LS Tractor Oil, Gas, & Air Filter Information
/ LS Tractor Oil, Gas, & Air Filter Information #221
2016 XR4155 gear tractor hydraulic filter is NAPA 1715 or wix 51715
/ LS Tractor Oil, Gas, & Air Filter Information #222
Re: LS Tractor Oil, Gas, & Air Filter Information
Hey guys, just got an LS XR3135H and wanting to do the maintenance my self. I put together a list from what I have read so far on this thread, just checking to see if anything changed or if there are any updates. I want to have filters and lubricants on hand so I don't have to scramble to find something or pay more for something I can plan ahead and get at a lower cost. Below is what I have so far and also what I wasn't sure about. Can you guys verify and fill in where I am missing items or if you know of cross reference part numbers. Thanks in advance.
Fuel filter: Wix WF8395
Air filter: Wix 46438, 42985
Hydraulic filter: Wix 51715
Oil Filter: Wix 51516(XP), Fram PH3600, TG3600, XG3600, Baldwin B243
Hydraulic Fluid: Will the TSC (SKU #80639199) work fine? What ISO Grade?
Engine Oil: Will Valvoline HD Diesel oil work, (Menards SKU: 2612847)
Anything missing? Thanks
/ LS Tractor Oil, Gas, & Air Filter Information #223
aw 68 on hydro
/ LS Tractor Oil, Gas, & Air Filter Information #224
Anyone know the hst and hydraulic filters for the xg3025h? The wix site shows just the hydraulic.
/ LS Tractor Oil, Gas, & Air Filter Information #225
would this be the same filter for hydrostat tractor also
/ LS Tractor Oil, Gas, & Air Filter Information #226
Yes, the hyd. filter is the same whether Gear or HST. Every LS from an XU5065 down to the S3010 uses the same hyd. filter (same LS part number). Same with HST filters, all the same from a G3033H up to a 4155H.
  • FIlter Chart Rev 2 06-15-2015.pdf
/ LS Tractor Oil, Gas, & Air Filter Information #227
I got these numbers from a poster above but he says the wix51715 is a hst filter and a wix51551mp is a hydraulic
/ LS Tractor Oil, Gas, & Air Filter Information #228
ive never been so confused trying to figure out filters.what is the wix numbers for oil,hystat and hydraulic filters for xr4155hc,thanks.it may be in the thread but ive read till im give out
/ LS Tractor Oil, Gas, & Air Filter Information #229
I do not have the hydrostat 2016 xg 3025
Fuel wix 33830, air wix 46449, oil wix 51365 , hydr 51715
/ LS Tractor Oil, Gas, & Air Filter Information #230
Can someone help me with a XG3140H
Fuel filter: ?
Air filter: ?
Hydraulic ?
Oil Filter: ?
Hydraulic Fluid: ?
Engine Oil: ?
/ LS Tractor Oil, Gas, & Air Filter Information #231
I have the same tractor as you. The new holland workmaster 40 tier 4 engine is the same engine as the LS so I looked up the oil filter part number. It is MT40006986. I ordered it from Messicks $17+shipping. It is a blue filter manufactured in South Korea. Wix showed the hydraulic filter as Wix 51715. I think I paid $37 for it off ebay. I think Wixes filter lookup also shows the air and fuel filter. There was hardly any cross reference information available on the filters since this engine is so new. Hope this helps.
/ LS Tractor Oil, Gas, & Air Filter Information #232
Getting ready to do my next scheduled maintenance on my XG3037 and here is what I will be using:
Oil Filter: WIX 5700 (Amazon $20.86)
Pre-Fuel Filter: NH MT40279917 (Local Dealer $20.00)
Fuel Filter: WIX 33138 (Amazon $23.07)
Inner and Outer Air Filter: Inner WIX 42985, Outer WIX 46438. (Bought as combo on Amazon for $40.40)
Hydraulic Filter: WIX 51715 (Amazon $48.36)
Oil: Travelers 15W-40 All Fleet Diesel Oil (TSC $7.50 per gal on sale...will buy 2 gals)
Total for these parts will be approx. $168.67. Already have hydraulic oil on hand (QP Universal Hydraulic and Transmission Fluid JD J20A, 303). All WIX and NH parts have been cross-referenced.
/ LS Tractor Oil, Gas, & Air Filter Information #233
Are the oil and hyd filters the same for the tier III and tier IV XG3025? Both engines are S3L2.
/ LS Tractor Oil, Gas, & Air Filter Information #234
I am not completely sure, but the WIX cross reference lists only one filter for oil (57040) and one for hydraulics (51715) for that engine model. Personally, I don't think the Tier model makes any difference, but you might want to reach out to your local dealer to be sure.
/ LS Tractor Oil, Gas, & Air Filter Information #235
Complete line-up of filters for my XG3037.
/ LS Tractor Oil, Gas, & Air Filter Information #237
Thanks, Irishboomer!
/ LS Tractor Oil, Gas, & Air Filter Information #238
Finished the 250-hour service on my XG3037 today and decided to make a few notes:
*All of the WIX filters (oil, inner air, outer air, main fuel, and hydraulic) fit perfectly. The hydraulic filter was slightly shorter than the original but otherwise fit.
*The original inner air filter was very clean even after 250 hours of service....not a speck of dirt or dust. Probably did not need to change it, but did anyway. The outer filter obviously did it's job.
*The oil drain plug required a 17mm socket.
*Had to use a strap wrench on the hydraulic filter..tough spot and large diameter. Will definitely try the vacuum trick the next time....lost about a qt of fluid while changing the filter.
*Did the work in this order; air filters, pre-fuel filter, drained oil, oil filter, filled with oil, main fuel filter, hydraulic filter, all the rest.
*The oil fill location is in a fairly tight area and required the use of a flexible long fill spout on the oil container.
All in all, I was very pleased with it's serviceability and other than the strap wrench and the long flexible fill spout it didn't require any additional tools other than what I normally use to service my truck.
/ LS Tractor Oil, Gas, & Air Filter Information #239
Thanks for your post I’ll be doing my service in the next couple weeks been very informative.
/ LS Tractor Oil, Gas, & Air Filter Information #240
Thanks, Irishboomer. What filters are you planning on using?
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
TORO GREENS MOWER (A56857)
TORO GREENS MOWER...
2005 Ford F-450 Dump Truck, VIN # 1FDXF46P65EB16866 (A61165)
2005 Ford F-450...
4'x6' Stack of Sheet Metal (A60463)
4'x6' Stack of...
LMC Ag 3pt 300 Gallon 54' Boom Sprayer (A60462)
LMC Ag 3pt 300...
ASV Posi-Track RT-65 (A60462)
ASV Posi-Track...
