3-Point Hitch My CK2510 with a homebuilt rear carrier
/ My CK2510 with a homebuilt rear carrier #2
Very cool. What does the empty carrier itself weigh?
About 300 lbs ish. I have a 4" poured concrete "floor" which fits into the box if I just want to use it as a counterweight/ carryall, or for hauling firewood
/ My CK2510 with a homebuilt rear carrier #5
Pretty neat! Where did you get the sunshade?
I built it. Just a chunk of 3/8" plywood, easily replaceable when it gets dented by a tree.
/ My CK2510 with a homebuilt rear carrier #8
This is great. Do you have other pictures? How does the dump mechanisms work? Do you any sort of build directions?
I do not have any other pics right now, the machine is on a job away from home otherwise I could get a few for you. The dump mechanism is a simple hook-and-latch. Pulling the rope lifts the hook. The pivot is the 3 point's lower lift arm connection. Google "transport box" and you will see many similar mechanisms. The main difference this one has is that this is actually a rear pallet fork that dumps, and the box just sits on the forks.
2004 FORD F-350 XL DUALLY CREW CAB FLATBED TRUCK (A59823)
2004 FORD F-350 XL...
New/Unused Quick Attach Pallet Forks (A61166)
New/Unused Quick...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
2016 FORD F-550 SUPER DUTY DUALLY CAB-N-CHASSIS (A60736)
2016 FORD F-550...
2020 FREIGHTLINER CASCADIA 126 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2020 FREIGHTLINER...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
