Replacing another Wheel Motor.
/ Replacing another Wheel Motor. #21
Is a not P/T owner allowed to speak?:D
Can't you get a "rebuild- seal kit" for these motors? I've never done it but it looks like a pretty simple gear motor that I have have rebuilt in an excavator.
Barry I've been up in Shannondale believe it or not.
/ Replacing another Wheel Motor. #22
Anybody able to describe the baffles? Does anybody know their purpose?
/ Replacing another Wheel Motor. #23
As I see it, the baffles help prevent "short circuits" within the tank which will keep your fluid cooler, help reduce sloshing, help particles settle, and help prevent air bubbles from being sucked into a pump.
Ken
/ Replacing another Wheel Motor. #24
Here's a picture
/ Replacing another Wheel Motor. #26
Thanks. That helps.
/ Replacing another Wheel Motor. #27
Fellas... the baffles are the tunnel for your hoses to pass through to the front half of the machine..... and the others might just be structural. I'll have to take my cover off and look.
/ Replacing another Wheel Motor. #28
Sorry, Moss, mine also has a baffle at the returns - labeled in the first picture - if you look, there is a gap behind it. The tunnel is also labeled and will act somewhat as a baffle.
More visible in this picture: IMG_2732-small.jpg
Ken
All this info is starting to get interesting... I bought this machine with a little over 600 hours on it. I have not even put 30 working hours on it yet . Because I wanted to make sure everything was in good working order and checked out before I started using it heavily...
It is an old 95 model that sat outside under an overhang. But it was out of the rain and snow. The PT had one owner and he swears these were the original hours. And by the way the Kohler runs, I believe him. After reading all of the complaints on here concerning the Robin. Figured as a base machine with a good running Kohler and for half the price of a new one I would fix it up and put it to use.
I've been slow to get on the upgrades or extended maintenance. Just doing the obvious fixes up until now. To many other home improvements and life in general going on. It has been used sparingly for lifting or moving heavy objects causal snow removal and tucked away safely in the garage.
After I bringing it home I started noticing a slight vibration when going up hill. I thought maybe the Love-joy connector was out of alignment. But never saw any shavings or wear / wobble when the machine was running .. Now after having it up on blocks and turning the opposite wheel motor I see it was this wheel causing the vibration. I do have a service training manual I just dug up with all of my other information.
Guess the quickest way was to bring the topic up here and watch you guys debate... Helps me bring things into perspective quicker, So thanks for your help. Won't be using the PT until I feel most of the bad oil is filtered out of machine. For now the plan is to take the old motor off look inside check the oil in the motor. See if I can see any debris that's noticeable to the eye.
Maybe after changing out the motor place a few magnets around the tank and run it around the yard maybe 3 hours total. Then change out the all of the oil. Here is a picture of the wheel motor circuit from my manual ... Will ask Terry while ordering the new motor and see if there is a smarter way to circulate out the debris then change the oil and filter. Guess in the end you pay for it one way or another ..
Rustyiron speaking for myself .. Any input is always helpful / welcome . From Maine to Shannondale WV it's a small world .. ;>)
Surprised no one called me out on this one either .. :laughing: Nice of you .. No I don’ have a 1430 but I do have a digrams for my 1425 .. At this point guess it does’t matter lol .. Guess I should stop rushing around before I post something.. Anyway will be ordering another wheel motor Next week thanks again for all the reply’s and insight..
OK replaced the other side wheel motor .. Man what a difference in the way she rolls vibration gone ... So now have replaced three the one remaining motor does not leak and seems fine for now..
Also if anyone here is planning on replacing more than one motor ..It would be worth your while to buy one of these 10 hydraulic pullers. This time for the heck of it .. I just sprayed on some PB blaster let it set for about 15 min's .. After the initial tighting of the puller .. I took two long strokes and it shot off like a rocket. Didn't have to use a hammer or a torch .. So much easier than the first one with a regular puller ..
Now to take off the gas tank, install new lines / petcock and heat shield. The one on the bottom of the steel tank is pretty cracked up.
2019 Chevrolet Tahoe SUV (A64557)
2019 Chevrolet...
2014 VOLVO A40G WATER TRUCK (A65053)
2014 VOLVO A40G...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A65053)
2018 VOLVO SD75B...
2015 CASE CX160C EXCAVATOR (A65053)
2015 CASE CX160C...
Power King Tractor
Power King Tractor
2018 GRASSHOPPER 900D MOWER (A66091)
2018 GRASSHOPPER...
