Beacon Light for LS Cab tractor
/ Beacon Light for LS Cab tractor #21
Bracket is why I did and it’s prewired. I’m in a busy highway blowing snow and I don’t want some ambulance chasing lawyer saying he couldn’t see me.
Thanks. That makes perfect sense. The mounting arm looks pretty skookum and much nicer than anything I could cobble together.
/ Beacon Light for LS Cab tractor #22
I didn't buy the factory strobes because they look like they would stick up too far and easily get caught on tree branches snapping them off. I also want to be seen when out by or on the road so I bought the low profile magnetic strobe and only had to fab a metal bracket to the cab roof to stick it on. I fed the wire in through the back right window and plug into the cig lighter plug. I haven't seen any posts from anyone that has broken a factory strobe yet but can see it happening.
/ Beacon Light for LS Cab tractor #23
When I get back home Tuesday I’ll take some pictures. Like was stated previously it only sticks above the roof about a inch. I also mounted strobes under my front cab lights to be seen from front visibly.
/ Beacon Light for LS Cab tractor #24
IRISHBOOMER, Don't those front strobes bother your eyes? I'd probably have a seizure.
/ Beacon Light for LS Cab tractor #25
I don’t even see them they’re directional and are higher than line of sight.
/ Beacon Light for LS Cab tractor #26
Good to know! The few I've seen were not directional.
/ Beacon Light for LS Cab tractor #28
Irishboomer,what kind of led work lights did you install on the rear of your ls thanks
/ Beacon Light for LS Cab tractor #32
Bracket is why I did and it痴 prewired. I知 in a busy highway blowing snow and I don稚 want some ambulance chasing lawyer saying he couldn稚 see me.
For those interested, my dealer has just the mount for the light for $25. Then just add a less expensive light.
For those getting the plug, your going to want a 90 degree low profile one otherwise you won't be able to open your rear side window. (At least on the 3135)
/ Beacon Light for LS Cab tractor #33
Truth be told the light is garbage but the way the mount is built unless you find a light with same footprint it’s not going to mount without modifications.
/ Beacon Light for LS Cab tractor #34
A five minute tops install , this kit is a LED no rotating Beacon
(4) MISC WHEELED TRASH CANS (A64280)
(4) MISC WHEELED...
2016 Mercedes-Benz 300SLK Coupe (A61574)
2016 Mercedes-Benz...
Abaco Machines DVL500 Vacuum Lifter (A61573)
Abaco Machines...
UNUSED AGT YC-32G SAWMILL (A64281)
UNUSED AGT YC-32G...
PREVIEW DATES AND TIMES (A65579)
PREVIEW DATES AND...
213324 (A64279)
213324 (A64279)
