LPGS For Kubota B2910
   / LPGS For Kubota B2910 #163
Are there any updates on this build Rswyan? I might have missed another thread about this, but I happened to come across this today and realized I never saw the end of the show. ;)
   / LPGS For Kubota B2910 #164
That seems to happen frequently here. I guess the builder gets done with the project and moves on, simply forgetting to update the followers. We are probably all guilty of that to some degree.
   / LPGS For Kubota B2910 #165
I think RS moved over to the Politics Thread and found his new home. I'm subscribed to several threads, that he used to participate in, and he's been absent for a while. Too bad, he had some great expertise to share.
The show has been on hiatus ... expect some updates in the not too distant future.
I tend to float a around a little bit at times ... :D
Once it warms up outside and summertime arrives I am usually occupied with outside stuff, due to the limited amount of nice weather.
Once cold weather gets here and snow starts flying, it's time to go into winter mode and start on inside projects.
I fired up the double barrel stove up in the shop about an hour ago.
   / LPGS For Kubota B2910 #167
Looking forward to seeing how this project goes. I think you guys are starting to get some snow up your way, so you should have a lot of shop time now!
Any update on your "good neighbor"? I haven't seen any updates on that thread in a while except that he "got out" and was back in town.
Yup ... we had our first snow this season earlier today ... mostly flurries, with a couple of intermittent squalls. None of it stuck to the ground.
He's been seen around in the business area of our small community.
Supposedly has put on a some weight. Still as stupid if not even more so apparently ...
Decided to cut up the welding table top for the side plates and just do it right, rather than using the 10" c-channel for the sides.
Side plates will be 14" tall and 62" long, with a 5' width on the LPGS.
2 1/2 zip discs later:
Made a little progress today:
Just need to make another one for the other side, then I can get U. B. to break out the gas axe and we can form the bottom runners around the curves on the end and bring them up the sides...
2016 Dodge Ram 5500 4x4 Crew Cab Stellar 4421 4,000lb 2 Ton Crane Service Truck (A55973)
2016 Dodge Ram...
PALLET TOTE OF MISC (A58374)
PALLET TOTE OF...
2013 FORD F-350 XL SUPER DUTY- FLAT BED (A58214)
2013 FORD F-350 XL...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
light tower (A56857)
