Does anyone use tire chains on their UTV
/ Does anyone use tire chains on their UTV #1
ernemats
Bolivar, pa.
power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
I have a Polaris Ranger 500 and I was thinking about putting a set of tire chains on the rears. I have some real steep trails and driveway . If anyone uses chains what type is best and is there any problem with clearances.
/ Does anyone use tire chains on their UTV #2
I plowed for two winters without chains with my RTV X900 and Boss V-Plow, but last winter we had enough ice after snowing that I ended up purchasing chains for the rear. It makes stopping easier and more secure. I've never been stuck, even without the chains, but I do enjoy having the security of the chains. I plow over a mile of dirt road with almost 300 feet of elevation change. I purchased my from Miller tire: 25x8-12, 25x1-12 ATV Snow Tire Chains
/ Does anyone use tire chains on their UTV #3
I've has good luck with these guys for chains on my tractors. They do ATV chains as well:
tirechain.com
If lateral (side-to-side) traction is an issue for you (if you do a fair amount of operating on side hills), you may want to spend the extra for the diamond pattern chains. The studs on the ladder-style chains help some with lateral traction, but it's hard to beat the diamond pattern, or a similar pattern that has something other than just cross chains.
I have purchased tire chains for my power trac from tirechains.com as they are only about 15 miles away. I will probably go with the standard 2 link space chains if I decide to buy any.
/ Does anyone use tire chains on their UTV #5
What kind of shape are your tires in?
I put chains on my foreman, then the next spring bought new rims and tires thinking I'd just switch tire out fall & spring.
The new tires were radials and work great in the snow plowing.
/ Does anyone use tire chains on their UTV #6
I have yet to get my ranger 570 stuck with stock tires - rain, mud, water, rocks, snow, ice, it just pulls right through it uphill or down. The only close call was entering a mud pit in one wheel drive, just flip it into 4 wheel and it crawled right out, up a slippery hill on the outbound side.
MT
Tires are ok probably about 70% tread on them, I was just wondering how much difference chains would make mainly on going up and down hills on hard packed snow or ice.
/ Does anyone use tire chains on their UTV #8
Huge difference I run diamond studded ice chains on 825i and after things get packed down and icy it's the only way to go.
International Chain & Cable - ATV Tire Chains
I run the same chains on my Kubota BX on the rears in the winter as well
/ Does anyone use tire chains on their UTV #9
why mess around with less capable traction options? :laughing:
Price and don't need that often.
/ Does anyone use tire chains on their UTV #11
Never actually needed chains on my RTV's regardless of weather or conditions and everything around here is a hill..
/ Does anyone use tire chains on their UTV #12
A bit of ice changes everything. My RTV 500 moved a good amount of snow until there was a thin coat of ice on the ground. I started with the work site tires and later purchased a set of the factory atv tires as well after hearing multiple success stories about them. Neither set provided sufficient traction for plowing or trudging through the deep stuff. My Gator 825 didn't need chains either until we had an ice storm, after I slid sideways down the driveway and put a nice dent in my hybrid snowmobile trailer I didn't think I needed them on that either. My trailer still has it's dent and now my Gator wears chains in the winter as do both of my tractors. :laughing:
What type of chains did you get for your Gator? Do they seem like they help a lot?
/ Does anyone use tire chains on their UTV #14
/ Does anyone use tire chains on their UTV #15
Mostly because chains might be a couple hundred bucks...tracks are a few thousand (or more) bucks!
/ Does anyone use tire chains on their UTV #16
You ought to post or link to that YouTube video you have...IIRC, you posted right after you got your BOSS plow.
Still have that plow? And the Gator?
