Preperation for a Short Term Disaster !
/ Preperation for a Short Term Disaster ! #21
Some Mormon friends taught me a trick.
Pay with everything you buy for a week or teo with $20 bills. Keep all those small bills in the safe, unless you want to be paying $20 for everything.....
That's what I do most of the time. But, then I tend to spend the small bills on diesel. I paid for 3 tanks in a row with 1s. I'm nearly out of them now and I'm using 5s.
When I started this thread I was thinking of preparing for a temporary emergency of a month or so but some here seem to be prepared for a decade with no outside help. One thing those people do not have that my 90+ year old mother and father-in-law would both point out as a necessity is a salt box and smoke house. Spent several days every year in my youth salting hams, shoulders, and bacon. The salt can literally freeze your hands. Then would have to take them out and hang them and tend the fire every afternoon after mom did it at night and dad in the morning. Hams would hang for a year or more before they would be taken down and served.
Getting back to the short term, thirty day or less disaster we have a Brita filter pitcher to filter water that stays in the fridge. Best tasting water you can drink. I guess it could be used to filter drinkable water from clear outside water but the filter probably wouldn't last long. We also have plenty of quilts and blankets and pillows.
I have been doing all my planning based on my extended family coming here and staying. That would mean two daughters, two s-i-ls, and four grands. The problem would be that two of the grands are still in diapers though one is beginning to transition out of them. Might ought to purchase a pack of the next two sizes up for the littlest one for the winter.
Looked in the utility room closet a few hours ago. We have enough home canned green beans, purple hull peas, and lime pickles to feed all ten of us for a month.
Could shoot squirrels out of the front yard for meat.
All jokes aside both of my parents lost their fathers when they were five and eight respectively. That was in the twenties when there was no welfare to fall back on. They all survived and thrived by making do with what they had. They ate what they grew or killed or caught. They didn't worry about fashions. They survived on their wits and on the traditions handed down to them by their parents. I could do the same if I had to and also ensure the survival of my family. Most of the people posting on this forum also could. Sadly, many if not most of the young ones alive today could not.
RSKY
/ Preperation for a Short Term Disaster ! #23
Well, It may be an issue of relativity.
Inconvenience vs emergency. Would you compare the events in Burma or Syria to your contingency plans? Those are EMERGENCIES!
/ Preperation for a Short Term Disaster ! #25
Many water filters do not work on parasites or diseases
/ Preperation for a Short Term Disaster ! #26
A couple generator items.
A schoolmate went out to pull start his generator in the last outage here caused by a nice storm. He slipped on the ice, hit his head and was found dead. Should only have to hear that story once.
Is it possible to start a generator on gas and switch over to natural gas to run? My limited understanding is the carburetion works, but getting one without an electric starter up and running on natural gas is hard, nay impossible. Again, limited knowledge, but I understand there would be somewhere in the neighborhood of a 20% deration of rated power. Since we have natural gas, it sure seems like the way to go for power,
/ Preperation for a Short Term Disaster ! #28
Plenty of people have done propane conversions on gasoline gens, and they are sold dual fuel by several manufacturers.
I wouldn't go messing around with converting an existing gasoline gen to natgas; if you want to go that route just install a dedicated natgas generator.
Propane leaks can be nasty (heavier than air) but are at least tank-limited. I can't imagine a licensed natgas tech risking his ticket hooking up to a converted gasoline gen - liabliity is too high.
Rgds, D.
/ Preperation for a Short Term Disaster ! #29
It has been a few years since I did any looking at the possibility. At the time there were a lot of homespun conversions. I should have done a quick google search to get up to date. It now looks like three fuel is a fairly common readily available off the shelf conversion.
convert gasoline to natural gas generator - Google Search
So now the question becomes, does anyone have one installed / are they running one? Can you switch over while running?
I stand corrected. Water filtration is something I had not thought about until I put it in that post. I need to look in to that. Of course the water could be boiled for a few minutes, then run thru the Brita to remove solids and make it more drinkable. Still, a purpose built filter would be better. I know there are large bathtub sized bags available for purchase that would be filled before the water in the system ran out. Having one of those would also be good to have. During the ice storm we never lost city water.
Gonna do my yearly generator run today to burn out the old gas and refill with fresh.
During the ice storm one of my sister's neighbors was running his portable generator when suddenly the power cut off. He could hear the engine running and figured that somehow the cord had vibrated loose. Took his time getting his coat and boots on and when he got outside his generator was gone but his push mower was sitting there running. Never saw the vehicle the thief's used to haul his generator away.
Other things that would be handy in a short term situation would be a solar battery charger, small walkie talkies, lots of quart freezer bags, and rechargeable batteries.
