Good morning!!!!
   / Good morning!!!! #64,161
I hear that Justin Verlander took my advice and married Ms. Upton yesterday. :)
I got a big case of "couch potato" yesterday, recuperating from the bush hog blade changeover....
   / Good morning!!!! #64,162
67°F and .47 inches rain last 24 hours. Raining as I type.
Sunday football :)
a keeper for sure - Blessed I am.
Extra prayers for you Randy
Be safe
Have a great day
   / Good morning!!!! #64,163
Good Morning! 50F @ 9:30AM. 20% / 0 in. Sunshine and clouds mixed. Slight chance of a rain shower. High 54F. Winds SSE at 10 to 15 mph.
Hopefully, Randy, at your wife's service you were surrounded by friends and family, and they'll lend you a shoulder to lean on. When my mother died, I met some of her friends for the first time, and it was a comfort to learn more about her from them. A few stayed in contact after the funeral, long after most had forgotten her. With luck you'll meet a few of those, too.
I've been hearing the telltale scratching sound of a potato bug in the office the past few days, and this morning it was clear enough I found it. This time, instead of squishing it, I corralled it long enough to don a pair of gloves to pick it up and launch it off the front porch, where hopefully it makes a proper home. Seems like I always get one in the spring and another in the fall when the weather changes, but they're so big I wonder what else could get in the same way. Not a comforting thought.
Got a start on the respoking job on the old motorcycle yesterday. Pulled the tires and tubes off both, but moving a bunch of stuff monkey-move-up style around to get to the tire mounting machine took longer than pulling the tires. Then slowly let the tension off all the spokes of the first wheel until I could work the nipples and spokes by hand, pulling one completely apart to see what was involved. The first thing I found was that they'd sent me the correct length of spoke, but they wouldn't fit the bushings at the hub side, and the nipples wouldn't go through the holes in the rim. I shouldn't have been surprised, as there were signs in the bearing stack that these were wheels made before BMW had gone to a thicker spoke correct for the model year stamped on the head badge, and which had been sent by the vendor. Set up a little fixture on the mill to drill out the bushings, and set up a wireless drill to do the rim holes. That worked well enough until, after pulling about ten more spokes, I discovered that the square shoulders on the bushings were tailored to the recesses in the hub, and not all were interchangeable. Managed to figure out what went where and got the ten new spokes back in place, but abandoned plans to completely disassemble the wheel for better access and a bit more polishing. Between the bushings and also noticing that each of the rim holes was drilled in a direction to point to the matching hole in the hub, it didn't seem very likely I'd be able to reestablish the correct orientation once I brought the parts back together. Both wheels are the same, and I'd have the other one to use as a pattern, but there was so much to get wrong I think going forward replacing one spoke at a time is the best approach. Hopefully I'll get the rest of them done today. Not exactly the relaxing Sunday I usually plan, but should be pretty satisfying if I can pull it off.
This last storm left an inch of rain behind, not near the two and a half predicted, but enough so that the county lifted the total burn ban. If it warms up enough I'll scrounge around the wood pile and see if there's enough dry stuff to put together a campfire tonight, which thanks to the expiration of Daylight Savings Time, will come comfortably close to dinner time from here on out.
Hope everyone enjoys the rest of their Sunday...
   / Good morning!!!! #64,164
Meant to post this Fri. Some of you guys are sitting on a gold mine.
   / Good morning!!!! #64,165
after struggling with the hitch adjusters to get them free, I then spent a very enjoyable four hours cultivating my neighbor's collards in two different fields.
He came out, smiled, and promptly told me I had missed a row. Which I had...
though he was more concerned that he had a half gallon of cheap booze he couldn't drink without his chasers, whatever they are, of course last Thursday he had told me he had sold some produce and promptly bought four half gallons. He has one left. Half gallon a day. Is that possible? Can you imagine how pickled he is? And he was complaining he didn't feel good.
Collards are a big deal here for the holidays. Very traditional vegetable for traditional Southern meals.
