EMP Prep, What would you do if you had 45 minutes to prepare?
   / EMP Prep, What would you do if you had 45 minutes to prepare? #71
Yes enlistments rise after disasters, but not to kill Americans.
Comparing Katrina to this scenario is where you go "entirely absurd". Katrina was a Spring Shower.
Sorry, I do not suffer fools gladly...
   / EMP Prep, What would you do if you had 45 minutes to prepare? #72
To clarify your comment I Googled it:
suffer fools gladly definition. A person who does not “suffer fools gladly” is one who does not tolerate stupidity in others. The New Dictionary of Cultural Literacy, Third Edition. Copyright © 2005 by Houghton Mifflin Company.
So now are resorting to declaring me as displaying "stupidity" in addition to "entire absurdity"?? :)
   / EMP Prep, What would you do if you had 45 minutes to prepare? #73
I still have to ask. What happens to the families of military personnel? I think this would be key as far as how many would desert. I personally would imagine that the armed forced would have it's resources stretched to the limit, just protecting itself and its assets. There is a lot of real estate in the US and much of it sparsely populated. How much fuel does the armed forced keep on hand?
   / EMP Prep, What would you do if you had 45 minutes to prepare? #74
The Soldier having to make a choice of protecting his/her family or the public from itself will contribute dramatically to shrinking numbers. Sad, but reality.
Protecting governmental assets first would be a huge issue creating a large vacuum of time when ML support is needed and when it finally gets supported.
Not even knowing the numbers, I'll guess the military doesn't have enough fuel stockpiled to mobilize all the equipment necessary to all the locations needed and sustain any length of operation. Then we are back to whether the required equipment is even functional.
   / EMP Prep, What would you do if you had 45 minutes to prepare? #75
Not for long...under M.L. the constitution is suspended...guns would be confiscated...there would be zero tolerance by the military...
And how well do you expect a mass disarmament would go over?
   / EMP Prep, What would you do if you had 45 minutes to prepare? #76
I can't verify this at the moment, but I suspect we are the heaviest armed society on Earth?
   / EMP Prep, What would you do if you had 45 minutes to prepare? #77
Don't forget that the military/government rarely does anything effectively or efficiently. This would surely be the mother of all cluster farts! And in that, I imagine all manner of danger to the public as military personnel act with little or no oversight.
   / EMP Prep, What would you do if you had 45 minutes to prepare? #78
Who said anything about a "mass disarmament" ? martial law means the constitution is suspended...as would be the bill of rights...There is no set laws per se, the military would have complete authority including legislative, judicial etc. powers...nonconformists would be dealt with zero tolerance...
   / EMP Prep, What would you do if you had 45 minutes to prepare? #79
And all arms discovered would be subject to confiscation.
   / EMP Prep, What would you do if you had 45 minutes to prepare? #80
...Don't forget that the military/government rarely does anything effectively...
In reality the US military is actually quite effective...if you don't believe it...just ask bin laden or any of the dead terrorists that have been taken out with predator drones...
2011 V.E. ENTERPRISES 130 BBL STEEL VACUUM TANK TRAILER (A50854)
2011 V.E...
FRUITLAND VACUUM PUMP (A50854)
FRUITLAND VACUUM...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
F550 CM Trucks 11ft Utility Bed (A49461)
F550 CM Trucks...
CHALLENGER MT465E TRACTOR (A51406)
CHALLENGER MT465E...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