Keep thinking and posting guys. You might post something that will make somebody else think about their situation and save them a lot of trouble or inconvenience in an emergency.
RSKY
/ Preperation for a Short Term Disaster ! #31
I was given a Corona DK23 kerosene heater a couple years ago and could only find clear K1 kerosene in gallons or 5 gallon cans for $7 a gallon.
We can’t buy clear K1 at a pump in Massachusetts so it sat there.
Yesterday I was cleaning up and saw it on the shelf and thought I would try on road diesel in it.
Filled it up and started it with no trouble & no noticeable smoke and let it run for a couple hours.
It was in my 40x60 Garage so I Let it run through the night.
When I closed the garage up it yesterday it was 40 degrees at 5:20 pm this morning at 9am I checked it and it was still running with 1/4 tank of fuel left. The temperature in the garage went up 10 degrees over night from 40 to. 50 with no noticeable smell.
This will be a great economical heat source for a New England winter.
90cummins
/ Preperation for a Short Term Disaster ! #32
For fresh water, don't forget the hot water heater. One of the reasons we installed an 80 gallon hot water heater was to have 80 gallons of water if the power went out. We have lost power a few times but have yet, knock on wood, had to tap the hot water heater. I have a section of host and a bib to help make the connection a bit easier.
Even a small hot water heater has enough water to keep a family alive for quite some time.
Later,
Dan
/ Preperation for a Short Term Disaster ! #33
Guess I need to stock up on instant coffee. I was always under the impression that coffee beans didn't go bad as long as they weren't ground, but just reading that they do have a shelf life, but freeze dried instant is almost indefinite. I hate the taste of instant, but any instant coffee has to be better than stale coffee.
While in Viet Nam, I got to the point where I could drink warm beer and while I'd hate to regain that taste, guess it would be better than no beer, but it would take up a lot of space for a 3 month supply for me.
/ Preperation for a Short Term Disaster ! #34
Toilet paper! Lots of toilet paper! I bought a large box of that tightly wrapped industrial style toilet paper for Y2K. The good thing is, that it never gets used up as it is too unpleasant but great to have in an emergency.
I saw the Documentary of the blizzard of 49 a few weeks ago. Quite an eye opener.
Cheap booze is something our government won't let us have. Maybe it's finally time for a still!
/ Preperation for a Short Term Disaster ! #35
I wonder about depending on natural gas in an emergency, seems just like city water it could be disrupted???
Except for my welder, all my electrical power needs are met with my water wheel, my water comes off the mountain from a spring that hasn't varied in the 30+ years I have been using it and it supplied all the water to a cannery in the late 1800's. I get to go grocery shopping once a year for here so stocking up is what we do. 3 greenhouses for produce, been saving my seeds for 25 years(don't tell Monsanto) always have several barrels of gas and a couple of diesel.
Unless the ocean dries up I have all the fish/shellfish I could ever eat out the front door, plus ducks n venison out the back. I have some of the reusable lids but haven't tried them for canning meat yet??? Anyone else try?
Most things I break I buy 2 of the needed parts to fix it so I can fix it again (hopefully not right away;)
The biggie that would really mess up life here would big a major emp. No motors, Might be able to figure out how to get the tractor started but no outboards:( No water wheel or inverter, no radio for entertainment or communication and the biggie NO INTERNET, not sure I can and I know I don't want to live without it out here!
/ Preperation for a Short Term Disaster ! #36
You are in a most envious position. The water wheel especially!
/ Preperation for a Short Term Disaster ! #38
The water is a huge resource, I am looking into adding a second wheel and 2 inverters so I can make 240 and heat my water/dry my clothes with.
But the best thing is it's the sweetest tasting water I have ever had and collecting it from the spring I don't have to filter it:)
/ Preperation for a Short Term Disaster ! #39
It's because of the moose pee.... :laughing:
My sister used to tell me not to drink water because fish pee in it.
/ Preperation for a Short Term Disaster ! #40
It's because of the moose pee.... :laughing: My sister used to tell me not to drink water because fish pee in it.
Close, actually it's the moose drool, it's so good in fact there is a brewery that makes a great brown ale out of it;)
UNUSED CFG INDUSTRIAL MX15RX MINI EXCAVATOR (A62130)
UNUSED CFG...
Location (A63116)
Location (A63116)
2004 Ford F-350 4x4 Crew Cab Pickup Truck (A61568)
2004 Ford F-350...
UNUSED RAYTREE RMSC78-78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
UNUSED INDUSTRIAS AMERICA 190-9' SCRAPE BLADE (A62130)
UNUSED INDUSTRIAS...
UNUSED KJ 42'X30' METAL STORAGE SHED (A62131)
UNUSED KJ 42'X30'...