If he can get his collards to market, which remains to be seen, he could make some good money over the holidays.
I'll try to help him.
Little Massey did great, really did need 4wd as the tines were digging in pretty well. Just purred along at 2100 rpm in cruise control in low range.
As you can see these rows weren't exactly set down by gps, so I had to pay attention to where the row went.
   / Good morning!!!! #64,166
geez horrible to come in and see the news in Texas, pastor's 14 year old daughter killed among so many others.
Do folks have to carry guns to church now to protect themselves? Sad, very sad.
   / Good morning!!!! #64,168
Holy mackerel, Drew, that's a LOT of collard greens! Who's gonna weed and pick them?
Half gallon of cheap hooch, A DAY? Well, I guess if you started first thing in the morning, and kept hitting it until you went to bed, you might finish one off. I'd be more likely to pass out after the first three rounds, but I'm obviously NOT world class like your neighbor.
I imagine that after all that booze, the shape of those rows came naturally!:laughing:
   / Good morning!!!! #64,170
That is not far from some of our Texas friends. Prayers sent. Ed
I was thinking that Ed, whether we had any members or their family in this area.
A little country church.
I have been a life long pacifist. I did mention, however, in our Meeting a few years how do we peaceful folk handle someone with a gun coming in and opening up.
It was a topic none wanted to explore. How can anybody say it won't happen here anymore.
I suppose I could sell everything and go back to living on a boat and head to the Exumas. I could run a tractor with a rake on the beach, keep things tidy in paradise.
Nice small house built to withstand a Cat 7 hurricane. Better protect the tractor too.
There are sure a lot of mentally ill folk on the loose and we are going to have to be creative in protecting ourselves.
RNG that is just one field, there's another one almost as big. My neighbor is now in a race for the holidays, with rain coming, which is good, and if frost holds off, he can have a valuable marketable crop for Christmas. The question is how cold is it going to be until then. He might make it, it's quite the gamble this late in the year. Most crops are being harvested locally and winter wheat planted. Seeing green crops in the field in December is dicey even for here.
Yeah, I have absolutely no idea how he plans on harvesting it all. I think by hand with Mexican farm labor he thinks he can call in.
I'm going to look up collard harvester for kicks.
Unlikely I'll be adding a collard combine to my fleet.
   / Good morning!!!! #64,171
Drew, you cultivated in 1 row more than my cultivator has ever done. Lol. Congrats on the good work, and getting the sway turnbuckle free.
   / Good morning!!!! #64,172
Good evening all. 70F this morning, mostly clear, no fog, light wind. Wind peaked out early afternoon then dropped off to calm early evening. Cold front has come through and temp has already dropped to 61F after a high of 91F. Chapel this morning, then did a meals on wheels run ( with a shopping cart :) ) lunch with stepdaughter and light duty after that.
Randy more prayers sent for you and family.
Buckeye thanks for sending TBN condolences.
Drew that is more cultivating than I have ever done, manual or on tractor
   / Good morning!!!! #64,173
Sad about the Texas church in Southerland. Prayers for the victims and families.
Drew, I was thinking the same line, how do you protect yourself at church now?
I read where the guy was basically a loser, wife and child beater, disciplined by the Air Force, demoted and kicked out.
But darn, what a loser he turned out to be. It has been all too common down here for Latinos to get so violently jealous, that they commit murder/suicide on their families.
________________________________________________________________________________________________
No tractor time today. And now it gets dark by 6pm. So, only weekends available to get tractoring done.
Drew, very nice of you to help out neighbor. I had a friend who drank about that much, almost died, got healed up, started in again on wine, then he got to where almost any amount of alcohol would make him stumbling drunk. Happy to say that his company called him out, and sent him to rehab and told him to walk a straight line or get shipped out. So far, he hasn't had a drop in almost a year.
RNG, I would've guessed that some key photos would help you take out all the spokes and get them back in, but it does look intimidating. Safe and sure might be the way to go.
