Beacon Light for LS Cab tractor
/ Beacon Light for LS Cab tractor #21
Bracket is why I did and it’s prewired. I’m in a busy highway blowing snow and I don’t want some ambulance chasing lawyer saying he couldn’t see me.
Thanks. That makes perfect sense. The mounting arm looks pretty skookum and much nicer than anything I could cobble together.
/ Beacon Light for LS Cab tractor #22
I didn't buy the factory strobes because they look like they would stick up too far and easily get caught on tree branches snapping them off. I also want to be seen when out by or on the road so I bought the low profile magnetic strobe and only had to fab a metal bracket to the cab roof to stick it on. I fed the wire in through the back right window and plug into the cig lighter plug. I haven't seen any posts from anyone that has broken a factory strobe yet but can see it happening.
/ Beacon Light for LS Cab tractor #23
When I get back home Tuesday I’ll take some pictures. Like was stated previously it only sticks above the roof about a inch. I also mounted strobes under my front cab lights to be seen from front visibly.
/ Beacon Light for LS Cab tractor #24
IRISHBOOMER, Don't those front strobes bother your eyes? I'd probably have a seizure.
/ Beacon Light for LS Cab tractor #25
I don’t even see them they’re directional and are higher than line of sight.
/ Beacon Light for LS Cab tractor #26
Good to know! The few I've seen were not directional.
/ Beacon Light for LS Cab tractor #28
Irishboomer,what kind of led work lights did you install on the rear of your ls thanks
/ Beacon Light for LS Cab tractor #32
Bracket is why I did and it痴 prewired. I知 in a busy highway blowing snow and I don稚 want some ambulance chasing lawyer saying he couldn稚 see me.
For those interested, my dealer has just the mount for the light for $25. Then just add a less expensive light.
For those getting the plug, your going to want a 90 degree low profile one otherwise you won't be able to open your rear side window. (At least on the 3135)
/ Beacon Light for LS Cab tractor #33
Truth be told the light is garbage but the way the mount is built unless you find a light with same footprint it’s not going to mount without modifications.
/ Beacon Light for LS Cab tractor #34
A five minute tops install , this kit is a LED no rotating Beacon
2025 X-Pro Victor Mini Dirt Bike (A61574)
2025 X-Pro Victor...
2018 Peterbilt 579 Sleeper 72" Sleeper (A62613)
2018 Peterbilt 579...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2022 EZ-GO ELITE...
iDrive TDS-2010H...
Caterpillar 400B Series Backhoe Service, Parts, and Operation Manuals (A63117)
Caterpillar 400B...
