Electric tractor
/ Electric tractor #2
As graphene technology develops, battery/electric tractors seem feasible in a few years.
Graphene technology has the potential to displace current Lithium ion technology in batteries.
/ Electric tractor #3
They both have them, check out the videos on you tube.
/ Electric tractor #4
A quiet tractor? That means I could hear my tractor radio without using headphones.
/ Electric tractor
Plus no more need to use ear muffs unless you are running noisy attachments.
/ Electric tractor #7
Battery pack contains the equivalent available energy as 8 gallons of diesel . Battery will provide more of it’s capacity if the tractor is operated at part load instead of full load .
/ Electric tractor #8
Seems like a good fit for CUTs. My usage is almost always less than 4 hours. Version 1.0 will be interesting. Version 2.0 might be compelling...
/ Electric tractor #9
/ Electric tractor #10
Most of my usage is 30 minutes to an hour at a time, doing small jobs, mowing, grading, hauling dirt or rocks.
/ Electric tractor #11
/ Electric tractor #12
/ Electric tractor #13
/ Electric tractor #15
Frankly if you're building an electric tractor, there is no need for a transmission if you have the right motor controller. At worst, you might need a 2 or 3 range transmission, but no need to lose 20% of your battery charge pumping hydraulic fluid to drive the wheels.
Then you would want a closed center hydraulic system with an accumulator and a pressure switch (like on an electric pressure washer) to keep the hydraulic pressure up without running the motor all the time and a separate electric motor to run the PTO.
If you want to get fancy, you could put electric motors on your PTO powered equipment, but that could get spendy in a hurry.
Aaron Z
/ Electric tractor #16
I would definitely be a customer......if the price is right.
/ Electric tractor #17
All fine and good in theory, but I'll sure have to keep a diesel for when the power goes out. Sure couldn't power a generator for a week or 2.
Five hours wouldn't last long tedding or raking hay and if it's cabbed with AC even less time.
Just plowing snow after a good sized storm is a couple of hours for me, and I'm danged sure going to want a cab and heat for that.
/ Electric tractor #18
I am amazed they are this far along with version 1.0 (Model T). Technology will race forward and quickly enhance capabilities. I can imagine farms that have machine sheds covered with solar panels, and a wind turbine or two to supply most or all of the needed energy. I can imagine modular battery packs that can quickly be swapped out for "refueling" on long days. I can imagine "pony tanks" of batteries for extended capacity sprayer tanks.jpeg
Will they replace diesels overnight? Nope. Will they happen? Yep.
/ Electric tractor #19
At some point economies of scale will present a problem. While BIG corporations will be able to "afford" new technologies the bulk of the world won't be able to. Reason being is that the bulk of the world's population isn't able to afford to take on additional debt (we can deny it all we want but we are debt saturated- if not for "hiding" bad loans it would be a lot more clear; bad loan write-off will occur and with it a reduction in over-all debt servicing abilities, especially affecting issuance for new debt).
So, yes, Big Ag probably will have a sense of a transition but I assure all that it will come at a BIG price. Expect BIG subsidies; meaning, tax hits to all. And eventually as the debt-carrying abilities further diminish food prices WILL rise. While this is long over due I'm afraid that it'll come at a point in time that will be a huge shock. IF "we" weren't so heavily debt-laden I could see this being pulled off. Insufficient numbers of younger folks able to work off our debt; the Ponzi unravels.
Raise your hand if you can afford another new tractor. And keep in mind that these would carry a significantly higher price tag than what existing fossil-fuel based ones currently sell for: and that would likely even be WITH a direct subsidy [the drain will be through some other hole in your pocket].
I'm NOT anti-EV, not at all. I'm just practical. I have a friend with an EV that is looking to go off-grid. He's figured that he won't be able to keep his EV (cost for scaling up his off-grid solar installation would be too great). And this guy is a HARDCORE solar/electric guy! I've got quite a bit of personal study in energy, but it's the economics that I've found really just aren't there to support it. (and, yes, the limits to fossil fuels and its environmental impacts ARE most certainly expensive, most likely more so, but because tech may be better in these regards that still doesn't mean that it's a viable "solution" - that something CAN be done doesn't meant that it OUGHT to)
Jevons Paradox and human hubris are lurking behind our curtain of optimism.
/ Electric tractor #20
The outright cost of a 100Kw hr lithium battery pack and cooling system will make the EV proponents here slam their wallets shut and then run away.
1995 Ford F-250  7.3L Powerstroke Diesel (2WD, Long Bed) (A63118)
1995 Ford F-250...
2025 Pabreak 6-Way 84in. Serrated Hydraulic Dozer Blade Skid Steer Attachment (A61567)
2025 Pabreak 6-Way...
2013 Jeep Grand Cherokee AWD SUV (A61569)
2013 Jeep Grand...
UNUSED JCT 84" SNOW PUSHER (A62131)
UNUSED JCT 84"...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A63118)
Case Wheels for...
New/Unused Wolverine Quick Attach Ripper (A61166)
New/Unused...
