SC2400 Loader Valve Float Sticky
/ SC2400 Loader Valve Float Sticky #1
sauer
WA
Yanmar SC2400
Last time I used my sc2400 I was grading some gravel floating the bucket. It seemed "sticky" coming out of float, taking much more force to release the float than I remember previously.
So before I take apart the loader valve, has anyone experienced this and is there an easy fix?
Thanks
/ SC2400 Loader Valve Float Sticky #2
Sounds like the detent assembly on the end of your valve spool could be full of crud. Usually with a little time and care these can be cleaned up. Take a look at the directional valve for your loader. On the end opposite where the control linkage connects there should be a cover held on by bolts. Under this cover is the centering spring and detent assembly. There are different styles of detent assemblies and I have no idea which style is on your valve.
Thanks, appreciate it. It resolved itself when I was using it today, so if it returns I will go your route. Thanks again.
Stertil Koni 18000lbs Auto Lift Columns (A61572)
Stertil Koni...
2014 Freightliner M2 112 Tandem Dump (A62613)
2014 Freightliner...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
New/Unused Wolverine 3 Point Hitch Attachment (A65583)
New/Unused...