   / Good morning!!!! #64,174
No front here yet. Nov 5th 9 pm and it is 76F still and calm.
   / Good morning!!!! #64,175
2017-11-06, 0350
55 right now...more rain today and a high of about 60.
   / Good morning!!!! #64,176
Good morning all, low this morning is 53, going to 70 with a 70% chance of showers. Hope to get more done on the shop vac/cyclone cart today, we will see. Need to take mom in for a heart test this afternoon.
RNG, my dad and I did two sets of bicycle wheels when I was a kid, can't imagine balancing motorcycle wheels.
Randy, love you brother, still praying.
Praying for Sutherland springs.
Have a great day. Ed
   / Good morning!!!! #64,177
Good morning. It is sad this morning to hear of so many people being murdered in Texas. Kyle, I can imagine your anguish, when the simple act of attending a church appears to make your family more likely to be a target in horrific cases like this. Whatever you decide, think it all through carefully before allowing a madman to make significant changes to the way you like to live.
Guy Fawkes day passed relatively quietly last night compared to the fireworks that went up on Friday and Saturday night. I liked the big bangs when I was a kid, but nowadays I am all too aware how much they scare livestock and domestic pets and wish everyone would be content to see a display that lights up the sky with an occasional soft thud, rather than multiple fast cracks that sound harsher than any thunderstorm.
Drew, that's real farming, so good to see you making the most of your new little Massey :thumbsup:
   / Good morning!!!! #64,178
58 going to 73, probably some rain later.
Up early. Coco decided she wanted to run a possum off the front yard and I couldn't get back to sleep...so drinking coffee and catching up. Plus it takes a while to start sleeping the extra hour that the time change provides.
RNG, that spokes project looks tough. Good luck.
Drew, nice farming.
Drove to my in-laws yesterday to set up a ground blind for my FIL...he can't climb into his tree stand since his stroke, but still wants to be out with the deer. Hard to break a habit of hunting after over 70 years of doing it. The ground blind is like a small tent with lots of screened windows. We bought him a nice solid swiveling chair with a built in gun rest that will help him keep his aim steady. Cut some brush to put around it and it looks over his favorite hunting area. He's set.
Then cut a stump he wanted removed from his backyard and drove home. Light traffic for a weekend on I-95. But 425 miles is a lot of driving in one day. I downloaded a couple of podcasts onto a thumb drive to listen to on the ride.
Plan to take my muzzleloader out back for a while and then get some chores done. Maybe Drew has inspired me to clean up our garden, except for the kale, broccoli and collards. Lots of dead tomato, pepper, bean and other summer plants to remove, and some weeds. Some of the landscaping cloth has deteriorated and will be a pain to clean up. I used 2 different brands...I liked the "look and feel" of the higher priced one, but it is in pieces now. The cheaper one still looks great.
   / Good morning!!!! #64,179
52 high of 70 today but very cloudy
Prayers for Randy and his family
Prayers for those in Texas so sad
   / Good morning!!!! #64,180
Drinking first cup of coffee. 44ー with cloudy skies this morning. Heading to 44ー with some sun in afternoon. Good visit with Son's family yesterday. Not much planed today. Haul oil to Walmart and TSC.
Randy, thought's and prayers for you and family.
Drew, I had to look up Pacifist to make sure what it is. Sure would be a good thing. But _ _ _ _ _ _ . Maybe that's why the discussion did not go far. Good job cultivating. I did it when I was a teenager. Would be a lot nicer today with ear protection and iPods.
RNG, I was going through a tool draw the other day. Still have a set of spoke tighteners that never got used. Tool my motorcycles to a shop for that repair.
Wngsprd, my son showed me his birthday gift from his wife. A muzzleloader. Got my interest. Will be going to range and try it out in near future.
Good Morning All.
2014 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2014 KOMATSU...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
204158 (A57193)
204158 (A57193)
2017 Ram 1500 Pickup Truck, V6, 4X4, Automatic Transmission, 212,570 Miles (A56438)
2017 Ram 1500...
