn't start. She thought it was dead and put the batter charger on it and let me know about it when i got home from work.
After i looked into it i realized the battery was quite old so i bought a new one, after installing that still nothing, so i ordered a new starter and installed that when it came in the to the parts shop. When i go to turn the key all the lights come on on the dash, its the volts are good, but when you turn the key to activate the starter still nothing. So i checked all the fuses and they seem to be fine. I went back through my phone to make sure i installed all the wires correctly on the starter, all seems good. (Handy thing about smart phones taking pictures so you know how to put them back together)
As my last resort, i know its not ok to do this, but i had to see if it was another bad starter, i took a screw driver and jummped the starter to see if it would work. It sparks instantly and is ticking. So i think its fine?
I took off the new starter, put the old one back in and yep for sure this old one is no good, so i hook up the starter just so i can see the gear moving at the end and jump it to see it spinning. All good with the new one.
My issue is when its installed in the tractor and its up against the fly wheel it wont crank it over for whatever reason ane the when you turn the key it wont even engage the starter.
Any advice on how to get it running?
/ White 6150 - Starting Issue #2
Possible bad ends on the main cables. Poor ground at the battery. Poor battery connections. Did you ream out the battery post clamps? An ugly layer of something can form in there making poor connection to your battery and causing exactly what you describe.
Making a shiny new lead surface and coating it with terminal grease or spray prior to attaching to your new battery is what you should do.
Yes you bet. When i changed the battery i also changed the terminal cable clamps. The old ones were poor shape and the positive terminal cable was very gunked up. So i just decided to spend the extra $10 and put new ones on. Then give them a bit of grease then they were good to go.
/ White 6150 - Starting Issue #4
Your last resort would have been my first approach. Doing that should start the tractor or at least turn the engine over. If doing that doesn't turn the engine over there's only 4 possible things that could be wrong . Bad starter and that's not likely. You're jumping it wrong. The battery is dead. There's a bad connection somewhere.
/ White 6150 - Starting Issue #5
Did you replace the cables or just the ends? Getting fresh copper and good connections on new ends can be a problem. So many "mechanics fixes" like crimp connectors, butt splices, clamp on battery terminals and electrical tape are trouble down the road.
/ White 6150 - Starting Issue #6
Five: the engine is seized.
/ White 6150 - Starting Issue #7
Inflatable Canoe (A64127)
Inflatable Canoe...
UNUSED WOLVERINE SB66 - 66" ROCK BUCKET (A64281)
UNUSED WOLVERINE...
International S1900 (A63689)
International...
1999 Ford F800 Dump Truck, VIN # 3FEXF8019XMA05457 (A65563)
1999 Ford F800...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
CHANDLER 14' LITTER SPREADER (A64277)
CHANDLER 14'...
