which portable generators do people have
/ which portable generators do people have #161
/ which portable generators do people have #162
That sense, but as usual there's always a catch, I need 240v for hot water heater and well pump, so who makes a 7000 watt generator inverter?
We just bought a Briggs & Stratton Q6500 Inverter for $1,500. Pull start.
Q6500 QuietPower Inverter Generator (Yamaha is about $3,000, Honda is fuel-injected and $4,000.)
Pluses:
  • Has 240V outlet, designed for home backup.
  • Five gallon internal tank with gauge.
  • Will run up to 14 hours per tank according to manufacturer: from our limited use that is conservative.
  • Has two USB ports for charging.
  • Has built-in wheels and a collapsing handle.
  • Relatively quiet.
  • Really low price for quality Inverter this size.
Minuses:
  • Wheels do not lock - some users report it will walk on hard surfaces.
  • Pull start only: effort is not high but requires a long pull.
  • No option for remote start.
  • Full 5000W Running / 6500W starting is only available as 240V output: designed for home backup, not RV use.
/ which portable generators do people have #163
They are costly but kinda a buy once thing. I'd like to see these have a propane option.
Looks like Champion has one but not in the 220v flavor.
Amazon.com : Champion 34-Watt Dual Fuel RV Ready Portable Inverter Generator with Electric Start : Patio, Lawn & Garden
/ which portable generators do people have #164
I'm not nuts, I just like HIGH QUALITY RELIABLE tools, I get a huge enjoyment from owning them! AND I'm willing to save more, to own them...
Ditto
/ which portable generators do people have #166
We very seldom lose power in Boston so couldn稚 justify the $4,000 EU7000 and wanted to give B&S a shot at our business. We still have three EU2000´ for more-portable use.
Wish B&S came out with a $2,000 Q6500 with remote electric start, bigger wheels, full output through the 120V outlets, etc. But as they are backordered most places into December, it has become a popular choice as-is.
Sound readings.
Full throttle, 3 feet away 89dB . 20 feet: 80dB.
Eco mode 3 feet away: 83dB. 20 feet: 75dB.
For reference, EU2000i. Our EU3000is was slightly quieter.
Full throttle, near 80dB. 20 feet: 70dB.
Eco mode near: 74dB. 20 feet: 67dB.
The app was the iPhone app Decibel 10 if you want to run your own tests.
/ which portable generators do people have #167
Sound readings.
I paid $2000+ for a Honda ES6500 ...... 27 years ago!
Sure,.....mine is electric start, and water cooled, but .....
......$1500 (or less) for a manual start, quiet, 6500W rated, inverter generator, is an amazing deal for 2017.
If I needed another backup generator, (I have 3) I would definitely buy one!
/ which portable generators do people have #168
I only run a generator when I REALLY need it, it's considered one of my "emergency tools", so I buy known quality... And, in the long run it has paid off for me.
Just because some one can get something built cheapo in china, and put a common name on it, doesn't make it good quality that can be depended on for long life.
SO, I have been sticking to tools of "known" quality...
SR
/ which portable generators do people have #169
No one every got fired for buying Honda... or was that IBM?
Honda has a good reputation that it built... Japan was not known for quality in the 60's... saying made in Japan meant cheap back then...
No way implying others are not good values... but Honda also has the highest resale almost across the board.
I have often wondered why Honda no longer sells it super quiet Diesel water cooled generators that were marketed to the film industry and such...
/ which portable generators do people have #170
Pluses:
  • Relatively quiet.
Minuses:
Thanks for that link, that one looks more doable then the Hoonda 7000@$3,799, but as always there a slight catch, 5000 running watts, when I have my electric hot water on my transfer switch box two meteors are reading just a hair under 5,000 watts if those are accurate that would put the gen/invert near the limit or edge of the universe, guess I could take a cold shower thow but at my age I dont need cold showers anymore.
"Relatively quiet."<<<<<So this is your opion from listening to it, guess what I'm asking is, you've tried it and thats what you consider it to be? Would you say like a small lawn mower, rototiller, woodsplitter or quieter than those?
/ which portable generators do people have #171
.......... when I have my electric hot water on my transfer switch box two meteors are reading just a hair under 5,000 watts if those are accurate that would put the gen/invert near the limit or edge of the universe, guess I could take a cold shower thow and at my age I dont need cold showers anymore.............
You can wire your water heater so both heating elements don't run when on generator power. Or you can run it on 110 volts so the elements pull less power, but take longer to heat the water.
/ which portable generators do people have #172
You can wire your water heater so both heating elements don't run when on generator power. The second element is for a fast recovery, which is a luxury not a necessity.
Never heard of that, I'll keep that in mind, thanks. Wonder if new electric hot water heaters have a switch for doing that, my 40 gal heater is almost 30 years old, I think it was made by Timex.
/ which portable generators do people have #173
Electric water heaters never run both elements. They are staged so the top comes on first and once it hits temp it enables the lower element. This scheme is used for "fast recovery"
You are correct that you can run it on 110 volts. It will draw 1/4 of the power, about 1,100 watts.
paul
/ which portable generators do people have #174
SR
I bought this one because our Honda EU3000iS was stolen.
Since you buy products of “ known” quality, where was your Honda made?
Honda produces approximately 48 thousand compact gasoline generators ranging in capacity from 0.6 – 80 kVA in Japan, China, France and India, and supplies them to North America, Europe and various other countries around the world.
Honda Worldwide | Power Products - Generators
A little louder than a Honda EU2000i, which is a common benchmark as supposedly it’s the single most popular generator model in the world. We have two Companions and one regular.
A LOT quieter than any construction (ie, 3600rpm Direct) Generator we致e looked at. Indoors with windows closed you barely hear it.
/ which portable generators do people have #175
Since you buy products of known quality, where was your Honda made?
Are you trying to say "Honda generators" aren't of known quality??
Seems being of known quality negates where it was made... but, like YOU posted, they are the "common benchmark" for all others...
SR
/ which portable generators do people have #176
Quality should be based on the quality of power reliably produced...
/ which portable generators do people have #177
You must change your anode on a regular basis?
/ which portable generators do people have #178
That's the the kinda answer I was looking for, thanks.
/ which portable generators do people have #180
Only thing I done to my electric hot water heater is after the first 10 I drain the tank cause someone said that should be done once in awhile, but that drain valve was so hard to turn I never done it since, fraid of breaking it. Then not long after that I got a water softener and I had red water for a few days.
As I think about it, that water heater is over 30 years old now, bet they dont make em like that no more, must be a Honda water heater...............
2014 Bobcat T870 (A64126)
2014 Bobcat T870...
1979 Donahue Dump Trailer (A66285)
1979 Donahue Dump...
2007 International 8600 Parts Truck (A63689)
2007 International...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
John Deere 1770NT Planter Drive (A65640)
John Deere 1770NT...
