   / Harbor Freight Tools that don't suck #8,001
Sitting in docs office to get gout prescription, I see a US General tool cart in the room... View attachment 526857. and yes, it is US General, the draw with name tag is towards wall
I am cool with the HF cart in a medical setting. It is part that 1/3 of hospital deaths are direct/indirect related to medical mistakes that concerns me.
It seems more and more people realize China and India have both the technology and local markets to become the Western Europe, Japan and USA of yesteryears. China and India will own the EV market in 20 years from now of the technology that replaces the EV market as we are reading in the EV thread.
Bashers of HF are becoming the new generation of NON mover and shakers I expect. Our 20 year old children seem to focus more on value than country of origin unlike we living in Social Security land. Their generation feels we screwed their generation future's in a major way.
Now working to rehab our new to us 1966 US build Ford 3000 tractor I realize that all of the engine parts are not from the USA after all. The after market parts that I am finding are mainly from the same place where HF equipment comes. Pull the parts in today's new tractors that are sourced from India and China and I bet they will not even start and work.
Old men in a New world perhaps! :)
   / Harbor Freight Tools that don't suck #8,002
A bit off-topic, but let's not forget that every generation thinks they have all the answers and everyone who came before just made a mess of the world. They just haven't had a chance to make their own mess, and they will. Some foreign-made products are a good value, others not so much.
Now back to HF tools that don't suck.
   / Harbor Freight Tools that don't suck #8,005
A few days ago I posted about buying this kit - Air Compressor Pressure Switch, Safety Valve, and Gauge - $12.50 on Ebay.
1/4" BSP 4 Port Single Phase Air Compressor Pressure Switch + Safety Valve Gauge | eBay
...To repair my year 2010 Harbor Freight 10 gallon compressor.
attachment.php
I got the kit installed. Comments if anyone in the future is considering this:
The time spent wouldn't be worth it in a hourly-wage environment. Just get a new compressor and give this one, and the kit, to some kid who can put a couple of weekends into fixing it.
I got it right in ordering the BSP (British Standard Pipe thread) version of the control instead of US-spec threads.
This control is widely used. This one is 15 amps 110/220, the other common one on Ebay is rated 26 amps and might make a better replacement. While Ebay shows 'up to 175 psi' this is adjusted and labelled 115 psi, and includes a new gauge redlined at 120 psi.
The hole in the top of the control isn't the air pressure adjuster, its the holddown screw for the cover.
This kit has a name brand on it, HF's was unbranded. Only one difference but it took hours to resolve: there's a piece of quarter inch copper tubing that goes into the bottom of the control and this branded kit used a larger diameter compression nut there. While the copper tubing was generic US-spec, the tube had to be replaced, with a new compression ring/donut, to attach it to the control unit. I tried carefully slicing off the old compression donut and replacing it but the new compression donut wouldn't seal. I had to go to town and get a new 10 inch piece of quarter inch copper tube. Then the other end of that copper tube is flared. I had the flaring tool but had to ream and burnish my new flare before it would seal. The compression nut at the lower, flared end of the tube was so poorly made that it slipped, didn't even strip, on the threads it mated to. That explained why I found gasket paste there when none should be needed at a flare fitting. Plenty of teflon tape on those threads compensated and I finally got that compression nut installed securely. Bah.
If anyone makes this replacement I suggest lay the control valve on its side like some later compressors, rather than upright. And pre-wire the wall cord to what will be on the lower side of the control before screwing the control onto the tank. This change makes it unnecessary to work with a mirror and flashlight to connect the copper tube in what would have been in tight space underneath the control, now it's accessible on the side facing toward where that tube is headed.
Ok, the repair made it like new - new control valve, new safety bleedoff, and even a clean new gauge - and the compressor is back in service.
Ebay photo. You can see in this photo how installing the control on its side as oriented here makes it easier to attach the copper tube to the compression fitting, contrasted to the original vertical orientation for the control with that fitting crowded under the control, right next to the vertical compressor outlet pipe.
FA82C69626969176CCAE63C623CF133333D65FCA939A162683936352D236CC33C9D2239C10C7CED223C999CFD2C42353C9CC9D36CB9DD57333C623A063.jpg
   / Harbor Freight Tools that don't suck #8,006
I need to cut some steel roofing thats being used as siding on a pole barn. I don't think a circular saw is ideal because it's an active livestock barn and has hay stored in it too so I don't wan't metal shavings raining down everywhere. Would the swivel head electric nippers from HF work?
14 gauge 4 Amp Heavy Duty Metal Shears
   / Harbor Freight Tools that don't suck #8,007
Plus sawing leads to paint rusting due to the heat damage I was told by a local metal dealer.
   / Harbor Freight Tools that don't suck #8,008
Yup
I bought a pair to assist in cutting holes for windows on my siding. Worked fairly well. Just carry a regular hacksaw blade for when you get to "problem" areas that the nippers don't quite fit but you've got that last 14" to go.
   / Harbor Freight Tools that don't suck #8,009
I bought one of these, about 5 years ago, to cut Formica sheets for some shop projects. They worked well and easy to follow a line. I’ve also used them on sheet metal.
Bobcat T590 (A53317)
2012 Ford Transit Connect Van, VIN # NM0LS7DN0CT092703 (A57453)
2012 Ford Transit...
TRANSMISSION JACK & TRACTOR CYLINDER (A54757)
TRANSMISSION JACK...
5PC. WICKER SET (A58374)
5PC. WICKER SET...
2012 MACK GU713 (A58214)
2012 MACK GU713...
LIGHT TOWER (A56857)
