Trusty JD and a big Log
/ Trusty JD and a big Log #1
Dave Pee
Live Oak, Florida
JD 2032R 2015
Cleaning up my neighbors yard. Ran across this dry pine tree - about 30 ft long. No problem lifting it with grapple and 32 HP.
/ Trusty JD and a big Log #2
I guess we have different standards for a big log.
/ Trusty JD and a big Log #4
Yep, my big log has roots on it: :D
It was vertical earlier:
/ Trusty JD and a big Log #5
My big log weighed 10k with the top of the tree gone. My tractor couldn't hardly lift the top part so it was more than a ton. IMG_0073.JPG Here's another big one IMG_0096.JPG
/ Trusty JD and a big Log #6
How big is big? It is relative term conventionally.
Six ft. tall may be considered tall in a group that averages five and a half feet. Six ft. Tall in an NBA dressing room might be considered short!
/ Trusty JD and a big Log #7
Considering you can't cut the red woods I consider anything I can't cut with a 20" bar "big". IMG_0601.JPG
/ Trusty JD and a big Log #8
Pardon the forks, they're chained to the bucket haha. Forks are off a forklift, still has the huge 1" steel plates on the back of it. Having it this far forward of the pins doesn't help with my lift capacity. I had my brother cut it down, all those vines you see are poison ivy which I get pretty badly and he does not!
/ Trusty JD and a big Log #9
Unless I had my buddy who's not allergic to that crap I'd have left that alone. I'd probably be in the hospital after cutting that log.
/ Trusty JD and a big Log #10
I've had friends who seemed to think I should drop everything I have to do and eradicate poison oak/ivy from my woods. I just don't invite them into the woods.
/ Trusty JD and a big Log #11
Well - I have a green log chart. It tells me how much a 5' or 10' chunk of green Ponderosa pine will weigh. My pine will get up to and a bit bigger than 36" on the butt. So a 10' chunk that's 36" on the butt will weigh around 3180#. My tractor will lift this but with all due consideration its just a little to dangerous to transport this weight. So the 10' becomes 5' - weighs around 1600# - and is easily transported.
I don't have the time, patience or reason to be in a weight lifting contest.
/ Trusty JD and a big Log #13
When my 28" bar can't make it through from both sides it's definitely a bad day. Wait, that's never happened. The one on my forklift is a little better than 40" DBH and it's probably the biggest log I've had.
/ Trusty JD and a big Log #14
That comes to 45 pounds a cubic foot assuming it's 36" diameter the whole length. I'm guessing the chart is high by 1000 pounds or so.
/ Trusty JD and a big Log #15
I'm fairly certain the largest tree on our property is well under 36" in diameter. Most are in the 14" and under range, but average over 60' tall.
/ Trusty JD and a big Log #16
If you have to strain its big enough.
/ Trusty JD and a big Log #17
That's why I had my brother cut it for me, I didn't touch it! It was standing dead in my front yard, every time the wind blew it dropped sticks and branches all over. There are 3-4 just into the brushline just like it, I'll take them out eventually but this one was the worst!
/ Trusty JD and a big Log #18
Oooo - tough crowd today!
A week and a half later, let me be the first to say thanks for sharing. That was indeed a handful for your equipment.
/ Trusty JD and a big Log #20
4570man - I recalculated a 36" x 10' chunk of P. pine and it still comes out 3180#. Perhaps my calculations are in error but that would mean that ALL the calculations on the web site I use were also in error.
Formulas and values
TT - - pie(3.14)
D - - diameter in inches
R - - radius in inches
1728 Cu In = One cubic foot
One Cu Ft of P. pine weighs - - 45#
TT x R2 x length(in inches) = Cu inches
Cu in divided by 1728 = Cu Ft
Cu Ft x 45 = total log weight
3.14 x (18x18) x 120 = 122, 083.2 Cu In
122083 divided by 1728 = 70.65 Cu Ft
70.65 x 45 = 3179.25 pounds
New/Unused Wolverine 78in Quick Attach Land Leveler (A65583)
New/Unused...
42in. Pallet Forks (A65640)
42in. Pallet Forks...
New/Unused Landhonor Mini Grapple Bucket (A65583)
New/Unused...
2012 Hyundai Sonata (A62679)
2012 Hyundai...
Ford 550 Backhoe (A65579)
Ford 550 Backhoe...
J.I. Case 2090 Tractor (A66285)
J.I. Case 2090...
