Opinions-3032E
/ Opinions-3032E #1
Red Horse
Bolton, MA
Deere 655ZTrak, Deere 4720 Cab, 400 X LT 155
Have a buddy who is looking at a 3032E that was rolled over. Any notable downside to these. I assume this took place of 3320? I had one of those-great tractor.
appreciate any insights
/ Opinions-3032E #2
3032e is a bare bones tractor the 3320 was a premium tractor, same chassis is about it, a pretty good little tractor, but not capable of everything that the 3320 was.
/ Opinions-3032E
thx for response
/ Opinions-3032E
I have one, it does everything I need it to do. Very good tractor
Thx. The one in question is on an auction site. Its "clean and bright" but was rolled over. No fiberglass damage but the loader brackets were snapped at the four bolts. Can't imagine how that can supposedly happen and NOT suffer any fender damage but that is what the site says.
/ Opinions-3032E #6
Maybe it wasn't really "rolled over" but instead turned on its side (like with a load in the bucket too high, tipping and stressing the FEL brackets). Certainly a guess (WAG), but maybe an overstatement of "rolled over".
/ Opinions-3032E
Yes-we were thinking that for sure the loader must have been "stressed"-but again, lets say it went over and they snapped-now for sure the loader arms and the "towers" would have been free to hit the hood-you would think-anyway nasty looking break.
/ Opinions-3032E #9
Depends upon what you're using it for. The e series are designed as a basic no frills machine that are for the large homeowner and weekend farmer. The 3320 is a premium tractor with a cast vs aluminum rearend and will handle a backhoe.
/ Opinions-3032E #10
my question would be
1 why did they call it a total ?
2 if the loader 'towers' are bent they only bolt on ,did it crack the block or case ? thus totaling the tractor ?
/ Opinions-3032E #11
Well Ill play. Not sure I would want one that was rolled over. Lots of them out there. IMO having one I really like the 3032e, that said you need to know what your getting and what your not. I did notknow any better when I got mine, never needed bells and whistles but a few things I came to realize.
Its a great light weight machine that can do a lot. Great for the homeowner or small land owner, easy on my yard. That said the 305 loader like all the 300 series loaders are a bit anemic ( I sell firewood on the side and while not heavy you realize how small and light the machine and lift capacity/breakout are). Lift height was also an issue loading my dump trailer. The next issue was the brake/diff lock combined pedal. I would step on the brake (loaded my trailer a bit lower than me to help with height and reach so I didntwant to roll into it) and the diff would lock, back up from the trailer and the diff would be locked. Ok step on the brake pedal every time and hope it unlocked. Bad on my grass worse on the pavement. 2stage hydro ok but that hydro noise was annoying.
Big operator station, easy to operate, nimble, easy on turf. For what it is a pretty good machine.
I tried a 4310, about 900lbs heavier, Power Reverser and while the 430 loader has a lot more breakout Force, lift height and capacity are pretty close.
If I had a brain this would probably be the machine as a harry the homeowner I would keep. Light and nimble, but a little more work oriented.
I found a great deal on a 4510, not a fair comparison at all. Bigger and far heavier and my turf shows it. That said the 460 loader can do anything I will need. The tractor is about 2k heavier and it is very apparent. Much more of a work horse but again not as maneuverable, harder on turf, and with a 6 Cutter does not fit on my trailer. LOL.
Just beware itsa tough balance between enough machine, too much machine and too little machine.
I like the Power Reverser, Like the separate diff lock pedal, Like the split brake pedal.
, Like the temp gauge, love the lift height and capacity.
All I can say is do your research, they are all great machines. If I have learned anything over the years and it has been painfull, get more truck that you need, a longer trailer than you need and more tractor than you need. Right now I have two of the three right, ha. Anyone got a deckover gooseneck trailer for sale?!?
Any questions feel free to PM me, sorry for the novel . Rye
/ Opinions-3032E #12
The 3032e is a good little tractor. The seat is horrible, real back breaker. Hard to walk the next day after mowing for 8 hours.
It's a little light on the PTO HP running a rc2060 mower in thick grass. Very easy to bog the engine down 1000rpm if trying to mow at 4-5mph. Any slight increase in grade will bog it down hard too.
*** end is very light. Lifting my 60" 450lb disc harrow off a trailer with nothing on the 3 point put the back tires 2' in the air while the bucket just fell to the ground when it rolled off the deck.
Like RyeThomas said. Very nimble and easy on turf. Ran it in 4x4 with industrials all summer mowing 10 acres equine riding areas with my grooming mower. Was easy on the grass. 2wd you'll spin a rear tire and do some damage.
/ Opinions-3032E #13
Looks like the 3303r is more like the 3320, an that handles a 375 backhoe.
/ Opinions-3032E #14
Are you certain they make the 3330 with a cast rear end? It wasn't on the 3320 Looked at 5 years ago. That may have been the last year for that model and they might have switched to cast. It's good if they did.
/ Opinions-3032E #15
I would think the 3303r is cast because it weighs 2900 pounds vs a massey 1734e which is about 2500 lbs, an the 3301 Kubota the same as the massey.
Unused 2023 Monroe Tufline TW693222 12ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
DRAGON 500BBL WHEELED FRAC TANK (A67714)
DRAGON 500BBL...
2012 Gillig G27B102N4 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
2008 Hummer H3 4x4 SUV (A66738)
2008 Hummer H3 4x4...
ROOM WITH MISC ITEMS (A67714)
ROOM WITH MISC...
2009 KENWORTH T800 TRI-AXLE (A67714)
2009 KENWORTH T800...
