Do your own Fluids and Filters on a BX
   / Do your own Fluids and Filters on a BX #461
Mark, you must have missed the post I did a couple years ago. Just mount that second filter underneath like the other one. After breaking one of those OEM plastic ones and losing 5 GL diesel on something; I went to the metal cased generic ones. The 2 hoses just interchanged. Was able to manage it w/o removing the cowling. Also get one of those finger type filter wrenches made to go on a 3/8 socket extension. Oil filter changing is done w/o removing the cowling. I have banged up my cowling and hood so much when I had the forest that am thinking of replacing both this winter. Sure rattles a lot w/a lot of the connection points broken. The age of plastics.
Ron
Yeah I'm going to go with a B series type fuel filter when I get around to it.
Good to hear from you Ron. Hope you are adapting to your new place! Still got the tractor! That is a good thing!!!
Ron
Just bought a metal in line fuel filter from Rural King for $2.99 with the clamps in the pack. Paid $7 for the Kubota plastic ones.
Great advise from you guys that keep the same BX for years.:thumbsup::cool2::drink:
   / Do your own Fluids and Filters on a BX #463
I just did the 50-hour service on my BX1870. I changed the oil & filter, as well as the HST filter. When I got the oil/HST fluid and filters at my dealer, I asked for some guidance on cleaning the HST screen and was told this isn't needed until 400 hours. I found this surprising, as I thought this was done at 50 as well. As a result, I simply changed the HST filter and re-filled what I lost in the change.
Changing the oil/filters was cake. Glad this break-in period is over, as I've really held off on really going above 2500 rpms. Not now! Time to put this girl to work.
   / Do your own Fluids and Filters on a BX #464
It all depends. I've done two BX's and never found any metal in screen. Others have reported differently. Just so you know. I pulled my screen out and with the blazing speed of a guy in his 60's, pushed in a tapered cork stopper. Rubber tapered stoppers are available, so they tell me, at most good hardware stores. Cleaned the screen, pulled the cork, and reserved the screen in the same flash of speed. :) Truth is? I lost maybe a half quart of fluid. Others swear by the vacuum hose on the filler port. In any case, yes. The screen can be pulled and cleaned with very little loss of SUDT.
   / Do your own Fluids and Filters on a BX #465
I used an appropriate sized cork to plug the hole. Marked with a Sharpie and threw it in my tool box. First time (at 50hrs) I had some, not a alot, small shavings. Second time (400hrs) no shavings and HST oil looked good. Replaced it and onward we go!
Never found much in my screens at the 50 hour screen cleaning. Usually stuck my finger in the hole and had cleaning solution (Gas) in a pan and one handed cleaned it and reinstalled it. Will hunt the cork I bought years ago when I do the BX2370-1 next year. :)
   / Do your own Fluids and Filters on a BX #467
I guess I should have taken a photo, but at the 50 hour service I did engine oil/filter, 2x fuel filters, front axle grease, air filter, and rear axle/HST fluid/filter/screen. The screen was at least 50-60% covered in grey rubber gasket maker... I generically call anything like that Permatex. I cleaned it in the parts washer, shot it with brake cleaner and put it back in it's home. There was no noticeable performance or sound change, but I am sure that the fluid restriction at the screen was greatly reduced after removing all of the small fragments of rubber like material.
Total cost from M&R Kubota for all fluids and filters was just around $300. So this way I know that the clock is set to zero for all fluids aside from the coolant, I'll do that in the spring when I change the engine oil/filter again. I am sticking with all Kubota branded parts and fluids.
   / Do your own Fluids and Filters on a BX #468
To me, that' a wise move. Any difference in price is minimal and I'm convinced you get a better filter and with a correctly set pressure relief valve. Years ago I used to endlessly cross reference filters and applications only to save 35 cents.
   / Do your own Fluids and Filters on a BX #469
Yea, my father is retired but now works part time moving Enterprise Rental cars around the area, and his home base store is a few miles from M&R Kubota. So I just ask him to stop by on a day he is working and he can get what I need with no real inconvenience. It's not worth it (to me) to play the game of guessing who's filters meet or exceed what criteria to perform the job at the suitable quality level as a factory part. Especially when the Kubota filters are what, $12? The filters where not the expensive part, the Super UDT2 was a little costly. But... you know what, my wife and I ran to a bar last night and drank down a few beers and had some greasy food, we left after paying a bill of $71 plus a $12 tip. I took a dump this morning and it's all gone now. The $300 I spent on Kubota service parts/fluids will keep me happy for a year. That is $300 well spent, where as last night I spent over $80 to create a turd 12 hours later!!! That is not really good money spent :laughing:
   / Do your own Fluids and Filters on a BX #470
I had a couple of fairly long curly shards of metal on my screen when I cleaned it the first time. After that, not so much.
   / Do your own Fluids and Filters on a BX #471
hi i had to change one hydraulic steel line that go under my tractor it was all rusted and the other 2 was ok it took me about 1 hour to do the job if you guys have same bx as me better check the line its along the left wheel you dont see it unless you take the wheel off
I think the screen mostly catches those production metal bits and the filters (Kubota only filters and Hyd fluid for me) do most of the cleaning thereafter. If something breaks then the screen will probably do some filtering of metal. Not sure the owners manual says to even check it after the first time?
Sun shining some in Ky and temp in the 70s now:confused3:1 so that get the tractor/mower out is upon us. I got my F3080 out a couple days ago to mow a lot across the street that I sold a man and had told him I'd do the first mowing on it thinking I had a couple of months lee way but he got out cleaning it up, grass is growing and weather is warm. Anyway, if one hasn't done their service on their tractor it could be a great time to get it done and do it yourself if at all possible. Easy peasy job and helps one learn the basics of their machine and can save a bundle of cash.
For the person questioning their 50 hour service on their BX1880 and what's required, recommended by Kubota.
Cold weather has finally hit Ky and sure other states so now is the time for service that you didn't do when work was being done. Many people have read/viewed this thread and most appreciated it. If it helps then glad I posted it. If it ruins your day then move on and read some other posts. :)
   / Do your own Fluids and Filters on a BX #476
Yep, tons of great info buried in this thread!
   / Do your own Fluids and Filters on a BX #477
Just did the annual service on my BX2660 last weekend. This thread is always helpful as a refresher course.
I and maybe a few others forget over time something remembered in the past which is happening more frequently now than in my past. I like to have info available to verify what I think I sometimes know.:)
   / Do your own Fluids and Filters on a BX #479
Sorry if this has been asked before, but I couldn,t find any info about it.
I,m ready to change the UDT fluid to sudt 2 in my BX 2370. How does one get the old fluid out of the loader cylinders and the new stuff in there, without mixing the old with the new ?
   / Do your own Fluids and Filters on a BX #480
One does not unless one is very posterially retentive :laughing:
You could break lines loose, in-pin an end of the ram and manually compress it to push out the pint or quart of contained fluid. But I do not think that most "normal" people would do that or worry about it.
But if you so desire, you can make it into one heck of a fun project! Have at it!
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
2019 Caterpillar 239D3 Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
