Xj2025 backhoe dolly
/ Xj2025 backhoe dolly #1
dwalk19
Gold Member
Addison, ny
2018 LS XG3140H TLB
I saw one thread on it but not really any pictures, anyone able to make a backhoe dolly for the xj2025, i tried buying some heavy duty snowmobile dollies, but didnt have much luck getting them to work, may have to revisit it, but might just be better off building something, kinda hoping for some pics for ideas, thanks
/ Xj2025 backhoe dolly #2
If I could ever get the misses to quit using the backhoe, I'd be all over that!
/ Xj2025 backhoe dolly #3
Storing the backhoe has been on my mind from day 1 of my purchase. I don't have much room in my garage (30x20) to store the backhoe and I don't want to leave it in the field. Also its not very small so you cant tuck it away in a corner somewhere... I will be building a new 40x60 workshop soon and a dolly might work then, but that might not be for a while. So i guess ill have to figure out a way to store this thing so the elements don't destroy it.
/ Xj2025 backhoe dolly #4
now that you got me thinking about it again... Went out in the garage and took the backhoe off. I think if you take the 4 bolts on the sub-frame out you could fold it up and cart it way but it is still 7 feet long and 4 foot 5 inches wide...
to make a dolly to fit this I think it would be a simple Tee design. In this configurations all you would need is some hefty 2" x 2" square tube. 1 piece about 7 feet long and the other 53" long. Seeing how the stabilizers are already that wide there is no reason to go smaller. Weld them into a Tee and mount 3 heavy duty casters to the ends. then you'll need to fabricate up some mounts to connect where the 4 bolts came out of the sub-frame so you can firmly mount the backhoe to to the dolly.
Dont think this is a quick attach method by no means... but it would get the job done. Instead of using the 4 bolts you could replace them with 4 pins of the same diameter to make it faster.
Yeah it wouldn't be to bad to store except for the long subframe arms, folding it up definetly looks like it helps, and yeah I agree a couple quick release pins wouldn't hurt, but your right probably would want to strap down some how
/ Xj2025 backhoe dolly #6
To install My BH92 you do not have to take the lower lift arms off the 3 point hitch but it is recommended. *I heard damage could be cause if you leave them on. *Trying to assess is it worth take the lift arms off so trying to find out what kind of damage can be done and what action causes the damage ..etc.. mistakenly lifting the arms when the bh is on. *Some arms got bent some how... was it that they got hooked on stumps? *Hope you can shed some light.*
/ Xj2025 backhoe dolly #7
I seen something in the Kioti threads. The backhoes are very similar to the CK20S and CK2510.
/ Xj2025 backhoe dolly #8
Like others on this forum have done, you could re-purpose a engine stand... HF has the 1000lbs version on sale for $47 with coupon. 1 lb. Capacity Engine Stand
looks like it would work... dont know the tube wall thickness, but it would be hard to find metal casters and that much steel for the same price.
/ Xj2025 backhoe dolly #9
Yep, that's how I'd do it. Rigid casters at the frame end. Swivel caster at the bucket end. Bolt/pin the frame end before setting the weight down. A saddle bracket for the bucket to sit in.
Buy high quality casters so it can be relatively easily moved.
Wouldn't take more than a couple minutes to attach the cart once the hoe is free from the tractor. Last thing would be raising the stabilizers, then uncouple the hydraulics. :thumbsup:
/ Xj2025 backhoe dolly #10
stopped by HF on the way home from work and picked up the 1000lbs engine stand. Should have time this weekend to play with it.
/ Xj2025 backhoe dolly #11
Will be interested in the end result!!!! Please post pics.
I'm a bit concerned if the hoe sitting on those wheels will be able to be moved by hand. Not sure what the hoe in question weighs?
/ Xj2025 backhoe dolly #12
im not sure either... :shocked:
Its not listed and I've asked the dealer... was told "around 1000lbs". Im pretty sure that was just a guess
/ Xj2025 backhoe dolly #13
I built a welding table that weighs around 800lbs fully stocked. It's on very high quality 6" steel casters. It requires the floor to be swept clean before moving. It also requires a pretty hefty shove to get it started rolling.
/ Xj2025 backhoe dolly #14
haha makes me think of my sander. In the background of my pictures there is a 37" belt sander that weighs 1300lbs. The guy I bought it from had welded 3"? poly wheels to the legs... the thing hardly moves on them. I dont even know how they are not busted off yet. Luckily he owned a crane business and we used one to load it on my trailer. Getting it off was another story.
/ Xj2025 backhoe dolly #15
I had some time this weekend to weld up the HF dolly. here is the end results, well kinda - part 2 coming later this week. Was a fun build. I might even paint it... maybe...
Harbor Freight Engine stand. Can it hold a Backhoe? - YouTube
Thanks rider7767 (Tony) for the idea!
I need a better camera, the batteries died halfway through and my wife didn't like the idea of her picture camera in the garage with sparks
Cool video, pretty impressive, thanks for showing and the idea
/ Xj2025 backhoe dolly #17
Looking good.
/ Xj2025 backhoe dolly #18
thanks
building the backhoe dolly was the easy part... I didn't realize how much time it takes to do the youtube stuff...
/ Xj2025 backhoe dolly #19
A fast computer with a big video card is your friend. LOL
/ Xj2025 backhoe dolly #20
Anxiously awaiting part 2!
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
CASE 105C (A62177)
CASE 105C (A62177)
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
Like New! Kubota L2501 HST Tractor Package – LA525 Loader, RCR1260 Cutter
Like New! Kubota...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A63688)
2022 Schulte...
2014 Chevrolet Silverado Pickup Truck (A62613)
2014 Chevrolet...
