Core drilling--anybody do that?
/ Core drilling--anybody do that? #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
We have some post anchors to remove and someone suggested core drilling. I got a quote from a driller to drill out 4 post anchors (4x4 posts, the deepest hole might be 18", others a lot less) and he said about $1,000 including travel, 35 mi. each way.
I thought that was a little high and found Home depot rents the equipment for $104 for 1 day's use. So are these tools hard to learn? Is the project a reasonable DIY thing?
/ Core drilling--anybody do that? #2
You want to remove anchors by drilling? I'm not getting it. The coring equipment rented by HD is for concrete and might be able to go to 12 inches. Typically concrete coring is usually shallower. Not sure if they rent the core bits or make you buy them, but they aren't cheap.
/ Core drilling--anybody do that? #3
I don't understand your situation, you have 4x4 posts set in the concrete or some sort of 4x4 anchor base set into the concrete?
What's the situation and desired end result? New posts or just filled and smoothed over.:thumbsup:
/ Core drilling--anybody do that? #4
Man, I'd just get some large wood bits and start drilling out the wood posts and chisel them out with a spud.
/ Core drilling--anybody do that? #5
Um, I dont get it either.
4x4 post.....18" or less.......
What are they in? And what is the desired result?
/ Core drilling--anybody do that? #7
I think he's got 4x4s embedded in concrete and was thinking about having someone core out a circle of concrete right over the 4x4 stub so he'd have a nice, round hole where the square 4x4 used to be. Seems like a good idea until you find out how much core drilling costs! :shocked:
I've had to be involved with some core drilling in my last I.T. job placing floor mount power/network taps under conference tables, desks, etc... we dreaded getting the estimate to drill 3" (as I recall) cores through the concrete floors. It's very, very expensive.
/ Core drilling--anybody do that? #8
I had about a dozen drilled in my poured concrete basement walls when we built. I don't remember the exact cost, maybe $400-$600? They varied from 1" (hose bib lines) to 5" (septic line). Travel was part of it since the guy came from KY to TN. There's not a lot of folks that do it. Captive market!
/ Core drilling--anybody do that? #10
I've done some boring and would not recommend renting and diy. 1st off the bits are very expensive and if you don't know what you're doing you'll be buying them. Well you'll be buying at least one, I doubt they rent them. You could be buying many to get done. 2nd, without a smooth slack l slab you mount to and start the drill into you'll never get a straight hole.
/ Core drilling--anybody do that? #11
I also don’t get it. I’ve done some of it through work. We take cores to determine pavement thickness. Asphalt is easy, concrete takes some work. We usually take 4 inch cores. You need an electric source and a water source.
It takes about a 6000 watt generator and we usually get about 300 gallons of water in a tank. We put it all on a trailer of mine. It basically just a high quality drill rig mounted on a stand that is waist high. The water is for cooling the bit and yes the bits are diamond bits that look like a hole saw and are expensive. I think for the bit and the core drill machine are like $150 for a day.
Ok, I certainly need to clarify.
The posts are attached to steel anchors, U shaped except square, not rounded. The anchors apparently have a pin going down into the concrete. I just guessed maybe 18" while sitting at the keyboard--I don't know how deep the longest one goes, but looking at similar anchors at HD, it is much less than 18". I can cut the steel with a die grinder, then the core drill will have to make a hole around the pin so we can pull it and surrounding concrete out to leave a hole. A new steel railing upright would be anchored in the hole that is left. That's the idea, anyway. Will know more when the rail guy comes and takes a look. But somehow, we need a new hole. He may be able to do the hole job.
/ Core drilling--anybody do that? #13
You have something like these to remove?
Bruce
/ Core drilling--anybody do that? #14
Weld onto the existing steel in the concrete.
Leave old steel in and drill new hole alongside it.
/ Core drilling--anybody do that? #15
Ok I get it, it’s for a deck or patio or something similar. I was thinking posts for a fence line. How thick is the concrete? If you have water nearby, a garden hose works, and a110 volt outlet, not a big deal to do it your self. My guess would be a couple of hours. You could also probably get by with a 2 or 3 inch bit.
/ Core drilling--anybody do that? #16
I just rented a core driller and bits to put some holes in my foundation to run power to my shop. Drill motor was $75/day and bits were $35/day. The motor was 110v, no issue running it on a 100' extension cord. Water was needed to cool the bit and flush out 'slurry' that was generated. The drill motor had a level on it so you stood a shot at making a level/straight hole. It took about 15 minutes to drill thru the 8" of foundation I was working on. One hole did hit a piece of rebar, that hole took about 20 min to get thru. I would call around to your local rental places and see what they have, and for how much, and do it yourself. The rental place I used had bits from 1" to 12". You could use a hand held drill motor up to a 5" bit, after that you needed the motor on a stand. If you just have a 1/2" steel stud you want to core out, I would use a 3" bit and spend 15 min per hole and DIY. I was warned that if you didn't use enough water to flush out the slurry, the core would get stuck inside the bit with little hope of getting it out without damaging the bit.
/ Core drilling--anybody do that? #17
I looked at a bunch of youtube videos on this core drilling thing, wasn't sure what it was, with very few straight to the point on a low budget option, the nearest straight forward drilling thing looks to be the farthest away, Europe most likely, of coarse US only showed the $$$$$$$$ options. Seems like everything or everytime I look at something on youtube it's over on other side of the planet, for a low budget one man do it yourself thing-a-majig on whatever I'm doing, ok got that of my chest.
Handheld Wet Core Drilling - YouTube
/ Core drilling--anybody do that? #18
Well, that certainly clears things up. :thumbsup:
/ Core drilling--anybody do that? #19
That video is pretty good. We installed a large machine tool at work and drilled 56 3" holes 14" deep and then drilled a 12" diameter "counterbore" for the leveling jacks and anchor system. We rented the drill and bought our own bits. The drill was a drillpress, like a mag base drill only with a vacuum base. Due to the big bit we were using we Tapconed the base down. The drill worked great with the 3" bit. Was too fast a speed and underpowered for the 12" bit, but it did do the job. Got another installation coming up where we are going to drill 95 12" diameter holes 5" deep. We have a set up now using a skid steer to run a hydraulic drillpress. We'll see how that works. I can see drilling the 3" with a hand drill without a problem in your case. I would check the rental places.
/ Core drilling--anybody do that? #20
It may or may not matter but the ones I rent can be attached to a wall by vacuum. I致e never seen it done but they are set up for it.
