What's wrong with this picture?
/ What's wrong with this picture? #1
CincyFlyer
West Chester
Mahindra 2540
This is the cover of my Mahindra 2540 manual (and it's quite poorly written; my "day job" is technical publications for a large jet engine manufacturer!)
Something odd about that tractor ...
(Please forgive the cat hair from the scan!)
/ What's wrong with this picture? #2
Well they couldn't decide which way they wanted the tires for one.
/ What's wrong with this picture? #3
Some recommend that orientation for better reverse traction, particularly with loader work...
Note that only one of the front tires is that orientation!
/ What's wrong with this picture? #5
Yeah, I noticed that AFTER I posted. Maybe it's one of those compromises; slightly better traction in reverse and slightly better in forward!
/ What's wrong with this picture? #6
Dang it...I got a couple of tires off e-bay and dropped them and the rims off at a tire shop...when I was unloading them back at the farm I noticed they were mounted with opposite tread direction...since they are turf tires I've left them...mostly run heavy lug fronts anyway...
/ What's wrong with this picture? #7
Well to what the OP said poorly written manual, so I guess to go with the poorly written manual a poorly put together tractor.
/ What's wrong with this picture? #8
How many times you looked at that manual before you noticed? As long as the tractor works good, all that counts. I'd might expect that on a Chinese tractor manual 40 years ago.
/ What's wrong with this picture? #9
Well, I don't think that there is anything wrong with the picture. :rolleyes: It seems to me that a large amount of tractors have the tires mounted this way. Not on purpose, but when you have people that know next to nothing and get paid about the same amount, what else would you expect? :rolleyes:
So to sum up, don't be surprised when you see a tractor with the tires mounted in a similar fashion. The manual is just showing how it actually might be. :(
/ What's wrong with this picture? #10
Where is the right rear fender & tire? Actually the entire right rear of the tractor is missing.
/ What's wrong with this picture? #11
I've actually been to the dealer shown on the brochure. Considering... the picture is right on.
/ What's wrong with this picture? #12
If BOTH tires were mounted with opposite tread direction, why couldn't you just mount them on the opposite side to correct?
Regarding OP's picture: I'm sure the dealer will say "Well, one's for going forward, and the other is to back up" :rolleyes: But missing the right rear tire IS a bigger problem! :eek:
/ What's wrong with this picture? #13
Maybe showing that the tractor can operate with only 3 wheels? :rolleyes:
Is this actually one of those pics that is intentionally flawed so that people can do exactly what we are doing? :confused3:
Seems like if it is-was the real thing that it would have been more work than to have the correct complete machine available to be photo graphed. :confused2:
My tractor has had only the most minor of issues in its first 100+ hours.
I suppose that it could be a lousy Photoshop job, and the tractor was never this mixed up. But somehow I doubt it.
/ What's wrong with this picture? #16
That's what happens when marketing does manuals. Some one thought it looked better that way
/ What's wrong with this picture? #17
Agree on the left front tire reversal....reason who knows, maybe as stated herein. Seems doing only one would present problems. Now to have the fronts one direction and the rears the other for the intended purpose stated, that may work...never tried it.
On part of the tractor missing, just a clip and paste job leaving out part of it.
/ What's wrong with this picture? #18
You must not buy much stuff from Chy naaa as your pres says, otherwise you would be satisfied that it had a tractor image at all ��
/ What's wrong with this picture? #19
I think you’d actually get the worst of both unless you had a locking differential on the front.
/ What's wrong with this picture? #20
On a side note.... Back when I was in high school (before I was dating my wife) I used to date a girl that lived in West Chester. Over near 42 and West Chester Rd. My aunt and uncle lived down there and I met her through my cousin. I have several cousins that work for a jet engine manufacturer, too. ;) Spent many summers in that area, Kings Mills, racetrack in Mason, Sharon Woods.... I can't believe how much that area all the way up to Dayton had built up since then. I think I read somewhere about 10 years ago that it was 2nd in growth behind the Raleigh/Durham area.
2006 HEIL 200BBL CRUDE TANKER (A65643)
2006 HEIL 200BBL...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
2012 Ford F350 Truck (A62679)
2012 Ford F350...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A64194)
2018 Freightliner...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
