What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #191
Mine live on the tractor 95% of the time.
Logs, skiffs, totes of whatever, strangest thing I probably carried, barrels of starfish!
   / What else do you do with forks besides lift pallets? #192
I lifted up 3ea. 20'x 2' diameter horns (corrugated steel tubes used for drainage ditches and such when you need to cross with a driveway or such). Perfect for the job.
Glad you explained that - I was thinking this was another Texas story - 20' horns - when I started reading it. Plus your cattle are the wrong color for those.
   / What else do you do with forks besides lift pallets? #193
Yep, around this part of the world they are called "tin horns". :thumbsup:
   / What else do you do with forks besides lift pallets? #194
Clean beaver dams out of the creek.
   / What else do you do with forks besides lift pallets? #195
Make burn piles back when I didn't have a grapple.
   / What else do you do with forks besides lift pallets? #196
I've got holes cut in all of my forks. A pin in the hole makes lifting with a chain a lot safer. <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=528051"/>
I have 3/4 inch holes in the ends of mine too, I use d rings attached to the forks a lot with chains for lifting things.
   / What else do you do with forks besides lift pallets? #197
Re: What else do you do with forks besides lift pallets? Turkey Processing
We are exhausted.
Processed 22 birds this weekend 8 last weekend
Ranged from 9.5 lbs to 35 Lbs dressed. These were various heritage breed turkeys, more like fat wild turkeys than the genetically modified steroid laden store bought type. I'm impressed that a 40 plus Lbs bird can fly across our yard overall fence or perch high up in a tree.
When they wack you with their wings you think you have bee hit by a Pterodactyl.
   / What else do you do with forks besides lift pallets? #198
Right mike! The last time I was hit by a Pterodactyl it felt just like a turkey!
:laughing:
TBS
   / What else do you do with forks besides lift pallets? #199
Memories. Getting my new wood shed into placed:
   / What else do you do with forks besides lift pallets? #200
Build a rock wall.
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
2020 INTERNATIONAL MV607 REFRIGERATED TRUCK (A52706)
2020 INTERNATIONAL...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A55851)
Tiger Mowers 80in...
2015 FORD F-350 XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-350 XL...
